Building forms - what to use?
Discussion in 'Programming & Software Development' started by mr sti, Jun 12, 2015.
  1. mr sti
    mr sti Member
    Apr 6, 2004
    8,248
    We have a daily checklist at work that is currently completed by printing it and writing on it with a pen. I would like to automate this. There are about 20 questions which need a checkbox and an initial, with a notes section at the bottom. Any idea on the best way to do this? My thoughts are below
    1. Use Excel, and make a macro to save the sheet as the date into a folder on the network drive
    2. Use MS Infopath
    Anyone got any ideas that may help?
    Thanks
  2. RobRoySyd
    RobRoySyd Member
    Jan 24, 2008
    8,242
    Saving each form as a spreadsheet is going to create a lot of files needlessly.
    Use MS Access.
    Create a table to save the answers, build a form to input the answers, same form could be all that's required for the print out.
  3. zachnedwich
    zachnedwich (Banned or Deleted)
    Jul 2, 2014
    295
    Peenemünde
    InfoPath is a fkn turd, can you use a web based thing?
  4. HSV
    HSV Member
    Jun 15, 2003
    496
    Newcastle
    Use Acrobat, create a form with it (can even be a form created from a Word document that you/the admin person has typed up as the template), and just fill it in based on that. Dead simple with the automated form creation wizard thingy.
    mr sti
    mr sti Member
    Apr 6, 2004
    8,248
    Yep, that sounds much better.
    I know, we use it currently. Company policy won't allow something like google forms.
    Thanks, this sounds easy, ill look into it.
