Cleaning CPU?
Discussion in 'Newbie Lounge' started by chinkiwinki, May 4, 2005.
  1. chinkiwinki
    chinkiwinki Member
    Apr 14, 2005
    936
    How would you clean the old thermal paste off the CPU when your replacing the fan?
  2. im_soo_sxc
    im_soo_sxc Member
    Sep 21, 2004
    581
    Perth, WA
    Using a very strong alcohol like isopropyl, it's like 98% or 99% alcohol. Use that and a lint free cloth and that should do the job :thumbup:
  3. terrabyte
    terrabyte Member
    Oct 5, 2003
    3,066
    Syd, 2147, near Blacktown
    I use Isopropyl Alcohol (or however it's spelt), other people use metho, Nailpolish remover (provided it's not scented),
    Pretty much anything that has a really high alcohol content (~99%)
    chinkiwinki
    chinkiwinki Member
    Apr 14, 2005
    936
    Can i use Paint Thinner?
  5. terrabyte
    terrabyte Member
    Oct 5, 2003
    3,066
    It might work, but I wouldn't want to try it
  6. domlebo
    domlebo Member
    Nov 13, 2004
    7,776
    A good cloth to use, is those spectacles clothes u get when u get glasses. They are lint free and can wipe the past of really well.
  7. Alfonzo
    Alfonzo Member
    Apr 7, 2003
    13,163
    4152, Brisbane
    Second the Isopropyl. When I have none of that Metho works well.
  8. Midnight Rider
    Midnight Rider Member
    Dec 24, 2001
    1,248
    Newcastle
    I've always used turps and a tissue. Works a treat.
  9. Azsen
    Azsen Member
    Oct 15, 2004
    1,174
    It will leave a slight residue though because it's not pure alcohol. Might affect cooling performance when you re-apply the thermal paste maybe?
    $3 from a chemist anywhere should get you some Ispropyl alcohol. Mine is 100%. :)
  10. Grafton26
    Grafton26 Member
    Aug 8, 2004
    759
    Grafton NSW
    A nice clean bit of loo paper works well , I don't bother with anything else LOL
  11. FB008
    FB008 Member
    May 5, 2002
    9,185
    Uncanny Valley
    metho works for me, with a serviette. if its really stubborn i might pull out the turps... ive had no problems with it
  12. AlieN101
    AlieN101 Member
    Aug 3, 2004
    462
    LMFAO Grafton26 :lol:
  13. Andrew357
    Andrew357 Member
    Feb 23, 2003
    4,669
    metho and paper towelling
  14. anlashok
    anlashok Member
    Jan 19, 2003
    1,728
    Isopropyl Alcohol and a lint free cloth, could even use a cotton tip if you wanted.
    Its strong enough to dissolve thermal paste but safe enough not to cause harm to other componets like PCB, plus it will totally evaporate leaving no residue.
    I noticed DSE had some on there shelf the other day other than that your local hardware store should have some. (just remember you want the pure stuff)
  15. Knobi
    Knobi Member
    Mar 21, 2005
    2,383
    Eeede-laide
    hmm. i dont think its a good idea
  16. Enkidu
    Enkidu Member
    May 7, 2005
    11
    I got some 100% iso propyl alcohol from the paint thinner section at Mitre 10
  17. Ashendragon
    Ashendragon Member
    747
    For more info do a search, this has been asked a fair bit...
  18. petercr
    petercr Member
    Jan 4, 2002
    4,337
    Northern Brisvegas (4504)
    Combine the isopropyl alcohol and clean cloth and go to your local DSE/Jaycar and buy some isopropyl wipes.
    I haven't had to do it for a number of months but what I normally do is get some orange-based cleaning agent in a spray bottle, give the core a good spray as the AS5 (in my case) breaks up easier, wipe off with a clean cloth then rinse with isopropyl (to get rid of any oil residue from the orange cleaner) and dry using a hair dryer set on warm...
  19. Roman209
    Roman209 Member
    Jul 26, 2001
    2,337
    If i were you, i would only use iso proply stuff or nail polish remover.
  20. mcsacks
    mcsacks Member
    Feb 1, 2005
    499
    Just go to the chemist and get isopropyl alcohol or however its spelt.
    Works great and only cost like 2 bucks.
    I just use cotton tips to wipe of the Arctic Silver 5 then I clean the rest of with cotton tips and the alcohol.
    Gives me a brand new looking CPU which I admire and then cover it back in the grey shit that I am gonna wipe of again at a later date anyway...
