Circular Polarising filter
Discussion in 'Photography & Video' started by sjaeger172004, Mar 21, 2014.
  1. sjaeger172004
    sjaeger172004 Member
    Sep 15, 2007
    1,006
    Um whats the difference between these and UV filters?
    As not sure whether to get a UV filter for my brand new Sony A3000 or a Circular Polarising filter or does a Circular Polarising filter do both?
    Thanks
  2. adamadam
    adamadam Member
    Sep 20, 2004
    1,390
    Circular polariser will polarise and will also cut more light than a uv filter.
    sjaeger172004
    Sep 15, 2007
    1,006
    so what would protect the lens more from cracking or being damaged from the sun etc?
  4. Taverner
    Taverner New Member
    Dec 25, 2011
    128
    A bag.
    For a serious answer, a UV filter is probably what you want. They're designed to block UV and protect the front element (and since your digital camera doesn't actually care too much about UV, it's mostly the latter).
  5. adamadam
    adamadam Member
    Sep 20, 2004
    1,390
    Probably the lens cap.
    Some people put on a uv filter for "protection".
    Circular polariser might cut too much light to leave on all the time... depending on what and how you shoot.
  6. Kurosaki
    Kurosaki Member
    Dec 8, 2005
    4,852
    Australia
  7. Alpha2k6
    Alpha2k6 Member
    Aug 30, 2006
    1,295
    Sweden
    Polarisers are used mostly for removing reflections but it can also enhance them.
    it can do either way depending how you turn the polarizer.
    Like a car photographed with a polariser you will see more through the car windows.
  8. Pinkeh
    Pinkeh Member
    Nov 1, 2008
    11,200
    UV filters are only needed if you have crap flying at your lens. CP filters are good for cutting glare/reflections. If you had to pick one, pick the CP filter and only use it when necessary.
    UV filters are kind of a waste of money. You're better off sticking a hood on your lens than relying on a flimsy bit of cheap glass to protect your lens.
