Cleaning dirt/dust from PCB
Discussion in 'Electronics & Electrics' started by DRAGONKZ, Dec 2, 2018.
  1. DRAGONKZ
    DRAGONKZ Member
    Jul 3, 2001
    1,803
    Bankstown, Sydney
    I’m just after some suggestions for DIY or a place in Sydney to help clean a server motherboard.
    It functions fine but is covered in thick dust, so could do with a good clean.
    Any suggestions on the best way to clean it, or a place to contact?
    Thanks
  2. [SweN]
    [SweN] Member
    Sep 2, 2002
    2,497
    fine, soft clean / new paintbrush, and a vacuum. personally i would also use compressed air, but if you are not familiar with using it you will make a huge mess, get shit in your nose and eyes, and potentially damage the component.
  3. power
    62,700
    Compressed air is a good start, antistatic brush as well.
  4. merlin13
    merlin13 Member
    Apr 12, 2003
    1,997
    back in BrizVegas
    Do not use one with synthetic bristles - find one with natural/animal ones, 'coz synthetic bristles can generate that evil shit called static. Not much, but have measured appreciable voltage levels on some 'way back when ,and encountered more than one instance of "Ooops, I Used This Cheap Brush To Clean This Board Cleaned The Board But It Doesn't Work Any More...".
    More expensive to buy but they last loooong time. And don;t use them for anything else. Wash out in hot water if/when they become clogged up with dust.
    My general knock-around one is a 1"/2.5 cm with the handle cut right down to let me get into awkward corners. I also use a 3"/75mm for cleaning out large flat areas (cases etc) and a skinny one about 1 cm with the bristles trimmed back to stiffen the action up.
    Be careful usually vacuum cleaners on electronics as well, you may need to be picky on yours. Seen lots of cleaners that generate shitloads of static electricity due to airflow in the pipe that can jump across to the board and really ruin your day...
  5. Myne_h
    Myne_h Member
    Feb 27, 2002
    10,491
    Take outside.
    Take vacuum cleaner outside.
    Switch hose on vacuum cleaner to the exit side (blow).
    From a decent distance, use vacuum to blow on board.
    DRAGONKZ
    DRAGONKZ Member
    Jul 3, 2001
    1,803
    Bankstown, Sydney
    Thanks for the replies.
    I’ll look at the WD40 product and get a decent brush.
    I’ve blown off the dust with with air and that’s got the loose stuff off, but the dust is caked on as well.
    If I run a section firmly with my finger all brown/thick/sticky dust comes off... the issue is that you need to use some muscles behind it to get it off (blowing/sucking alone won’t get it off)
    Cheers
  7. merlin13
    merlin13 Member
    Apr 12, 2003
    1,997
    back in BrizVegas
    Aaaaah, well.That then takes you to the next level, ie the "How Game Are You?" category, where you'd:
    a. take the board over to a large sink (or even into the bathtub/shower) and drown it in hot water 'n dishwashing liquid and give it a damned good scrubbing;
    b. submerge it in a large dish/tray/bucket of isopropryl alcohol for a good soak then scrub it off 'n rinse the hell out of it, either with more clean isopro or hot water. Be careful playing with isopro in a warm unventilated area, else you'll float out of there on the fumes.
    Either of these cleaning concepts scare the hell out of the Uninitiated... :leet:
  8. RobRoySyd
    RobRoySyd Member
    Jan 24, 2008
    8,151
    Isopropanol is definitely my go to solvent for cleaning PCBs. Nothing to really be afraid of using it apart from it being flammable. If you've ever been in hospital you know the smell of it. Adding 10% distilled water to it can make it more effective at cleaning. Applied Science has a great video on cleaning. In that you'll see why mixtures can work way better than a single solvent.
    Pugs likes this.
  9. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    2,622
    Don't use WD40 on the board, WD40 is a lubricator and will leave a oily film residue on the board, counterproductive of what you're doing and will not clean the board. WD Contact is the contact cleaner you want, part mixed solvent with IPA, cleaning solution for dirty electronics. Does not beat proper pure IPA though.
    If the board is caked in dust, use a fine brush to brush off the stuff first. I wouldn't even bother using contact cleaners on top of the board.
  10. power
    62,700
    watch the video i posted, it mentions that product.
  11. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    2,622
    Yep I have 4 cans of the bugger at home. It's alright but I generally use my IPA or Deoxit contact cleaners or similar ones by Chemtools.
  12. aXis
    aXis Member
    5,537
    Kalgoorlie, WA
    I have one of those battery powered "Canless Air" blowers (the O2 Hurricane), it does an awesome job of removing dust from components. That, and a soft brush is plenty.
  13. pfrcom
    pfrcom Member
    Aug 23, 2009
    349
    3114, Melbourne
    I use a shaving brush at $2-80 from a Daiso store, pig hair according to packaging
  14. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    32,158
    A Reported Post Near You
    Chemtools in Sydney have some specialised PCB-cleaning sprays, I seem to recall from the soldering course there.
  15. JSmithDTV
    JSmithDTV Member
    Jun 13, 2018
    6,620
    Algol, Perseus
    Do not use the one with any water in it on computer parts... you want the 99.9% pure stuff. ;)
    OP be really careful using a vacuum.. as others mentioned static can fry chips. Hold the nozzle well away from the board, keep yourself and the vac grounded as much as possible. Even the dust and dirt moving fast can generate static...
    JSmith
  16. Caffeine
    Caffeine Member
    Jul 1, 2003
    1,576
  17. merlin13
    merlin13 Member
    Apr 12, 2003
    1,997
    back in BrizVegas
    don't laugh, 'Caff. SMT assembly crowd I did some work for used to put EVERYTHING through a large dishwasher after the boards had been populated.
  18. Caffeine
    Caffeine Member
    Jul 1, 2003
    1,576
    Yes, i regularly wash PCBs after assembly.
    We don't do PCBs at work anymore but there used to be a large washing facility there too.
    Many PCB components such as buzzers and speakers have little self adhesive labels on them saying ’remove after washing', to stop water ingress.
  19. adamsleath
    adamsleath Member
    Oct 17, 2006
    17,482
    Sunnybank Q4109
    i have yet to try this but some people on youtube have used it...i mean ive seen vids of it being used. a bit expensive though.
    i use leaf blower, then a small craft paint brush with meths. i also use isopropyl aclohol. either. a wet brush isnt going to cause static.
    ive also seen people just use water. so long as it is totally dry and discharged.....but i wont do that.
  20. Technics
    Technics Member
    Apr 29, 2002
    2,013
    Brisbane, AU
    I prefer Trichloroethylene*. It's non-flammable, nothing cleans better and it's handy to have around as an anaesthetic for when you burn yourself with the soldering iron.
    *Note: Classified as carcinogenic to humans by freedom hating EPA liberals. Not to be used for post soldering pain relief. Professional Driver on a Closed Course: Do Not Attempt.
