children's shoes with lights how do they work?
Discussion in 'Electronics & Electrics' started by broccoli, Aug 6, 2017.
  1. broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    There was this little kid at the takeaway last night with lights on his shoes. When he walked, the three lights lit up in turn. I'd seen other kids with lights on their shoes. Can somebody briefly explain how those things work? Are there batteries in there?
  2. guy.incogneto
    guy.incogneto Member
    Nov 14, 2007
    4,578
    Pressure switch connected to flashing LEDs. Usually use button batteries.
    broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    Thanks. Where is the switch, and where does the battery go?
  4. rickbishop
    rickbishop Member
    5,489
    Petrie, QLD
    I'm pretty sure that the batteries are built in to the sole of the shoes, and they are not replaceable. Basically, when the batteries die, throw the shoes away and buy new ones.
    Just like many kids toys that talk or play music.
    broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    Or, just wear them as, you know, shoes..... :D
    So there's no battery compartment or anything that would be uncomfortable, it's all just in the rubber sole? Interesting, thanks. They were pretty neat shoes. :lol:
  6. ArmoureD
    ArmoureD Member
    Sep 12, 2002
    604
    Earth
    My son had a pair. They worked off a spring loaded switch mechanism. I.e vibrations make the circuit complete and the Leds light up. Batteries were built in and non replaceable.
    broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    The batteries probably last ages, I bet. How much power does a tiny little light use, and they aren't running constantly. With little kids they grow so fast, they'll probably grow out of a pair before the battery runs down anyway.
  8. merlin13
    merlin13 Member
    Apr 12, 2003
    1,532
    back in BrizVegas
    Same concept as those light-up balls you often see in the Charlie Cheapy shops - sealed unit, some sort of cheap motion/vibration/impact sensor, low power LEDs, throw away when the batteries go flat.
    Or dissect it as an organ donor to Frankenstein the innards to something else the kids can play with - grafted a few over the years into upgrading various toddler toys for the Squirts to muck around with...
  9. RP_Automotive
    RP_Automotive Member
    Apr 19, 2006
    192
    Some shoes have a little USB charger port on them as well.
    broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    Now I've heard of everything! Plug in shoes.... :D
  11. vk2fro
    vk2fro Member
    Feb 6, 2011
    230
    Erskineville
    Only thing that concerns me about the plug in type is the battery. Do you really want your little one running about, and jumping on top of a lithium cell? ;)
    broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    Why? Might it explode or something?
  13. vk2fro
    vk2fro Member
    Feb 6, 2011
    230
    Erskineville
    I've seen some gutted on you-tube - they have a small lipo inside and a charge controller. If the cell isn't protected properly from the normal abuse kids shoes get when running and playing, then yes, there is a possibility it could explode or catch fire. Not good when its in close proximity to a child's foot.
    broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    But if it's encased in rubber, isn't that sufficient protection?
  15. desertstalker
    desertstalker Member
    Feb 5, 2005
    378
    I would not be worried, there are a lot of these about and such a thing would be all over the news had it happened.
    The tiny cells are very unlikely to produce enough heat to cause problems, mostly they just get hot and swell up even if you charge them to 6+ volts
  16. Hive
    Hive Member
    Jul 8, 2010
    4,705
    ( ͡° ͜ʖ ͡°)
    Eh. Lots of current difference between a lithium coin cell and a lipo pack. One can catch fire under dead short the other just goes flat quickly.
    broccoli
    broccoli Member
    Feb 21, 2010
    17,004
    oh, well, thanks. I still think those shoes are cool. I've seen lots of different ones around and about, they draw the attention. They've also got ones with wheels in them, where the kids can skate around. I just wish they'd had those when I was a little kid, I would have loved them. :D
