C++ - Constructors
Discussion in 'Programming & Software Development' started by shihyuan, Oct 15, 2009.
  1. shihyuan
    shihyuan Member
    Apr 21, 2004
    50
    Thornbury 3071 VIC
    I am new to C++ and i am having troubles getting it to work.
    So I have a property.h interface file and then i want to implement the functions in a property.cpp file.
    i have included the codes which i am having troubles with.
    ------------------------ some codes from property.cpp ----------------------
    // default constructor
    Property()
    owner = "";
    address = "";
    suburb = "";
    postcode = 0000;
    error: expected unqualified-id before ')' token
    // argument constructor
    Property(string o, string a, string s, int p)
    owner = o;
    address = a;
    suburb = s;
    postcode = p;
    error: expected ')' before '0'
    ------------------------ some codes from property.h ------------------------
    Property();
    Property(string theOwner, string theAddress, string theSuburb, int thepostCode);
    I hope anyone would understand what i am talking about.
  2. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    Northern Beaches, Sydney
    What happens if you change it to this?
    Code:
    Property()
    owner = "";
    address = "";
    suburb = "";
    [DEL]postcode = 0000;[/DEL]
    postcode = 0;
    shihyuan
    shihyuan Member
    Apr 21, 2004
    50
    Thornbury 3071 VIC
    I just tried that and it didn't solved the problem. Any other suggestions?
  4. oupimiquo
    oupimiquo Member
    Sep 20, 2007
    520
    Check your scopes - is the Property() implementation in the scope of the Property class? The "usual" way to do it would be
    Code:
    Property::Property()
      // stuff
    in the CPP file.
  5. thommo101
    thommo101 Member
    Jul 24, 2002
    1,047
    Perth WA
    I assume owner/address etc are member variables defined in your header file?
    If so the nice way of initialising these is typically in the initialisation list.
    Code:
        owner(""),
        address(""),
        suburb(""),
        postcode(0){}
    Property::Property(string o, string a, string s, int p)
        owner(o),
        address(a),
        suburb(s),
        postcode(p){}
    Alternatively, defined default parameters in your header:
    Code:
    //----------------HEADER-------
    #include <string>
    class Property
      public:
        Property(string o = "", string a = "", string s = "", int p = 0);
        virtual ~Property();
        string owner;
        string address;
        string suburb;
        int    postcode;
    //------------------ CPP -----------
        owner(o),
        address(a),
        suburb(s),
        postcode(p){}
    Property::~Property() {}
    shihyuan
    shihyuan Member
    Apr 21, 2004
    50
    Thornbury 3071 VIC
    thommo101, I tried out your codes and I encountered new errors.
    I am really lost now...
  7. oupimiquo
    oupimiquo Member
    Sep 20, 2007
    520
    You've got using namespace std; somewhere? Otherwise you'll need std::string not just string.
    Also, there's something a little wonky - why have you got owner, address, suburb, and postcode declared just above the constructor? That should be in the class definition, not in what appears to be the global namespace.
    shihyuan
    shihyuan Member
    Apr 21, 2004
    50
    Thornbury 3071 VIC
    I have included some codes from the interface class file and the implementation file so you can get a better idea.
    ------------------------------property_a.h----------------------------------
    #ifndef __PROPERTY_A_H__
    #define __PROPERTY_A_H__
    class Property
    protected:
    string owner;
    string address;
    string suburb;
    int postcode;
    public:
    Property();
    virtual ~Property() ;
    void input() ; // Data input for a Property object
    void print() ; // Data output for a Property object
    string getOwner() const; //Note the use of const
    string getAddress() const;
    string getSuburb() const;
    int getPostcode() const;
    void setOwner(string newOwner);
    void setAddress(string newAddress);
    void setSuburb( string newSuburb);
    void setPostcode(int newPostcode);
    #endif
    --------------------------------property_a.cpp------------------------------
    #include "property_a.h"
    #include <iostream>
    #include <string>
    string owner;
    string address;
    string suburb;
    int postcode;
    Property::property() : owner(""), address(""), suburb(""), postcode(0) {}
    Property::property(string theOwner, string theAddress, string theSuburb,
    int thepostCode) : owner(theOwner), address(theAddress),
    suburb(theSuburb), postcode(thepostCode) {}
    I get the following errors when compiling
  9. Mikos
    Mikos Member
    Mar 12, 2004
    2,945
    Cydonia
    Tried a standard default constructor along the lines of
    Code:
    or even
    Code:
      owner = "";
      address = "";
      suburb = "";
      postcode = 0;
    instead of the ones giving errors? Could also be because they are protected rather than public. Though I haven't touched C++ for a long time so not real sure.
    shihyuan
    shihyuan Member
    Apr 21, 2004
    50
    Thornbury 3071 VIC
    if i do this
    Property::property() {}
    i get the error: Property::property()
  11. underskore
    underskore Member
    Nov 5, 2002
    4,336
    3198
    use the set functions instead of accessing the variables directly ?
    edit: wait that would probably try to call a default constructor or something... dont think it will work.
  12. BAC :S
    BAC :S Member
    Dec 26, 2001
    1,385
    You need to make sure that the string type is declared in your header file.
    Code:
    #include <string>
    class Property
    Otherwise you are using an undeclared type. You should get your IDE to sort the errors in the order it finds them.
    EDIT:
    Also what are:
    Code:
    string owner;
    string address;
    string suburb;
    int postcode;
    doing in the cpp file?
    EDIT 2:
    I assume you've just started programming but a good thing to look into early on is const correctness, its something that gets overlooked by people starting programming but its a very useful tool for catching errors at compile time and makes you thinking about how fields and methods will be used. I see you've started using it but its good to make sure you really understand it. Also you should pass complex objects by reference:
    Code:
    Property::Property(const string& theOwner, const string& theAddress, const string& theSuburb, int thepostCode)
    this saves the arguments given to the constructer being copied to the local argument variables and then into the fields of the class.
    You can also use this when returning complex fields:
    Code:
    const string& getOwner() const;
    Anyway, pretty minor things when you are starting off but its good to get your head around them as early as possible, good luck with the programming.
    Cheers,
    Mark.
    shihyuan
    shihyuan Member
    Apr 21, 2004
    50
    Thornbury 3071 VIC
    you are genius, Mark
    Thanks heaps for that.... cant believe I didnt see that....
