[WORKLOG] CaseLabs STH10 Build - it is finished
Discussion in 'Extreme and Water Cooling' started by Mrfocal, Jan 31, 2015.
  1. kEv_
    kEv_ Member
    May 5, 2012
    560
    those cables look good:thumbup:, can you tell me what they cost you?
    i am going to get a full set either for my AX1200 or a full set for a replacement PSU in a couple of months
    moddiy quoted me roughly 200pp(US??) for all but 2 of the PCIe cables for my AX
  2. DTG
    DTG Member
    Sep 16, 2002
    541
    Melbourne, Aust
    PCCG sell them for $120 a set.
    Mrfocal
    Mrfocal (Banned or Deleted)
    Feb 21, 2013
    301
    and then if you message cablemod (I can give you there email) they will send you any other cables you need, like I needed some more 6+2 pin PCIE as I am running 4 cards and he just sent them out to me.
    Mrfocal
    Feb 21, 2013
    301
    Ok guys need your help I can not fir the life of me work out what fan's I should use need 8 120s and 8 140s. If anyone can help with some advice on matching fans I will send you some cable combs.
  5. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,741
    Nulkaba
    Ill bite, is this a trick question ?, why you say, i say cause look at your sig DWPCM:eek:
  6. cheozuka
    cheozuka Member
    Oct 8, 2007
    389
    Cosair SP and HF matte.
    They will fit your build perfectly.
    Mrfocal
    Feb 21, 2013
    301
    I dont have a sig and just wonder what fans people would recommand that come in a matching 120 and 140 haha
    Mrfocal
    Feb 21, 2013
    301
    I didnt think AF quite editions where good for raditors.
  9. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,365
    Cheltenham VIC
    If you've robbed a bank recently, the Noctua redux fans are available in 120 and 140 :D I have 4 in push/pull on my front 280 rad :thumbup:
  10. _slacker_
    _slacker_ Member
    May 25, 2003
    1,240
    hiding from census dude!
    you want the SP not the AF. SP is static pressure and AF series are just case fans for free flow of air.
    Corsair do both 120 and 140mm fans you can match up im sure.:thumbup:
  11. kEv_
    kEv_ Member
    May 5, 2012
    560
    i used to have an AF140 quiet ed on my 140mm rad, cause at the time it was the only thing that matched, SP120's on other rad,
    it will still work, but just not as well,
    corsair do make SP140's now but LED's only, not with the rings:thumbdn:
  12. ac87
    ac87 Member
    May 29, 2009
    51
    The Sunburnt Country
    Subbed for pure awesomeness!!! Good luck with the build :thumbup:
    Mrfocal
    Feb 21, 2013
    301
    Yeah I just looked up the Red LED ones and they look really nice so looks like its SP120s and SP140s with red LED thanks guys.
  14. Modafroman
    Modafroman Member
    Jul 10, 2002
    10,057
    When my rig was in a 750D, my front 280mm was strapped with AF140s. They were rubbish. I went for Noctua A14s in the R5, and they're much better. I'd go Noctuas over the SPs, TBH. Unless you want aesthetics to match. Noctua have the Reduxes and Industrials in better colours, but eh.
    As for 120s, i'd still go for the Gentle Typhoon, or now EKs variant of it, FWIW.
  15. frizzl
    frizzl Member
    Aug 21, 2005
    1,081
    You said AF140's if that's the case, yes they are rubbish for a radiator... AF = AirFlow SP = Static Pressure.
    The SP120/140 aren't a bad rad fan, but certainly aren't the best either.
    I have used both Noctuas and Gentle Typhoons with far better results (currently running GT's :) - and MUCH quieter)
  16. Modafroman
    Modafroman Member
    Jul 10, 2002
    10,057
    Yea, AF140s, because that was what was in the case and I couldn't be bothered changing haha.
    I've now got a mix of 2xGT120s on the RX240, and 2xA14s on the SR280, downvolted and DC controlled via the Phanteks PWM Hub and a custom fancurve in Asus FanXpert. Works great, at idle, they're sitting there barely spinning, with decent idle temps (for summer), and then when CPU temp goes up they spin up to 100% :)
    Mrfocal
    Feb 21, 2013
    301
    I have used sp120 before and I can get them at a discounted price and I think they will match the build perfectly. I want performance but I also need them to match the build so the red LED will look great.
  18. havabeer
    havabeer Member
    Dec 12, 2010
    6,712
    the SP120's are good especially for the interchangeable rings that can be painted any color to match
    Mrfocal
    Feb 21, 2013
    301
    I will be using the LED ones they don't make SP140s with the rings
    Mrfocal
    Feb 21, 2013
    301
    Hey guys quick update.
    Here are the comb combs I had laser cut for the cablemod cables but they fit pretty much anything. Also the light box I had made for the bottom of the main section and did some brain storming of how I want the outside.
    What does everyone think.
