Cisco 1801 Help Internet
Discussion in 'Networking, Telephony & Internet' started by serverdude1982, Sep 8, 2012.
  1. serverdude1982
    serverdude1982 Member
    Dec 11, 2009
    11
    Hi guys how are you all.
    Guys i finally got back from a 2 month holiday and i have finally got my self a new modem which is a cisco 1801 problem I'm having is i cant get my inside network to get internet :S there must be something with nat or dns i have missed My ISP is telstra the modem is connected and from the modem i can ping google but I'm not sure what i have missed and was wanting to ask you guys what it could be ? Heres my running-config
    Current configuration : 1639 bytes
    version 12.4
    service timestamps debug datetime msec
    service timestamps log datetime msec
    no service password-encryption
    hostname Router
    boot-start-marker
    boot-end-marker
    no aaa new-model
    resource policy
    mmi polling-interval 60
    no mmi auto-configure
    no mmi pvc
    mmi snmp-timeout 180
    ip subnet-zero
    ip cef
    username admin privilege 15 password 0 ****
    interface FastEthernet0
    ip address 192.168.0.1 255.255.255.0
    ip nat inside
    ip virtual-reassembly
    ip tcp adjust-mss 1412
    duplex auto
    speed auto
    interface BRI0
    no ip address
    encapsulation hdlc
    shutdown
    interface FastEthernet1
    interface FastEthernet2
    interface FastEthernet3
    interface FastEthernet4
    interface FastEthernet5
    interface FastEthernet6
    interface FastEthernet7
    interface FastEthernet8
    interface ATM0
    no ip address
    no atm ilmi-keepalive
    dsl operating-mode auto
    interface ATM0.1 point-to-point
    pvc 8/35
    pppoe-client dial-pool-number 1
    interface Vlan1
    no ip address
    interface Dialer0
    ip address negotiated
    ip mtu 1452
    ip nat outside
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    ppp authentication chap callin
    ppp chap hostname *******@bigpond.com
    ppp chap password 0 *******
    ip classless
    ip route 0.0.0.0 0.0.0.0 Dialer0
    ip http server
    ip http authentication local
    no ip http secure-server
    ip nat inside source list 1 interface Dialer0 overload
    access-list 1 remark SDM_ACL Category=2
    access-list 1 permit 192.168.0.0 0.0.0.255
    dialer-list 1 protocol ip permit
    control-plane
    line con 0
    line aux 0
    line vty 0 4
    no scheduler allocate
    end
    :upset:
  2. Primüs
    Primüs Member
    Apr 1, 2003
    3,437
    CFS
    How are IP's assigned? If by DHCP, the config has no DHCP configured.
    Can you ping the router from the clients?
  3. caspian
    caspian Member
    Mar 11, 2002
    11,732
    no, your ISP is Bigpond, who are not Telstra.
    @Primüs - all Bigpond offer is DHCP. even their "static IP" is just sticky dynamic.
  4. Citiz3n
    Citiz3n Member
    Aug 3, 2007
    120
    I think he is referring to the LAN side. Also IPCP for PPPoE address negotiation is not DHCP :tongue:
  5. ics
    ics Member
    Jul 8, 2002
    209
    First thing I'd do, Assign your IP to vlan1 and setup ip nat inside on vlan1, I wouldn't use fastethernet0...
    T
    serverdude1982
    Dec 11, 2009
    11
    Thanks guys for the replys i got it working last night it was dns atm My server is handing out all the DHCP's only thing i have noticed is that this morning its been running really slow the internet that is and if i open up Cisco SDM and go to interface status the Dialer is at 100% say when i go to facebook youtube etc what might be doing this ?
    have to say though love this modem :)
  7. Primüs
    Primüs Member
    Apr 1, 2003
    3,437
    CFS
    Indeed I was!
    Are you torrenting? Aren't 1801's a bit underpowered so pumping through heaps of nat connections could use up it's RAM a bit (I know I had this problem on a Cisco 800 and moved to a consumer billion, which I can pump 500-600 connections through).
    Cisco's are nice, but to get the real high power and throughput its some decent $$
  8. caspian
    caspian Member
    Mar 11, 2002
    11,732
    given it's an ADSL connection with a maximum WAN bandwidth of 20Mbps, how much power do you seriously need?
  9. Primüs
    Primüs Member
    Apr 1, 2003
    3,437
    CFS
    To be honest, at first I was confused with a 1700 range, which falls over as soon as you give it 200 connections in the NAT table and 10~mbit.
    Since correcting my thought, the 1800 wouldn't be too bad, but still depends how many connections you want to push through it. My Cisco 800's couldn't handle 400~ connections, my consumer Billion 7800N handles 1000+ connections.
  10. caspian
    caspian Member
    Mar 11, 2002
    11,732
    *shrug* and my $90 Linksys handles everything I throw at it, although it tops out at 75Mbps throughput on my 100Mbps link. CBF upgrading it unless a Draytek falls from the sky at 1/4 price.
