cable management
Discussion in 'Overclocking & Hardware' started by cdtoaster, Oct 26, 2013.
  1. cdtoaster
    cdtoaster Member
    Jan 21, 2007
    4,670
    Tokara forest
    just wondering what you guys do for cable management behind the desk. i have 2 towers and 2 monitors (one is a tv), then 2 consoles, speakers, headphones, LAN cables, UPS etc
    it's a huge mess and difficult to keep clean. ideally i'd like no cables/power board/switch on the floor
    im thinking about trying something like this
    http://www.bunnings.com.au/cable-management-zone-2m-roll-large-zip-wht-cc6793_p4430314
    then just using adhesive hooks to hold it up at the back of the desk
  2. Jim G
    Jim G Member
    Jun 20, 2010
    1,011
    Newcastle
    Velcro. Get a long roll of the double-sided stuff that sticks to itself and have a band of it every ten inches or so - makes it heaps easier to break out sub-lines of cables. You can just get adhesive hooks to keep it off the ground and stick the line Adhesive hooks work great for keeping the cabling off the ground.
    I always found the linked items annoying to add/remove cables to once they had a few in them.
  3. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    8,126
    That plastic coated wire you get with "every electrical product" that "manages the cables".....reuse that....and reuse it.....and reuse it.......
  4. NeonMadness
    NeonMadness Member
    Aug 8, 2013
    28
    Yes,yes,yes,yes ^. Also, Cable ties, i sometimes use string but thats just me.
  5. ipex
    ipex Member
    Dec 24, 2001
    2,270
    velcro is what i use , easy to add and remove cables , keeps shit nice and tidy
  6. Rezin
    Rezin Member
    Oct 27, 2002
    9,488
    Cable trays is another option. No zip ties, etc.. and especially not that twisty conduit that you linked to (which has always been a pain in the arse, for me, when trying to add or remove a cable from the bunch).
  7. looktall
    Sep 17, 2001
    24,376
  8. Anteros
    Anteros Member
    Oct 20, 2009
    697
    Penrith
    Velcro if it's going to be visible at all, or be worked on very often. Duct tape if setting up for someone else that I know won't touch anything until they upgrade in 7 years.
  9. scrantic
    scrantic Member
    Apr 8, 2002
    1,691
    3350
  10. SkyJoggeR
    SkyJoggeR Member
    Jan 25, 2013
    190
    +1 fir velcro, its great stuff all that other stuff is annoying to put on, annoying if you have to take a cable out or put one in Velcro is easy
  11. mike-s
    mike-s Member
    Dec 15, 2003
    1,867
    Sydney, Australia
    Agreed, Velcro all the way. I got that silver ducting stuff. But it is a pain to remove or add cables. Also there it a limit on how many cables can fit in that ducting.
  12. the3coopers
    the3coopers Member
    Jan 7, 2012
    1,681
    Sydney 2151
    Easiest thing BY FAR is to buy some large cup hooks, and screw them up under the desk. Then you have custom made cable trays that get it all up off the floor.
    I also mount power boards up under the desk as well, which makes things heaps neater. I install little shelves to hold UBS hubs, router, etc so absolutely everything is stealth.
    By doing that the only cables will generally be the incoming power and your network or modem cable.
    A great neatening opportunity is the rear of drawers. There is usually a 100mm or more behind the back of the drawers that is perfect for hiding all the power cables inside.
  13. Hood
    Hood Member
    Apr 12, 2008
    580
    Hoth
    My cabling was completely out of hand, so i brought two rack cable managers off ebay and boleted them to the back of the desk. also brought two 10 port power boards and ran them just below the cable managers. now its all up off the floor and looks very tidy
    http://wiretek.com.au/media/catalog...d08d6e5fb8d27136e95/c/a/cable_manager-1-1.jpg
    http://www.anyware.com.au/Marketing/ProductInfo/Images/LB_PDU10_10/LB_PDU10_101615553826761_L_.jpg
    gords edit: Do not hotlink pics you are not hosting yourself.
  14. Gnatty
    Gnatty Member
    Jul 15, 2010
    456
    How are you guys bundling up excess wire? Since my powerboard is right next to my desk, most of my power cables are waay too long.
  15. trackhappy
    trackhappy Member
    Dec 29, 2009
    2,359
    Caboolture, QLD, 4510
    Where did you get that power board?
  16. PabloEscobar
    PabloEscobar Member
    Jan 28, 2008
    12,738
    I hate people that use duct tape or electical tape to bundle cables. It doesn't last very long, Is impossible to expand, and leaves a shitty glue coating over everything.
  17. Hood
    Hood Member
    Apr 12, 2008
    580
    Hoth
  18. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    136,470
    Omicron Persei 8
    I use velcro and bulldog clips, seems to do the job.
  19. Davo1111
    Davo1111 Member
    Mar 5, 2009
    3,017
    If it's "permanent" cable ties. If it's not, bulldog clips.
  20. DeadLetter
    DeadLetter Member
    Oct 1, 2009
    260
    Velcro is god. I use it at work and at home on everything.
