[WIN10] Cheapest legit way to get Win10 licence for new PC build
Discussion in 'Windows Operating Systems' started by MickybD, May 17, 2016.
  1. MickybD
    MickybD Member
    Jul 18, 2008
    591
    I'm looking to build my first new PC and my current PC only has an OEM Win7 licence, so I need to get myself a new Win10 Home licence. Just wondering where the forum can suggest I get a licence at the cheapest price. Should I buy Win10 from Amazon.com and ship it over, for example, or am I better to find somewhere to buy a legit Win7/Win8 key and get a free Win10 upgrade? Where is cheapest...?
  2. OldnBold
    OldnBold Member
    Oct 5, 2004
    4,261
    Sunshine Coast
    The upgrade to Windows 10 is still available. Through your own install, save your cash.
    MickybD
    MickybD Member
    Jul 18, 2008
    591
    Thanks for your comment. Reading back, though, I now realise my post wasn't clear. What I meant was that my current (old) PC has an OEM Win7 licence, so when I build the new PC I will need a new licence. I am entitled to a free Win10 upgrade on the old box, but as I will be building a new box I need a new licence.
    My research thus far has a retail Win8.1 licence at $109 - which I would then upgrade to Win10 for free - as the cheapest option. I'd be interested if anyone has any better suggestions though.
  4. samo
    samo Member
    Aug 20, 2007
    1,482
    student?
    if not, OEM or as you suggested. Win 8 to 10 upgrade.
  5. negatron
    negatron Member
    Jan 27, 2008
    1,298
    MickybD
    MickybD Member
    Jul 18, 2008
    591
    Not a student unfortunately. Looks like Win8 to 10 will be the way to go.
    Not sure about that. There seems to be mixed reviews about that sort of option.
  7. Slug69
    Slug69 Member
    Aug 28, 2002
    10,049
    Build your machine from scratch with win10 and call Microsoft to activate it if your old key doesn't work.
    Does your old machine have a removable network card put that in your machine as well.
    When I rebuilt my machine with some new components my autoactivation didn't work.
    Just follow their instructions on the phone. It worked for me.[emoji6]
  8. KaiShin
    KaiShin Member
    May 30, 2005
    60
    Will you be ditching the old PC?
    If so deregister Win7 from that one and reuse the Win7 key for your Win10 install, should work no problems. If that key doesn't register follow Slug69's advice.
    This is what I did, no problems at all.
  9. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,602
    Perth , St James
    Technically OEM keys are registered to the Mobo of your machine (and maybe a mix of other hardware) so when you change those parts your license is invalid.
    That being said there is a lot of leeway given by MS.
    I have used the same OEM key cross 3 Mobos now, as long as its been 1-2 years between upgrades the key will auto activate. Not sure how things will work with Win10 upgrades though as they don't technically have a key and are just registered to you Mobo.
    MickybD
    MickybD Member
    Jul 18, 2008
    591
    Thanks for the suggestions all.
  11. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,368
    Cheltenham VIC
    Also, check out Kinguin.
  12. decryption
    decryption Member
    2,878
    I've purchased a few Win 10 keys from that subreddit - all worked fine and keep working. Dunno where the fuck they come from or why they're so cheap. Anyone else know where these serials are coming from?
  13. josh1990
    josh1990 Member
    Mar 18, 2014
    1,556
    Albury, NSW
    Volume licence keys more than likely
  14. kogi
    kogi Member
    Jan 23, 2003
    5,002
    2031
  15. glenpinn
    glenpinn Member
    Dec 11, 2006
    6,573
    He can just use the Win 7 OEM key from the sticker on his old computer, he just has to do a custom install of Win 10 onto his new computer and use that key.
    Because he is doing a fresh install on a new Hdd and mobo, setup will detect that there is no current Win 7 or Win 8 activation already in place to validate the free Win 10 activation, so during the Win 10 installation, he gets a serial key screen, and he can just type in his Win 7 OEM key, finish the installation, and it will be activated.
    He does not need to buy any other keys, especially cheap keys from websites like the ones listed in this thread.
    Technically his old OEM key is supposed to stay with that old computer, but who cares, lots of people have been doing it, and if Microsoft don't have a system in place to prevent people from using them to get the free Win 10 activation, then that is their problem.
