capacitor Code, 2A154K, 224K ?
Discussion in 'Electronics & Electrics' started by Thraxeh, Sep 10, 2006.
  1. Thraxeh
    Thraxeh Member
    Nov 23, 2003
    4,345
    Sydney Australia NSW
    i just bought a pack of assorted capacitor's and i dont understand the coding.
    heres some examples
    2A154K
    224K(K is underlined)
    2A333J
    how do i work these out into uF or pF values ?
  2. Dr feelgood
    Dr feelgood Member
    May 24, 2005
    1,727
    Mornington peninsula
  3. LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,760
    Cambridge, Massachusetts
    The 3 digit number before the K or J is what you need to read. Capacitors (except for electrolytics) are rated in picofarads. The first two digits are the value and the third is the exponent, or power of ten (or number of zeroes). Therefore, a cap marked 224 is 22 x 10^4, or 220000pF, or 220nF, or 0.22uF - take off three zeroes to convert from pF to nF and take off another three to go from nF to uF. The letter denotes the tolerance
    Thraxeh
    Thraxeh Member
    Nov 23, 2003
    4,345
    Thraxeh
    Thraxeh Member
    Nov 23, 2003
    4,345
    what about the ones that say
    2A104J
    is that a 0.1uF cap ?
  6. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    Yes, that's correct.
  7. Dr feelgood
    Dr feelgood Member
    May 24, 2005
    1,727
    ignore the "2a" , the letter is the tolerance, so J means it is 5%, K means 10% and so on.
    Thraxeh
    Thraxeh Member
    Nov 23, 2003
    4,345
    awesome, thanks alot, i dont know what i'll do without OCAU :D
