Confirm my parts will work together please.
Discussion in 'Newbie Lounge' started by Splat-725, Oct 25, 2011.
  1. Splat-725
    Splat-725 Member
    Jul 17, 2011
    31
    I didn't know where to post this, but I figured, as I am a newbie, I will post here.
    Okay, so I am building my first computer, I have selected all my parts, I just need confirmation they will all work together before buying them, and that I have everything I will need.
    It is for gaming.
    Internals:
    Intel i5 2500k
    G. Skill RipJaws (4x4gb) DDR3 @ 1333mh/z
    HIS Radeon HD6970 x2
    ASRock Z68 Extreme4 Gen3
    Corsair AX850
    Corsair H80 Cooler
    Storage:
    60 GB SSD
    2TB HDD
    Optical Drives:
    24x DVD Read/Write Drive
    12x Blue Ray Combo, BR Read/Write, DVD Read
    OS, Case and Monitor:
    Windows 7 professional x64
    Cooler Master HAF 922
    Samsung 120hz monitor
  2. breno
    breno Member
    May 3, 2011
    1,738
    Bring it over to my house and i'll test it for ya :p
    Looks like your good to go mate.
    Your first build is gona have 2x 6970s running in crossfire, brave man lol
  3. glasswindow
    glasswindow Member
    Jan 5, 2011
    31
    Yes that will all work however i would change.
    RAM - 1600 Mhz of the same type
    SSD - 120 gig - ( after a format and the OS install you dont get much room for other programs)
    Case - I am not really a fan of the HAF. For duel GPU cooling i prefer the Silverstone FT02 or Raven
    GPU - Apparently for a single monitor 1 GPU is better (less micro stutter), i haven't really looked into it.
    Splat-725
    Splat-725 Member
    Jul 17, 2011
    31
    @Breno
    Thanks for the offer, but I can test it myself, i'm not new at all to building, just to all the current parts.
    Can you tell me the problems I may come across running Dual 6970's and an alternative of around the same price?
    @Glass Window
    Thanks for your input, stuff being changed around now.
    I quite like the HAF, but I will definitely be having a look at your suggestions, the SSD was meant only for OS, I was unsure of what amount of space Windows 7 Would require.
  5. Madengineer
    Madengineer Member
    May 27, 2011
    14,420
    Think it uses about 25gb
    Splat-725
    Splat-725 Member
    Jul 17, 2011
    31
    Thanks mad engineer, I figure there's some way to configure it so all your stuff like App Data and everything else in Users, is saved to an alternate directory?
  7. Madengineer
    Madengineer Member
    May 27, 2011
    14,420
    I think your games/programs can be installed on a separate HDD, but not sure :D
  8. Reaper_1994
    Reaper_1994 Member
    Mar 24, 2010
    2,040
    Townsville, QLD
    imo go with a single 6970 instead of 2 and see if it can handle what you throw at it. I have found that people have had issues in terms of tearing or what Glasswindow said micro stutter. but don't make this think that that 2 580's are better.... :leet:
    Remember that if you overclock your CPU and GPU there is a little more headroom if you get a little lag in games. GTA IV @ stock 2.66GHz on CPU and 880 core and 1375 memory on GPU runs at 50-55 fps where as overclocked to 3GHz on CPU and 920 core and 1400 memory runs perfectly at a constant 60 fps :thumbup:
    In Windows 7, you can change Documents, Music, Pictures, and Videos to another drive/folder like I have using "Libraries" :D
    Splat-725
    Splat-725 Member
    Jul 17, 2011
    31
    That would be with v-sync on? if so turn it off and tell me what FPS you get?
    Also I am planning to be running the CPU at 4gh/z+
  10. Reaper_1994
    Reaper_1994 Member
    Mar 24, 2010
    2,040
    Townsville, QLD
    I'll have a look tomoz... going out shortly :thumbup:
  11. l3git
    l3git Member
    Feb 19, 2004
    375
    /home
    drop one of the 6970 and the 60GB ssd and buy 2 x 64 or 128GB crucials M4
