Cable sleeving e-store does MDPC
Discussion in 'Modding' started by NinjaStickman, Dec 22, 2013.
  1. NinjaStickman
    NinjaStickman Member
    Jul 23, 2012
    284
    West Hobart, TAS
    Have spent the better part of an hour trying to find this:
    I found a site (probably from a post on here) that does custom sleeving. They do MDPC sleeving for a reasonable price (let you choose two colours I think) and they harp on and on about their 'signature "C" bend' of the sleeved cables.
    PLease please jog my memory haha
  2. BigDave
    BigDave Member
    Nov 12, 2007
    3,701
    ADELAIDE/5018
  3. Sven76
    Sven76 Member
    Aug 7, 2002
    1,386
    Bundaberg
    http://www.psychosleeve.com/
    he is the original one from MDPC i think. Its not hard to do but it is time consuming. I love the MDPC sleeve personally over other sleeves i have used.
    NinjaStickman
    Jul 23, 2012
    284
    West Hobart, TAS
    No, found this guy which is what reminded me of the store. Prices were about $250 (maybe) for a full 24, 8, 4x6+2, and maybe a sata or two - so pretty cheap.
    Woah bro! Dat price!
    I thought maybe until I say the price - think their store had a white theme.
  5. nyu
    nyu Member
    Oct 31, 2013
    30
    Does anyone know the sleeving material name?? I wanna buy the sleeving and DIY.. There's not that much to sleeving.. Just time consuming me thinks.
    There's a guy on YouTube - Singularity Computers, he talks about custom cables n stuff. He does a good job too. Not sure if he takes purely cables orders though.. He normally does custom cables for client PC builds.
    NinjaStickman
    Jul 23, 2012
    284
    West Hobart, TAS
    Lutro0s custom paracord is pretty cheap, I will probably go that rather than MDPC
    DIY job will work out to be ~$150 cheaper than ordered sleeving. .... at ~ 8hrs work (for a first timer), is my time worth $19 an hour? haha
    Sure it is :lol:
  7. harrye30
    harrye30 Member
    Apr 1, 2012
    247
    Never been a fan of MDPC sleeving really. I got fantastic results with paracord. Here's my first time attempt:
  8. Acesi7
    Acesi7 Member
    May 25, 2009
    2,149
    Mod-DIY do custom sleeving for a reasonable price. It's not MDPC sleeve, but it's very similar. They use the heatshrink-less crimping method.
    Lutro0's cables are great, Martin's (psychosleeve) is PERFECT, however outrageously expensive. Also, these are extensions.
    The Mod-DIY cables can be custom made for your specific PSU, so you don't have to hide the original cables.
    I've been using them for a while. Just easier, and I've custom MDPC sleeved around 10 PSU's so it's not that I can't do it. It's too time consuming when these guys deliver similar results for a reasonable price.
    You might need to fix a few cables though, but it's not too hard.
    NinjaStickman
    Jul 23, 2012
    284
    West Hobart, TAS
    Nice job harrye - looks sweet. Why the cable ties though?
    Bit dodgey for $300, I guess if you are a perfectionist though :p ... what is the turn-over time?
    Some of their show-case sets look pretty sweet!
    I'm fine with doing it myself - done a few testers, and I don't have dicks for fingers (all the time) so I should manage - however the SATA and Molex cables look nasty...
  10. harrye30
    harrye30 Member
    Apr 1, 2012
    247
    Ninja, the cable ties where there to give the cables a chance to *bunch* so to speak (so that they hold their shape once you remove the cable ties). I ended up using a whole heap whilst I got the cables in position then after a week cut them off and they stayed the same, even through transport too/from several LAN's.
    http://harrye30.imgur.com/all/
    Some picks of the finish build in their (ignore the car parts)
    That was my first major mod and I thoroughly enjoyed it. Sleeving was something I wanted to do, sometimes offer it for customers at the place I work. Never had a complaint either.
    Paracord has the advantage of being relatively cheap (extac is a good source in australia, or ebay for cheap stuff from china. Quality is not comparable in the inner weave. But the outer weave is the same - can take photos to show the difference). and comes in heaps of colours.
