CompuLab's upcoming releases: Trim Slice and fit-PC3
Discussion in 'Portable & Small Form Factor' started by stmok, Jan 27, 2011.
  1. stmok
    stmok Member
    Jul 24, 2001
    8,878
    First one is called Trim Slice
    => http://www.fit-pc.com/trimslice/
    The 2nd one is fit-PC3.
    => http://thetechjournal.com/electronics/computer/compulab-fit-pc3.xhtml
    => http://www.fit-pc.com/fit-pc3/
    AMD G-T56N => Embedded version of the AMD E-350 (Zacate)
    AMD G-T40N => Embedded version of the AMD C-50 (Ontario)
  2. Oblong Cheese
    Oblong Cheese Member
    Aug 31, 2001
    10,582
    As always they look pretty awesome spec-wise, but they're also quite ugly and will no doubt be extremely expensive.
