Car Motion Simulator
Discussion in 'Modding Worklogs' started by powella, Mar 1, 2010.
  1. powella
    powella Member
    490
    Sydney, NSW
    Hi,
    Well it looks like I have a new project in the wings.
    The goal:
    Build a motion platform for the car racing games on the PC, with the Seat, pedals and wheel on the platform.
    The parameters:
    - Cost <$2.5K (excluding wheel, pedals and tools).
    - Must fit in a smallish room
    - must use existing PC for the main machine, but can extend to old laptop for motion control etc.
    The parts list:
    - 2 Linear actuators.
    - Some Square hollow steel for the frame
    - Some ball joints
    - 1 low slop Universal joint - for the main frame pivot
    - some bocca rod for bracing etc.
    - 1 Racing seat (To be sourced).
    - additional nuts, bots, zip-ties, and foam as required
    - some rubber mounts to stop the final assembly jumping around the floor
    The Tools list:
    - Screw drivers
    - Hack saw
    - Files
    - Cutoff saw (more power...)
    - Mig welder (to be sourced)
    So until the first lot of parts arrive, there aren't any photos... but if you have q's fire them off or just let me know you are interested in the build....
    Cheers,
    AP
  2. denyer86
    denyer86 Member
    May 19, 2009
    43
    Wow. This is going to be epic. Got any drawings on your designs or anything like that?
  3. hoopstar
    hoopstar Member
    2,278
    Adelaide..
    X-sim..??
    Hoops
    powella
    powella Member
    490
    Sydney, NSW
    yup....
    Rough (very) sketch:
    Cheers,
    AP
  5. Chewman_BG
    Chewman_BG Member
    May 12, 2009
    182
    Byron Bay, 2481
    making the thing is easy. getting it to interface with a game is hard.
    powella
    powella Member
    490
    Sydney, NSW
    Possibly.... I think it will be a little easier for R-factor, LFS, Simbin Games, and possibly... Dirt2.
    Cheers,
    AP
  7. AlastairT
    AlastairT Member
    Oct 28, 2009
    443
    This should be amazing.
    Looking forward to seeing how it goes =)
  8. millsy
    millsy Member
    Mar 31, 2007
    13,409
    Subscribed!
  9. SVD115
    SVD115 Member
    Sep 24, 2009
    874
    are you serious?! thats insane!
  10. domlebo
    domlebo Member
    Nov 13, 2004
    7,776
    I'd love to help with some plugins for rFactor. I have experience helping Leo Bodnar with his SLI-M projects. http://www.leobodnar.com/
  11. hoopstar
    hoopstar Member
    2,278
    Adelaide..
    There are already plugins for the major sims like rFactor to use with X-sim..
    All the hard work has actually been done for the end user and reports state that the end results are better than the Frex system.
  12. [/\V3NG3R]
    [/\V3NG3R] Member
    Jul 21, 2008
    385
    You're probably better off having two actuators at either side underneath the back end and a large ball joint mounted underneath closer to the front, with the actuators mounted on an outward slant so as to keep the CG low(stability). Something like this...
    You have to make sure all structures are made of a collection of triangles (i.e. no quadrilaterals) to ensure proper rigidity.
  13. candm
    candm Member
    Nov 16, 2004
    6
    Toowoomba QLD
  14. Cyren
    Cyren (Taking a Break)
    Jan 22, 2010
    9
    Subscribed.:thumbup:
    powella
    powella Member
    490
    Sydney, NSW
    As the actuators are somewhat limited in force capacity, I will be getting the structure as close to balanced as possible, that way the linear actuators only need to move the structure, not hold it up.
    On the strength side, agreed with the triangles, just gotta put them in the right places and away we go. The trade off with more material is more weight, which will be a performance killer.
    The electronics side has left for Aus at 3:22 am on March 01, 2010, so around 6-10 days and that side will be here.
    Cheers,
    AP
  16. terroristone
    terroristone Member
    Apr 16, 2006
    2,173
    Melb 3030
    subscribed!
    If your after any parts look in my blog and make an offer, i have everything except the wood frame.
    Regards Andrew
  17. [/\V3NG3R]
    [/\V3NG3R] Member
    Jul 21, 2008
    385
    Triangles will decrease the weight of the frames, as stresses on the beams will be that of a push/pull nature rather than a bending one. I'm no engineer, so this is probably the limit of what I can give you.
    powella
    powella Member
    490
    Sydney, NSW
    Apologies if the response offended, it wasn't meant to.
    FWIW your sketch is significantly more sound than mine!
    Agreed that the triangles are really strong, and that the beams are only strong in tension/compression. I just need to use any material sparingly, ie where the extra torsional rigidity is required is where the triangles will be! :)
    Also does anyone know of a good trade tools place around Hornsby. I think a 120 amp Mig and a cutoff saw are needed...
    Cheers,
    AP
  19. mojododo
    mojododo Member
    Feb 14, 2004
    3,478
    your not ek are you domlebo?
    looking forward to seeing this built mate!
  20. [/\V3NG3R]
    [/\V3NG3R] Member
    Jul 21, 2008
    385
    What, no...
    Just trying to be helpful, sorry if it came across the wrong way.
