cnc machine build 1.2x1.2m
Discussion in 'Hobby Engineering' started by Ch4iS, Feb 1, 2015.
  1. Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Another toy in the making.
    Thanks for looking :)
  2. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,612
    Nulkaba
    Looks nice & sturdy:thumbup:
  3. dazza00
    dazza00 Member
    Jul 19, 2003
    63
    Looks great.
    Is the 1200mm X 1200mm the cut area ?
    Are you working to a plan or custom build.
    Have you got a estimate on final cost.
    Trying to weigh up cost/time vs cheap China job.
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Thanks mad mic
    Dazza, it'll have a cutting area a bit over 1200x1200, custom build drawn in sketch-up as I go, don't mind sharing if anyone wants it.
    No total price worked out, but so far I'm $950 deep.
  5. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,612
    Nulkaba
    Hey Ch4is, i wouldnt mind a copy once its built, might build something at a latter date:thumbup:
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
  10. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,274
    lookin good! machine porn :leet:
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
  12. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,274
    lol love the prototyping bolts...
    what are you driving the steppers with? they look pretty hefty.
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Maybe some geckodrivers, not 100% sure I really wanted to keep the build cost under $2000 so might give some of these TB6600's a go and see how they run.
    http://www.hotmcu.com/tb6600-1-axis...ver-board-for-cnc-router-p-56.html?cPath=7_30
    The steppers are 387 oz-in 3.5A nema 24 stepper motors, a bit on the small size for a machine this big but I'm trying to keep costs down where possible.
  14. pippin88
    pippin88 Member
    Jul 26, 2001
    7,406
    Newcastle
    I'm loving Leadshine digital drivers. DM556 or 856 can be had on aliexpress for less than USD60 a driver, shipped.
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Decided to go with some geckos again, I'd probably regret it with the budget drivers, I did look at the leadshine drivers and they do look good but just having used the geckos previously I just can't fault them.
    Not much to show but tons of holes drilled and tapped, just waiting on some more T-slot nuts to put the Y axis slide together.
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Machined more bar stock to attach the X axis rack, was planning to use some extrusion but the bar stock worked pretty good on the Y axis.
    Cut the X axis end plate and pinion pulley reduction swivel motor plate:confused:
    Will look something like this
    Having never built a rack and pinion setup I've got no idea if I have enough force holding the pinion to the rack, but I very roughly worked out about 20-25kg upward force with dual springs more if I drill more holes or get some thicker wire springs, but the 2mm+ springs seem overkill.
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
  18. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,612
    Nulkaba
    looking sweet as:thumbup:
    Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
  20. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,612
    Nulkaba
    Looking sweet as, thats a whole lotta love gone into so far:thumbup::)
