[WORKLOG] CaseLabs STH10 Build - it is finished
Discussion in 'Extreme and Water Cooling' started by Mrfocal, Jan 31, 2015.
  1. Mrfocal
    Mrfocal (Banned or Deleted)
    Feb 21, 2013
    301
    Start of my new build is here and all the blocks have been fit.
    The Rampage V looks amazing with a mix of EK Water Blocks and Bitspower Blocks.
    The gpus have Aquacomputer blocks with EK backplates.
    Not sure what fittings I will be using as I am still waiting for the case which will be a Caselabs STH10.
    Here is the Parts list
    MB: ASUS RAMPAGE V EXTREME X99
    Case: Caselabs STH10
    CPU: Intel 5960x
    GPU: Quad R9 290s (place holders for the new 300 series)
    PSU: Corsair AX1500I
    RAM: 16gb G-Skill 3000MHZ (extra 16gb down the track)
    Watercooling
    Rad: 2 x XSPC RX480 Plus 2 x Alphacool NexXxoS XT45 Full Copper 560mm
    Pumps: 2 x D5
    Res: 2 x EK D5-X-RES
    CPU Block: Bitspower Summit
    Ram Blocks: EK-RAM Monarch X4 plus EK heat Spreaders
    GPU Blocks: Aqua-Computer kryographics
    Fitting: Primochill Ridged
    Here are some pictures for you guys.
  2. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,011
    Cheltenham VIC
    Subbed for focalgenius...
    Are you doing 2x loops, or 1 loop with 2 pumps?
    Mrfocal
    Feb 21, 2013
    301
    I am going to run 2 loops one for GPU's and one for the rest.
  4. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,265
    Nulkaba
    You inverting the m/b so you can see the xxx on the cards;)
    Mrfocal
    Feb 21, 2013
    301
    Narr its going normal way up I would of loved to do reserve maybe next build.
    I am still tring to pick fans at the moment.
  6. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,265
    Nulkaba
    To hide all that xxxx, its just sooooooo wronggggggggggggggggggg:(
    Mrfocal
    Feb 21, 2013
    301
    I know but Scorptech don't sell the reverse version and I didn't want to wait 3 months to get one from caselabs.
  8. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,265
    Nulkaba
    Velcro, blu tack, riverts;)
    Mrfocal
    Feb 21, 2013
    301
    Haha just turn the case upside down.
  10. deluxe
    deluxe Member
    Dec 9, 2003
    550
    Mrfocal
    Feb 21, 2013
    301
    Hey Everyone,
    I got a quick update for you guys, got both the Pump/Res Combo's installed and I really like how they look, I know there is alot of room to the right of them but there is a Reason for that which you will all find out soon.
    Both The X-res will end up the same size just waiting for one to come in.
    Thanks all.
  12. Flat-6
    Flat-6 Member
    May 1, 2014
    422
    Very sleek and nice...!
    Mrfocal
    Feb 21, 2013
    301
    Thanks very much mate
  14. kEv_
    kEv_ Member
    May 5, 2012
    522
    very nice, so clean with no cables and tubing!:thumbup:
    does the orange edge of the GPU's PCB shit you as much as mine shits me? LOL
    i wonder if i could paint the edges red or something...
    Mrfocal
    Feb 21, 2013
    301
    narr doesnt tomorrow me at all and I just got the cables so there will be an update soon.
  16. havabeer
    havabeer Member
    Dec 12, 2010
    4,325
    can i ask, is this build sponsered or are you just rich
    wish i could just slap 4x R90's in a build
    Mrfocal
    Feb 21, 2013
    301
    This is my personal build and the quad r9 290s are just in there till the r9 390x's come out.
    Mrfocal
    Feb 21, 2013
    301
    Check these out guys
    Here are the cables going into the caselabs.
    The made by CableMod and they look amazing and the best part is there not extensions there a full replacement kit.
    Now to put some combs on them and get them into the case.
    Let me know what you guys think.
  19. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,563
    Those are some tasty cables and that mobo/GPU setup is pure porn mate
    What's your plan for storage? With all those SATA ports you could get an epic SSD array happening... :thumbup:
    good stuff, keep it coming!
    Mrfocal
    Feb 21, 2013
    301
    Well I got 4 256gb EVO 840s here so I was thinking about using them or an m.2 drive.
