charging AGM batteries?
Discussion in 'Electronics & Electrics' started by Dodge M4S, Oct 6, 2018.
  1. Dodge M4S
    Dodge M4S Member
    Jul 31, 2006
    3,243
    6061
    Hey guys, I'm putting together a portable boom box and am going to use a 12v 5.4ah AGM battery. I'm a bit confused as to what type of charger this thing needs.
    ive looked around and apparently I need a specific type of charger for it and they seem to range from $50 - $300...
    what would be the cheapest and safest way of charging it?
  2. slavewone
    slavewone Member
    Jul 9, 2002
    1,896
    B.Mtns2774 Status:Unhappy
    12v LEAD acid yeah?
    Do you have access to a car battery charger?
    Dodge M4S likes this.
  3. Privatteer
    Privatteer Member
    Mar 19, 2006
    796
    Anything that uses the float voltage of the AGM, usually 13.4V - 13.8V is safe.
    For faster charging some chargers will have a "boost" mode at around 14.4V then drop back to float when they detect the battery has reached full charge.
    Don't use the standard cheap car chargers they charge at around 17V which is way too high.
  4. MacroP
    MacroP Member
    1,304
    Bunbury WA
  5. Catweazle
    Catweazle Member
    Aug 12, 2003
    2,867
    Sale, Vic.
    That one would be ideal. Gotta be careful choosing one. Just the fact that it's about a 1 amp charger isn't enough. Quite a few of the lower end chargers aren't really suited to batteries of less than 10ah or 20ah capacity.
    Basically any charger promoted as being suitable for motorcycles should be fine, but always check the specs.
    Dodge M4S
    Dodge M4S Member
    Jul 31, 2006
    3,243
    6061
    Thanks guys :)
    This thing is getting a little expensive now, but the things we do to kill boredom lol
  7. Recharge
    Recharge Member
    Sep 5, 2001
    9,919
    when it comes to batteries, there is no cheap :/ try getting into hobby solar :p lol $$$$$$$$$$$$$$$
  8. Catweazle
    Catweazle Member
    Aug 12, 2003
    2,867
    Sale, Vic.
    Aldi currently have a charger that'd suit. About $30.
  9. v81
    v81 Member
    Jan 31, 2005
    652
    SE Vic
    For longer run time and better portability take a look at 4 cell LiFePo4 batteries and charger kits on E-Bay.
    You only have about 30Wh of usable power in that Lead acid battery.
