Computer will not power ON, I think it is toast.
Discussion in 'Troubleshooting Help' started by Multiplexer, Oct 9, 2020.
  1. Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,121
    Home
    Helping my wife cousin computer problem. The symptom is the computer will power ON for 1 second then off, no beep.
    1. I have tried another power supply and had the same issue.
    2. Remove memory and SSD and had the same issue
    3. There is no light on the motherboard that indicate power is fed. My understand is all motherboard make and model have light on the motherboard that indicate power is connected, I cannot see such light.
    I think the motherboard is dead and I would like a second opinion.
  2. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    2,214
    Melbourne 3073
    most motherboards do not have a light. Does the cpu fan spin up?
  3. philquad
    philquad Member
    Jan 22, 2004
    1,473
    nelson bay
    not all boards have lights
    before you can it, pull cmos battery out for 10 minutes
    try it again.
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,121
    Home
    I have pulled the battery out and will wait 10min
    The CPU and PSU fan spin for 1 second as well as case power light.
  5. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    2,214
    Melbourne 3073
    Could also be a short somewhere. Take everything out from case?
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,121
    Home
    Pull every possible cable out including the CPU fan, same symptom.
    Any more suggestion? Otherwise I am just going to declare it dead!
  7. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    631
    Lockdown, baby!
    * Replace CMOS battery, a flat one can do some crazy stuff;
    * Leave the CPU fan in, some boards won't start if there's no CPU fan detected;
    * One stick of RAM, CPU, no drives, see if you can get to BIOS.
  8. philquad
    philquad Member
    Jan 22, 2004
    1,473
    nelson bay
    thats it, you really wont know until you can try your cpu in another board, but it sounds likely its kuput
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,121
    Home
    I think I have troubleshoot enough. I have order a new CPU and Motherboard combination to replace the faulty one.
    The faulty part was low spec and not expensive so going to order todays equivalent.
    The cousin have left the computer unplugged from power and from my experience that is a dead sentence to electronic. All my remote tend to die if left with flat battery over an extensive period. Similar situation with a monitor.
  10. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    631
    Lockdown, baby!
    How old is the broken machine? Did you replace the battery? I've had 10 year old machines kick into life after being unplugged for years just by replacing it.
    Is the new combo compatible with the old RAM? Assuming you didn't order new RAM as your post didn't indicate it.
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,121
    Home
    No part was replaced. The cousin found the computer stop working after returning from a long trip.
    Is there motherboard that wont bootup when the battery is flat? I though a flat battery will only result in bios resetting to default, it should not prevent booting.
    My past experience when device without power for extensive time will cease to work, this happen to remote control and a monitor. I had 2 motherboard left in the garage for 2 years and 1 one of them stop working and the other one return error will booting but still load windows.
  12. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    631
    Lockdown, baby!
    I've had 2 Gigabyte boards go into boot loops, replaced the BIOS batteries and voila they came to life. What make and model is the board you're having issues with?
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,121
    Home
    No luck with change battery. Still failing. Not going to try anything else, going to replace with Ryzen.
  14. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    631
    Lockdown, baby!
    Oh well, worth a shot for the price of a battery. Did you get compatible RAM and a GPU?
  15. Groff
    Groff Member
    Jun 22, 2012
    222
    NSW
    What CPU and motherboard is it?
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,121
    Home
    The motherboard is a H270M-ITX, as for CPU it would be the same generation. The computer have been running the same components since day 1. No new parts was introduce.
    Feeling a bit guilty it have to go to the landfill.
  17. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    631
    Lockdown, baby!
    Consider looking for a used motherboard, CPUs rarely stop working and it may have some life left in it.
    Myne_h likes this.
  18. Groff
    Groff Member
    Jun 22, 2012
    222
    NSW
    It won't need to go to landfill.
    List it in the for sale section for $0 res and someone would take it.
    I would.
    pwlm1975 likes this.
  19. mareke
    mareke Member
    Jun 1, 2003
    7,701
    Sydney, NSW
  20. Groff
    Groff Member
    Jun 22, 2012
    222
    NSW
    Discontinued and won't be restocked.
