catching and resuming from sigsegv
Discussion in 'Programming & Software Development' started by MadOnion87, Oct 21, 2008.
  1. MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    Old Trafford, Manchester
    Hey all,
    I'm writing this massive system where we basically just gonna say "hey there's got to be some bugs remaining in the software when we deploy it". So now I'm trying to catch seg faults and then stop the thread responsible, destroy the objects and restart the thread. However it doesn't seem like its possible, the man pages of signal says its behaviour for multithreaded processes is undefined and sigaction didn't seem to work either. Have anyone tried this?
    I'm using linux btw.
    cheers
  2. Thunder
    Thunder Member
    Jul 22, 2001
    782
    It's not possible to do that, as far as I understand. If there is a SIGSEGV then your program is going to be terminated. you can't restart individual threads like that, It operates on a process level, not a thread level.
    What you can do is have another program which starts your main program via a fork() and exec(). Then have it do a waitpid() (wait until process termination). when your main program crashes waitpid() will return and you can just do another fork(),exec() and waitpid() again.
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    Thanks for the suggestion.
    I'm trying to get it to be as robust as possible that's why I wanna restart the thread and keep the program running. I've done a bit more googling and seems like its possible, but quite complicated. I have to fix the problem and let it resume. I tried doing a pthread_kill in the signal handler and it will infinite loop because it will jump back to the instruction that caused the segfault, strange because the thread shouldn't exist anymore.
  4. Thunder
    Thunder Member
    Jul 22, 2001
    782
    I believe it can be done ONLY if you can fix what caused the SIGSEGV in the signal handler, which is only useful in a very limited number of situations.
    Once the signal handler returns it will go back to where it was (the code that raised the SIGSEGV) and continue executing, when this happens the problem needs to have been fixed in the signal handler. Shooting the offending thread in the head does /NOT/ count as fixing what caused the problem.
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    The way we've structured it is that when the thread exits, all the memory goes with it. I've managed to get it to do what I wanted. So in the signal handler i set a flag indicating that the thread is dead then i do a longjmp back out to the parent thread. If the flag is set then I do pthread_cancel on it to kill it, reset the flag and reinitialise the memory (class) and restart the thread.
    thanks for your reply
    [edit] and yea I know that's not exactly fixing the problem, but at least we can keep the program going. And of course I will try all eliminate all the bugs if I can. [/edit]
  6. Thunder
    Thunder Member
    Jul 22, 2001
    782
    Interesting, I didn't even think it was possible. So it will restart the thread if you dereference NULL or scribble memory?
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    yep
    And to scale up to many threads, we just have a map marking which thread has died and which hasn't. We do the longjmp to that point where we check for dead threads. Also, re-enable the signal handler in the signal handler.
  8. Stinger
    Stinger Member
    Feb 15, 2002
    264
    haha that sounds so hackish :)
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    lol hey it works
    now our system can handle both exceptions and segfaults. Its for a system that controls a robot in a competition. We would rather it restarts the thread and (possibly) do funny things than for the whole system to just die and the robot falls to the ground and breaks.
    MadOnion87
    MadOnion87 Member
    Jul 10, 2002
    3,232
    lol, i would imagine that you want the robot to do more than just collapse and die though
