[WORKLOG] [Complete] Brass pipe watercooling-Rocket Science fittings-Clear Perspex PC mATX case
Discussion in 'Extreme and Water Cooling' started by crocodaVe, Mar 20, 2014.
  1. crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Hi folks,
    Good challenge this one! :cool: Great to work with this case.
    Most of the plastic work has been done in this thread.
    Stripped it back to a lovely quad AMD.
    Parts are:
    MSI FM2-A75MA-E35 mATX
    A10-5800k APU
    16Gb (2x8) Ares 1600
    Asus HD 6970
    Odin 800w
    Samsung 120Gb Ssd
    1Tb WD Blue
    1Tb Seagate
    Asus Xonar DGX
    + more bits.
    WC:
    DangerDen DD-M6 Brass block.
    It's the heaviest block going around at half a kilo+. Built for LGA2011, but we can get around that :) and keep original mounts. MOAR Metal !
    Aqua GPU block & plate
    Heatkiller mosfet Block
    Rocket Science 1/2" fittings (silver)
    Koolance 120mm
    HW Labs SR-1 240mm
    XSPC Crossflow 240mm
    D5 Vario - Bay Reservoir
    BP silver angles & rotaries
    1/2" OD (12.7mm) Brass pipe (1.63mm wall thickness)
    SP-120's (x5)
    SP-140 (drive intake)
    I've been keen on this idea for years and thanks to Saate, we can make it happen.
    The 12.7mm (1/2") just saves so much mucking around. Opens a lot of doors for watercoolers. Copper pipe from any hardware. Brass is getting harder to get though :Pirate:
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
  3. Ratzz
    Ratzz Member
    Mar 13, 2013
    9,579
    Cheltenham East 3192
    I tried to order some fittings the other day but the website was gone? I want to do a hybrid build, copper for permanent fixtures and flexible tubing and valves for things like CPU and GPU's for easy servicing.
  4. Saate
    Saate Member
    Nov 15, 2011
    398
    Canberra, Australia
    Will look great, though! How are you planning to polish it all up, and just going the clearcoat route or will you clear plate it or something? Let me know when you're working on it so I can come round :)
    Website seems to be fine for me, but feel free to pm if you're having any trouble and will get you sorted :)
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Will use the Josco geen and white compound blocks & some brasso too. Just using an orbital sander and cloth pad.
    Still in two minds whether to clear coat the GPU plate and block top. Will definately coat the pipes as you did.
    Come over for sure, I'll let you know. :thumbup:
  6. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,223
    Cheltenham VIC
    Subbed for crocodaVe lunacy!
    There is no issues with brass in a WC loop - the zinc doesn't cause corrosion or discolouring or anything?
    Will brass be harder to work with as it is a harder metal?
  7. Dingostolemyghz
    Dingostolemyghz Member
    Mar 30, 2011
    778
    Nah will be fine, brass has a similar anodic index to copper. Most rads have brass end tanks.
  8. deluxe
    deluxe Member
    Dec 9, 2003
    596
    Hi Dave
    Couple of questions if i may-
    How heavy are the sections of brass tubing shown in your first post;
    and what is the thickness of the tubing walls?
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Seems easy enough Komm. I've done a 45 bend. 90 should be no trouble.
    I will be using angled fittings to help reduce bending pipe.
    Most commercial fittings and radiators are brass. Will be Ok.
    600mm lengths weigh 295 grams each.
    1/2" OD (12.7mm) - 1.63mm wall thickness. I went for the thicker as I was concerned about 'crimpled' bends. Glad I did because it's equal to the ID of the fittings (at the thread). Not that important -but a smoother flow.
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Komm,
    I'm considering using 5 grains of chlorine as a grub killer. Think public pools maybe?
    A well built loop though, has no grubs. destroy everything with alco spray - blocks, fittings, the lot. Then assemble immediately. Primo LU is an unknown rort I think and I used it once. $250/l detergent? Find the ingredients to LU Ocau? and let me know ? :rolleyes: Loop will be clear mate. Distilled.
  11. meremortal
    meremortal Member
    Mar 4, 2010
    1,668
    Benowa, Gold Coast
    Thankyou for using AMD
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
  14. Ratzz
    Ratzz Member
    Mar 13, 2013
    9,579
    Yeah mate it was working fine a few days after that post. I guess it was just off making whoopie with the boss when you got married :D
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Bending and cutting tools. I'm leaving 5mm overhang on each cut, then trim and round the edges later.
  17. pieceofchance
    pieceofchance Member
    Sep 28, 2011
    447
    Country VIC
    Ah so this is where it wound up... really need to pop my head in 'round these parts more often. Looking sweet Dave. Inspires me to get off my arse and get a build happening myself. :thumbup:
    crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    Much better cutter this one. $12
    semi fitted out. ends and edges need work. This is alot trickier than I first thought.
    Pretty much have to be spot on with angles and lengths. Unforgiving this tube.
    ][​IMG]
  19. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,985
    Lookin good! You should polish up a bit of off-cut so we can see how the tube will look :)
    Got a higher res version of that last image?
  20. Saate
    Saate Member
    Nov 15, 2011
    398
    Canberra, Australia
    Yeah dave, bring me a small offcut when you drop by so I can polish it up and post some pics :)
