Boxee Box for pre-order, $199US
Discussion in 'Audio Visual' started by TrennaHowar, Sep 15, 2010.
  1. Frankeh
    Frankeh (Banned or Deleted)
    Oct 8, 2010
    396
  2. pongie
    pongie Member
    Dec 1, 2004
    1,050
    Sydney 2166
    Where does it store the meta data? I've read it has to rescan on reboot.
  3. KRiSX
    KRiSX Member
    Jun 13, 2002
    7,989
    North-west Sydney
    it'd have to have some internal storage? like very tiny amount... or perhaps the SD slot could b used?
  4. Frankeh
    Oct 8, 2010
    396
    The unit has 1Gb of NAND flash memory so I assume it's stored on that.
  5. AdrianL
    AdrianL Member
    Apr 12, 2010
    113
  6. OPM881
    OPM881 Member
    Apr 21, 2009
    1,652
    Cairns
    In regards to re-scraping on reboot, yes that appears to be true, the 1gb internal is used entirely for the OS and boxee and apps. They are looking at letting you put the metadata on an sd card though.
  7. DTG
    DTG Member
    Sep 16, 2002
    541
    Melbourne, Aust
    Well after playing with my boxee box here are my thoughts.
    1. Adding shares that didn't "disconnect" was a challenge. From my linux server the secret was have netbios configs and "nbd" running.
    2. Takes way to long to scrape the folders, approx 18 hours for 4TB of TV shows, movies and music
    3. While it was scraping my unit was prone to lock ups
    4. Some data seems persistent. Cover art goes but titles remain.
    5. No problems at all with playback, Blu ray isos, 1080p mkvs all worked for me with no issues after the initial scans where completed. Fast forward and skip work a treat, where as my PS3 media server would lock up (i950, 6GB, SSD).
    6. I don't use it for online content so the UI changes coming for user like me that use it for local content will make it better.
    In summary for $300 this box does exactly what I want in a single unit that is low power and I will never need to fuck with. I can only imagine it will get better with a few new firmwares.
  8. TheChemist
    TheChemist R.I.P
    Apr 5, 2007
    1,035
    Youcan scrape manually using something like EmberMM and save the scraped data into movie/tv folders so it doesn't have to scrape them.
  9. OPM881
    OPM881 Member
    Apr 21, 2009
    1,652
    Cairns
    I dont think boxee uses pre-scraped data
  10. cavanor
    cavanor Member
    Feb 18, 2002
    781
    Hulu etc should be available via VPN though right?
  11. Dropbear
    Dropbear Member
    9,720
    WTF?
    Seriously? it has to re-scrape the entire media collection everytime you reboot the box?
    And no one thinks this isn't a deal breaker???
  12. jezza323
    jezza323 Member
    Apr 7, 2005
    1,375
    it is definately a deal breaker for me :)
  13. FatBoyNotSoSlim
    FatBoyNotSoSlim Member
    Sep 9, 2002
    14,081
    SE Melbourne
    Not really no.
    The use case for a Boxee would be for people that want to watch their media streaming from online, and only suppliment it with a small collection of media offline.
    The above user with 4TB+ of movies/tv would be the category of a power user that knows what they're doing, and would use a system that can handle it, ala a full powered HTPC.
    So no, it's not a deal breaker as the core target of the Boxee wouldn't have a lot of media to begin with.
  14. Dropbear
    Dropbear Member
    9,720
    well i disagree, but oh well! not for me it seems like
  15. TheChemist
    TheChemist R.I.P
    Apr 5, 2007
    1,035
    You can manually scrape metadata using an external program and have it saved permanently
  16. Danske
    Danske Member
    Oct 27, 2004
    18,355
    Melgoon
    Agreed. What a waste of time for the thing to rescrape every time you turn it off :lol:.
    More info plx! Is it easy to setup?
    I cant afford a boxee box at the moment, but I'd like to get as much info as I can, in case I can afford it randomly lol...
  17. FatBoyNotSoSlim
    Sep 9, 2002
    14,081
    SE Melbourne
    If you use XBMC*, one of the key 3rd party apps, is a metadata scraper. Whilst XBMC does this itself, it's not as fast or accurate as a 3rd party app.
    Ember Media Manager scans your library, matches it to IMDB/MovieDB/TheTVDB and from that creates the thumbnails/fanart/posters/cast information/ratings/synopsis etc. of your media.
    Take a look: http://embermm.com/
    It's pretty easy to set up, point it to some directory, set up some options if your prefer X over Y, and either let it work on it's own, using best guess messages, or do it all manually for you.
    When I first ran it (400+ movie collection), I had maybe 20 or so that were wrong/not detected, which I promtly ran a manual rescrape on, and fixed up manually. Since then, I've been adding new movies with a manual scrape, simply so I can pic the poster and fanarts that I like. :lol:
    *I infer XBMC as they started (or one of the first) the whole metadata and image downloading for media. That and Boxee is based off them and would most likely use the same metadata standards.
  18. Danske
    Danske Member
    Oct 27, 2004
    18,355
    Melgoon
    You set up Ember on the file server? right?
  19. FatBoyNotSoSlim
    Sep 9, 2002
    14,081
    SE Melbourne
    You can run it from wherever you can access your files, then it creates the metadata files in the movie directories. Which means, you better have a file structure of
    \Movies
    \Movies\Movie 1
    \Movies\Movie 2
    \Movies\Movie 3
    Set up already, as it makes it 10x easier.
  20. Danske
    Danske Member
    Oct 27, 2004
    18,355
    Melgoon
    Sweet, sounds easy enough!
    Thanks mate.
