Catleap Q270 - 27" 2560*1440 IPS LED for ~$280
Discussion in 'Video Cards & Monitors' started by Tycn, Mar 14, 2012.
  1. kambo_rambo
    kambo_rambo Member
    Jun 30, 2008
    999
    Can you elaborate?
  2. zehoo
    zehoo Member
    May 19, 2002
    636
    I really should get around to doing this to mine.
    There is light leakage in some qnix screens, pulling it apart and using black electrical tape fixes most of the problem. Loosening the bezel can also reduce the bleed since some are screwed on too tight.
    http://www.overclock.net/t/1384767/...-monitor-club-qnix-x-star/0_100#post_19811603
    Listed as "Tape Mod to fix back light bleed".
  3. kambo_rambo
    kambo_rambo Member
    Jun 30, 2008
    999
    Ah thanks.
  4. Excess
    Excess Member
    Feb 27, 2010
    108
    Paid $70 for RMA to greensum, new monitor arrived < 1 week later. Only does 96hz compared to my old 120hz though ;(. New gen (since logo change) build quality has improved imo, little to no black light bleed compared to my first monitor.
  5. TripleJ85
    TripleJ85 Member
    Jun 20, 2006
    83
    Interesting that you mention there is a revision - Mine has the fancy logo too (only got it last week). I have no noticeable backlight bleed - so all good there.
    Why did you have to RMA? / how long did you have it before sending back?
    Have you noticed any difference in backlight PWM between revisions? I'm measuring ~150-160Hz PWM on mine, but others reckon they can't detect any PWM at all.
    Here are my tests - https://dl.dropboxusercontent.com/u/647589/QX2710LED PWM test.png
    I noticed my box says made in china - I wonder if the others ones are made in Korea?
    I definitely see some flicker on white backgrounds (unfortunatley).
    Other than that, it's great... I have it running at 82Hz (pixel clock limit of my DP-Dual DVI adapter - running on an HP8560W/Quadro2000m. It will do 120Hz fine on my desktop rig with a Quadro 5600.
  6. zehoo
    zehoo Member
    May 19, 2002
    636
    There's a new qnix screen using a 10bit AHVA panel listed as " 27" QNIX QX2710 Evolution II DP Multi True10 10bit".
    Seems to come in matte only and has multiple inputs so not sure on the input latency or how far it would overclock.
  7. Eradicate'
    Eradicate' Member
    Jul 25, 2009
    1,265
    Adel
    http://www.ebay.com.au/itm/Matte-27...980747?pt=AU_comp_monitor&hash=item23371508cb
    If they've switched to a BenQ panel they should've changed the model number away from QX2710, i imagine there will be quite a bit of difference between the PLS and AH-VA panels. Possibly the same panel used in the BenQ BL2710PT?
  8. Mordenkainen
    Mordenkainen Member
    Feb 16, 2004
    72
    Ulverstone Tasmania
    Going by what TFT Central and www.panelook.com show, the only two AHVA 27" 2560x1440 panels they list are 8-bit + Hi-FRC rather than true 10-bit:
    http://www.panelook.com/M270DAN01.0_AUO_27.0_LCM_overview_19766.html
    http://www.panelook.com/M270DAN01.1_AUO_27.0_LCM_overview_19767.html
    the former being a normal gamut panel and the latter a wide gamut panel both manufactured by AU Optronics Corp.
    TFT Central's panel database is here:
    http://www.tftcentral.co.uk/articles/monitor_panel_parts.htm
  9. Eradicate'
    Eradicate' Member
    Jul 25, 2009
    1,265
    Adel
    FWIW AU Optronics is owned by BenQ
    http://en.wikipedia.org/wiki/AU_Optronics
    And doesn't appear that these AHVA Panels will be overclockable being multi input
  10. Acesi7
    Acesi7 Member
    May 25, 2009
    2,148
    Sorry for the late reply. The thicker cable does nothing for frame skipping. This is happening in the panel not the cable. The thicker cable enables higher OC's stability wise. EG: coloured lines, black screen etc.
    This will NOT help get a higher OC that is skipping frames. Especially on a Multi-Input
  11. mick_champs
    mick_champs Member
    Sep 29, 2011
    874
    Seems i was one of the lucky ones and my Qnix QX2710 does 96hz and 120hz without frame skipping or any lines or artifacts etc.
    I've been running it on 96hz and I'm extremely happy.
    Ive been watching my GPU's and im confident ive got enough juice to run most games at a solid 120fps, or at least anything greater than 96hz, my framerate logging is sitting solid on 96fps so thast telling me it can do more....
    What i want to know is this:
    Does running the Qnix at 120hz cause it to 'burn out' quicker than running it at 96hz? I notice that the power adapter.brick already gets quite toasty....
    I want this one to last as long as possible because its the best possible result of buying one and don't want to have to roll the dice on one again to only get worse....
  12. zehoo
    zehoo Member
    May 19, 2002
    636
    On the specs claimed by one of the ebay sellers it can overclock to 120hz and it's default is 75hz. I'm almost tempted to be a guinea pig.
    http://www.accessorieswhole.com/images/011/QX2710_TRUE10_8.jpg
  13. Camm
    Camm Member
    Oct 1, 2010
    875
  14. SoulFire-Z
    SoulFire-Z Member
    Aug 28, 2001
    334
    Well, I received my QNIX QX2710 today and I am thoroughly impressed with this purchase. Have this display running at a comfortable 2560x1400 @ 96hz. With the cable holding me back from going any higher.
    Going to pickup a belkin cable tomorrow. 110hz works okay, but there is a green line here and there (no frame skipping on the web-based fps test).
    For $360 shipped to my door in 2 business days after I placed the order, can't go wrong!
  15. zehoo
    zehoo Member
    May 19, 2002
    636
  16. digitalnash
    digitalnash Member
    Nov 29, 2002
    12
    I got mine last Thursday, and using the cable supplied I can get 110Hz with no issues whatsoever. It runs 120Hz OK, but I get the occasional line, and 110Hz looks amazing anyway.
    And like holy shit, why the fuck did I not buy one of these earlier!? It's absolutely AMAZING. The lack of motion blur is just sexy. Games look incredible. Colours are fantastic, and viewing angle is impressive. Absolutely astounded by the quality of the screen, and especially for only $360 delivered to my door.
    I'll be buying a 2nd one of these as soon as I can afford an upgrade to my video card (only got a single 5870 so far). Which is also funny, because they said 5870's were not supported on the advertisement on ebay, but it's running like a dream right now.
  17. jayc
    jayc Member
    Aug 20, 2001
    1,156
    Congrats.
    And yep, should have bought it earlier.
    I've had mine for a year.
    The best thing is, you can go back and replay all the games you own in higher resolution. Well I did at least. Get your moneys worth from those games. :thumbup:
  18. Andres
    Andres Motor Admin
    Aug 30, 2004
    8,245
    These monitors are doing my head in...
    If I'm to push 2560x1440 with a laptop, it will likely be via Displayport or HDMI.
    If I don't want to purchase an active adapter, I need a monitor that will accept an HDMI or Displayport input. This generally comes at a premium of ~$70. (I.e. it's not realistic to find a 'pixel perfect', 27", 2560x1440 IPS monitor with more than just DVI-D for ~$360)
    Does this sound correct?
  19. TripleJ85
    TripleJ85 Member
    Jun 20, 2006
    83
    Except maybe the HDMI bit - Generally only DP will be able to push 2560x1440.
    I'm currently running a QNIX2710LED at 2560x1440 & 96hz through my laptop DP and an active DP-Dual link DVI adapter (this one) -> http://www.ebay.com/itm/231084623732
  20. xplod140
    xplod140 Member
    Jun 1, 2002
    4,665
    Melbun
    I posted a video some pages back now that shows a guy running HDMI to DVI cable and was able to push the correct res. Bit of fiddling but doable if you're keen.
