Cleaning water loop
Discussion in 'Newbie Lounge' started by an93l, Dec 17, 2013.
  1. an93l
    an93l Member
    Mar 20, 2011
    95
    Hi there, I was cleaning one of my old systems and realise that the tubing is all white cannot see the water any more. Also the reservoir has some sort of stain on it that looks like sugar dried up and stuck on it and I cant get anything small enough to fit into the hole to clean it.
    What is this and how can I stop this on my new loop? I have purchased new tubing and cleaned the radiators (hopefully its good enough).
    I previously used distill water and liquid utopia.
  2. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,453
    ADL/SA The Monopoly State
    did you previously use older primochill tubing? if so, it's plasticiser and shouldn't be a problem with new stuff.
    an93l
    an93l Member
    Mar 20, 2011
    95
    Yes its a primochill tube as well as the utopia.
    I bought another primochill tube from pccasegear, so will this still happen?
    I cant even clean the reservior inside is all white powder stucked on it. Tried using hot water and soap and nothing happens, Im planning to get new reservior as well. Just hoping it wont happen again though.
  4. BigDave
    BigDave Member
    Nov 12, 2007
    3,701
    ADELAIDE/5018
    Try using some white vinegar and see if that helps, Don't leave it in the rads to long though.
    an93l
    an93l Member
    Mar 20, 2011
    95
    Is that mixed with water right?
    So your suggesting to do it on the new loop? I cant see whats inside the radiator but the Reservoir is definitely powdered up.
  6. Sven76
    Sven76 Member
    Aug 7, 2002
    1,386
    Bundaberg
    The plasticiser will be through the entire loop coating it. It may not make much difference apart from discoloration to the functionality of everything. I suggest opening your water blocks and seeing if they have gunked up as well. The deposits will be worse in channels where it narrows like the water blocks and rads.
    Seems the vinegar route is the best option as well. About a 10% solution of it in distilled water.
