CH341A BIOS programmer - Need help
Discussion in 'Troubleshooting Help' started by TiMOiD, Jun 15, 2019 at 7:51 AM.
  1. TiMOiD
    TiMOiD Member
    Aug 7, 2002
    53
    Bundamba
    I bought a CH341A - its a USB2 3.3v/5.0v BIOS programmer with an 1.8v daughter board.
    Looks pretty much like this one:
    https://www.banggood.com/EEPROM-BIO...Adapter-For-24-25-Series-Flash-p-1332376.html
    I need to reprogram a board because the bios update failed and it does not have a rescue bios.
    The chip on this board is 1.8v according to the spec sheet, so I hook it all up and it tells me that it can't detect the chip.
    Thinking the actual IC is cooked, I order some new ones off ebay.
    Doesn't detect those either.
    I go back to the vendor saying that the 1.8v daughter board isn't working. My methodology: I tested a HD5870 BIOS on the 3.3v part and it worked perfectly.
    They send me another one: Same problem. Chip on the board doesn't detect, chips from ebay don't detect.
    Can anyone help me diagnose this? Is it 3 crook chips or two crook 1.8v daughter boards?
    I've done everything I can think of. Voltages are correct (theres a few online posts about them being screwwy).
  2. waltermitty
    waltermitty Member
    Feb 19, 2016
    937
    BRISBANE
  3. waltermitty
    waltermitty Member
    Feb 19, 2016
    937
    BRISBANE
    What are you using to flash? Flashrom? Run it in verbose mode and dump the output somewhere
    TiMOiD
    TiMOiD Member
    Aug 7, 2002
    53
    Bundamba
    I have multimetered out all of the SOIC clip pins they are OK.
    How do you mean "do you have everything wired up properly?"
    https://imgur.com/a/qPuib3I
  5. waltermitty
    waltermitty Member
    Feb 19, 2016
    937
    BRISBANE
    On the clip side, different chips have different pinouts, does your wiring match the spec sheet?
  6. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    2,163
    It works fine, the red signifies pin 1 for a traditional SOIC8 chip aka your 5870 SMD SOIC8 bios chip. If the clip is wired wrong then you need to rectify that.
    I used to use my CH340A programmer on a daily basis and have no problems getting it to work with SOIC8 or DIP8 vbios chips. The program becomes limited when you started .cap format motherboard bios flash which then you need a different CH341A compatible programmer that recognises .cap format.
  7. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    1,454
    Melbourne 3073
    Is your BIOS chip soldered on the motherboard? Then the USB may not have enough current to drive it. You might need to do dodgy stuff like powering the motherboard on first.
    TiMOiD
    TiMOiD Member
    Aug 7, 2002
    53
    Bundamba
    I removed the bios from the board, and also the new ebay ones are "loose"
  9. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    2,163
    You don’t need to power on the motherboard at all for the bios chip to be detected. Make sure the clamp head makes contact all 8 pins of the soic8 chip and is in the right orientation to pin 1 and 8, refer to the datasheet if unsure.
    If using dip8 use the usb adapter instead of the clamp heads.
    TiMOiD
    TiMOiD Member
    Aug 7, 2002
    53
    Bundamba
    if I run the base board in 3.3v mode (ie: no 1.8v adapter) i get FF as when I hit detect.
    When I load in the 1.8v adapter (connected to the bios chip or not, I get 00).
    TiMOiD
    TiMOiD Member
    Aug 7, 2002
    53
    Bundamba
    I'm using the clip, with the dot to the first pin -> the SOP8 adapter -> 1.8v adapter, then all of that into the main CH341 board.
  12. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    2,163
    Can you please post a picture of the chip and another picture of how you’ve connected everything.
    What ch341 programmer application you using?
    TiMOiD
    TiMOiD Member
    Aug 7, 2002
    53
    Bundamba
    TiMOiD
    TiMOiD Member
    Aug 7, 2002
    53
    Bundamba
    CH341A Programmer V1.34 (I have a bunch of versions but that appears to be the latest).
