Cable Management mod for ATX power
Discussion in 'Modding Worklogs' started by 192.168.0.1, Jul 4, 2009.
  1. 192.168.0.1
    192.168.0.1 Member
    Nov 18, 2004
    1,452
    Wollongong
    Was talking with another member of the forum lastnight about Murdermod products. I was upset at their pricing and the look is okay for some styles of cases, but for others it's so-so. I thought of my own little mod that may make my case management a little more cleaner :)
    I decided to do this on a cheap motherboard as opposed to my 780i at the moment. Please if your confident with this, give it a try and post your results in the comments.
    20pin ATX + 4pin_12v mod
    1 x Soldering Iron (20w)
    1 x Cut off ATX power cable (dead powersupply)
    1 x Motherboard
    1 x Powersupply
    1m of shrink tube
    Roll of Solder /w Flux
    1 x 3 Burnt fingers :mad:
    The goal of this is to totally whipe that ugly power cable from the front of the board. In my HAF932 having the cable looks crap, I will cut a hole behind both the 24-pin ATX and EPS12v (8pin) connectors to pass this mod through.
    Also this mod will be done a tad dogey due to me working 6 days a week and tonight being the only night i have off. The better method would repin all the cut off ends into a Female 20/24 pin connector for a flush fit.
    Less talk more pictures
    #1 - Original Board
    #2 - Rear of Board
    #3 - And more....
    #4 - First one soldered
    #5 - The workbench
    #6 - Moar..
    #7 - Cables/Connectors used
    #8 - All lines connected
    #9 - 20pin cables
    #10 - 4pin_12v connections
    #11 - Connecting to powersupply
    #12 - End result :)
    #13 - Close up
    Video up soon
    System works well, looks great :)
    Thanks for looking.
  2. hendot
    hendot Member
    1,277
    I've thought about doing this a few times, but never had time or motivation.
    Top work :thumbup:
  3. Chop92per
    Chop92per (Banned or Deleted)
    Oct 27, 2008
    1,296
    CraneBrook NSW (2749)
    wow i never thought of that, that would be AWESOME cable management
    192.168.0.1
    192.168.0.1 Member
    Nov 18, 2004
    1,452
    Wollongong
    Thanks hendot ;)
    After spending the time doing it, burning my hands i'm still happy it worked out good. I love my cable management though. So it's worth it :leet:
  5. Spork!
    Spork! Member
    Jun 5, 2009
    2,295
    Tasmania
    nice and original. :thumbup:
  6. CHemical.
    CHemical. New Member
    Mar 1, 2009
    660
    In a mushroom patch
    Never thought of that before. top work :thumbup:
    Do you mind if i do the same thing to my old board and call it your idea??
  7. xXxDarkness
    xXxDarkness New Member
    Jul 4, 2009
    10
    192.168.0.1
    192.168.0.1 Member
    Nov 18, 2004
    1,452
    Wollongong
    Go for it man, more the merrier. I really did this mod as a share mod. I wanted to get the idea out there, before i do it on my 780i :lol:
  9. broox
    broox Member
    Apr 27, 2006
    3,599
    Ad'laide SA
    awesome job. it's so weird seeing nothing pugged into that fat socket :lol:
  10. Sundarjee77
    Sundarjee77 Member
    Nov 5, 2005
    1,253
    Super impressive!
    That looks great, I'm sure a lot of people will start doing this mod :thumbup:
    192.168.0.1
    192.168.0.1 Member
    Nov 18, 2004
    1,452
    Wollongong
    Here is the promised video, sorry about the angle
  12. Skobb
    Skobb Member
    May 5, 2008
    1,227
    Adelaide, Tea Tree Gully
    Lol, before I even read anything I knew what you were going to do somehow haha
    Good work :thumbup:
    LOL scissors.. Class :p
  13. xXxDarkness
    Jul 4, 2009
    10
    Nice I wish i could do that
    192.168.0.1
    192.168.0.1 Member
    Nov 18, 2004
    1,452
    Wollongong
    I'm glad no one saw the cooking tin for my soldering iron or the rotten apple core :o ;)
  15. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    Northern Beaches, Sydney
    I'd be worried about the solder getting to high temps due to the current draw under load on high powered (i7, S775 Quad) systems. :wired:
  16. Chop92per
    Oct 27, 2008
    1,296
    what do you think they use on the mobo from factory?
    192.168.0.1
    192.168.0.1 Member
    Nov 18, 2004
    1,452
    Wollongong
    But your whole board is soldered together.
    edit: @ chopper LOL
  18. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    So what temp is the solder you used rated for? Did you calculate how much current that joint of x.xx mm diameter can handle or how hot it would get under maximum load? What about the effects of fatigue on the joint from movement or even heat cycling?
    You can do it if you want - but if it was me, I wouldn't be doing it on my prize system or a system that I leave running 24/7.
    That's all I was saying. :) It's definitely a good idea though, once all the above concerns are accounted for. :thumbup:
  19. dazzawul
    dazzawul Member
    Apr 29, 2005
    1,459
    the sutho shire (w00t)
    I'd like to thinkg a 24\7 system would have LESS heat cycling, cause it would go from hot to hotter, rather than cool to hotter all the time :p
  20. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    I wasn't saying running it 24/7 would be worse from a heat cycling perspective (as obviously that comes from shutdown-startup cycles) - my point there was that I wouldn't want to come home after a couple of days away to find some of the ATX wires had broken off and shorted onto the case or something like that. ;)
    Anyway are there any pics of this mod finished? How much clearance is required behind the motherboard? :confused: :thumbup:
