Can I sit my boom box on my pc rig?
Discussion in 'Overclocking & Hardware' started by Crewcut, Mar 26, 2021.
  1. Crewcut
    Crewcut Member
    May 22, 2020
    255
    Hi all,
    my PC has bad sound and I've got an old Phillips Audio Cassette (from when my kids were little, buried deep in the garage and now resurrected just for this. It's an MC-M250/30 if that matters).
    I can sit the speakers each side of the table, but the Amp / Central unit would sit nicely under my table on the rig. Is there any electromagnetic stuff going on there that would mess stuff up, either the Audio or my PC rig?
  2. Copie
    Copie Member
    Jul 24, 2009
    14,546
    Newcastle
    Nah its all good. Send it.
    Crewcut likes this.
  3. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,152
    Omicron Persei 8
    I think it would be fine, can't see any issues arising. Give it a go and report back in a year : )
    Crewcut likes this.
  4. Myne_h
    Myne_h Member
    Feb 27, 2002
    11,442
    Em: no
    But very loud sound too close can vibrate your hdd.
    It's not likely to be too harmful, but just consider putting the speakers a bit further
  5. FerrisXB9R
    FerrisXB9R Member
    Jan 18, 2005
    3,259
    AB, CAN
    In the immortal words of little shits everywhere, its "ok boomer".
  6. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,152
    Omicron Persei 8
    Well maybe, if you're into big thumping bass that is.
  7. Jumpingmanjim
    Jumpingmanjim Member
    Sep 20, 2008
    638
    Have you seen the movie "Do the right thing" ?
  8. BLESSSED
    BLESSSED Member
    Mar 10, 2021
    34
    Orange nsw
    It might vibrate.
    Put a cardboard wedge and monitor it. It should sit marked.
  9. BLESSSED
    BLESSSED Member
    Mar 10, 2021
    34
    Orange nsw
    Some monitors are priced as the bass is worth it. My 5 inch subys for real on utube room decor also iv had them aux set up 2 years making games and rap songs. Every day I play my recorder 8oo songs and its all on 32gb $500 it cost. The other day there crawling on the cable a mouse in my room. Look up jbl monitor deals on belfield sites there's 8inch and larger defined your spending.
  10. JSmithDTV
    JSmithDTV Member
    Jun 13, 2018
    9,143
    Algol, Perseus
    This one?
    ... speakers would be magnetically shielded, so no issues, put them where you like.
    JSmith
  11. BLESSSED
    BLESSSED Member
    Mar 10, 2021
    34
    Orange nsw
    Nicely set. Don't mind the shield depends on use. Iv had no issues, but there worth it.
