[WORKLOG] Build From 2011. Updated : Nov 2015
Discussion in 'Extreme and Water Cooling' started by kot0005, Nov 24, 2011.
  1. auApex
    auApex Member
    Feb 15, 2006
    1,355
    I'd also suggest getting rid of those ugly case stickers - they look really tacky. Also, why do you have cables spewing out of all the front USB ports? You'd be better off plugging the mouse, keyboard and other peripherals into the rear USB ports and using the front ports for things like USB drives.
  2. leithals
    leithals Member
    Feb 23, 2011
    694
    Central Coast 2257
    Although I agree with the fact that what VeritronX is reporting is not great, I stand by my statement that LLC simply adds extras volts (or increments of) to aid stability. Not sure your example above is exactly right, but I have 10 levels that I can choose from. LLC1 may only add .1v, whereas LLC10 may add 2v. (I have no idea of the actual values). I don't think the extra volts apply until they are required, i.e. under load. The extra v absorbs the vdroop, as suggested, but if I set the LLC too high the vdroop won't account for the volts thereby displaying higher volts than you set in the bios. that's my understanding of how it works explained in my own 'special' way, and is supported from my own testing.
    Following my 'logic' then, VeritronX has his LLC set too high and needs to adjust it accordingly. This will also lower his temperatures somewhat.
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    just got back from the hospital, had my shoulder surgery i cant type gud atm
  4. VeritronX
    VeritronX Member
    Jan 9, 2011
    628
    Unfortunately that isn't how LLC works at all, it's a modified control scheme that's supposed to make the voltage stay as close as possible to the set voltage. This is usually an on or off setting, not in increments.. I think only gigabyte does that and I'd assume their settings relate to how aggressive their LLC is.
    It's not too bad anyways, the voltage regulation on my board is really nice, runs cooler than any board I've ever had.. and while the voltage is higher it's pretty predicatable overall. I just with it could still drop the voltage down when idle, you don't need 1.36v all the time :thumbdn:
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    nop its quite lower than in the bios, my bios voltage is 1.280 and under load its 1.264 something if thats what you mean.
    The board comes with a strip of blue led's above the cpu socket which changw with the voltage that my mobo is using.
    Eg: blinking,the no. of leds that turn on
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    no, the duct tape is holding the thermacol below the pump bracket, its screwed in actually there are a few photos of it in on of my posts above.
    I will tidy up the loop in may 2012, saving up money for a 120gig ssd atm.
    those cables are for charging my phone/bluetooth headset and other two are for my xbox controller.
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    Some finished pics of this
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    I make robo bugs when I get bored. Have a collection of them now. Gave away a few.
    Fresh build moving from CM storm case to 900D. Reused a few parts from the first build.
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    Obviously this is an old build from 2012, was too lazy to upload at that time
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    Accident in front of my house, Had to dial 000. It was so loud!!
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    A year later I decided to go with acrylic tubing..
    1st: Painting the cpu block's ugly screws to matt black.
    Before: After:
    [​IMG] [​IMG]
    Sleeving with MDPC sleeve:
    Heatshrink less sleeving is sooo much easier and a time saver!
    First time using Ek waterblocks, I have sticked to XSPC and Koolance ever since their infamous galvanic corrosion in the past due to improper coatings. The block quality is really really good and well build, hopefully it wont fail on me because I use distilled water. I really don't like dye's.
    [​IMG] [​IMG]
    I will be using 2 colour tubing in my build:) Red and black. I wish Primochill used a protective wrap around the tubes because they scratch so easily :(
    Used the white sleeve samples for the double wire
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Finished sleeving my main cable's :
    Double cable madness
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    lots of corsair fans:
    My First AMD card after using Nvidia for like ever :
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    Ek blocks for R9 290x
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    After Installation:
    Mounted the EK Mobo VRM and Chipset blocks.
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    Primochill gear from THEKOOLROOM:
    The rads :The 480mm, 360mm and a 240mm rads. I slapped some Alphacool stickers onto the rads:)
    Pump Sleeved and ready to go.
    Got a Drain valve/tap and some Modsmart vandal switches. I will be replacing my power, reset, HDD activity Switches and LED's with the vandal ones. Finally, a T connector fitting.
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    First CPU I have delidded.
    Cpu installed with waterblock!
    Coollabs liquid pro thermal paste:)
    Mounted the reservoir, looks so bright.:D
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    First motherboard cover prototype and it broke:(( but hey! I got better measurements for my second one.
    Frosted Mobo cover
    Finally my new sound card and speakers!:D
    Now everything is mounted! Time to sleeve fans and mount rads next.
    kot0005
    kot0005 Member
    Nov 11, 2011
    682
    melbourne
    After a lot of struggling with getting the lengths of the bends right and after wasting a lot of tubing, I realised that I need a tool and this is what I made. This made my life a lot easier..
    Finally got all my tubes bent and sanded down! now to wash and dry them:)
    Front panel with power . reset buttons and HDD indicator(white colour)
    had to change it a bit after a while. No log for the change:(
