Charging a LiFePO4 (with BMS) with Accucel 6
Discussion in 'Electronics & Electrics' started by JonasQuinn, Nov 5, 2018.
  1. JonasQuinn
    JonasQuinn Member
    Oct 17, 2005
    80
    Lane Cove, Sydney.
    Looking to purchase one of these batteries:
    https://evparts.com.au/evh12v12ah.html
    And the charger I have is an Accucel 6.
    The battery doesn't have balance leads, presumably because it has a battery management system built in.
    Am I able to charge the battery using the LiFe profile on the Accucel without balance leads?
    My experience with the Accucel has often been that you need balance leads connected in order to charge.
    Cheers!
  2. mtma
    mtma Member
    Aug 12, 2009
    4,675
    If your Accucel 6 is the same model as mine then there is a 'charge' option that can be used without connecting the balance lead. If you connect the balance lead when using this mode it will check for individual cell maximum voltages to ensure no single cell goes outside of the preset range, however it will not do any balancing. I think it's locked to 3.6V for LiFePO4 mode on the Accucel 6.
  3. Caffeine
    Caffeine Member
    Jul 1, 2003
    1,497
    My friends and i have 4 accucel 6 chargers between us. 2 of the older ones (mine included) will charge just fine without balance leads. The 2 newer ones refuse to charge without them.
  4. Privatteer
    Privatteer Member
    Mar 19, 2006
    769
    While it has "Over-Voltage, Under-Voltage and Over Current protection" it would be worth confirming it has actual cell balancing/individual cell voltage monitoring and not just at a pack level.
    I have pulled a few similar packs apart and found them to have one or 2 cells drained and the others over charged.
