Connected to wifi but not able to load webpages?
Discussion in 'Networking, Telephony & Internet' started by Rezzix, Apr 20, 2015.
  1. Rezzix
    Rezzix Member
    Jun 18, 2014
    228
    Melbourne, Austraila
    G'day all,
    I'm after a big of help working out a problem with our home internet/wifi...
    For around 2 weeks now we have been having trouble with the wifi connection to our iPhones (the only devices that regularly connect via wifi). The connection will be strong but no webpages will load, it's like there is no traffic over the network... Sometimes switching from the 2.4ghz signal to the 5ghz helps, but that then stops sometimes also...
    The connection seems to be fine over a wired connection to the PC, though I think I have had atleast one occasion where it would not load web pages also, and I was unable to connect to my modem/router via its IP address. Our router is a TP- Link N600 8980.
    I've tried resetting the router to factory defaults and starting it up again, but have had no luck so far...
    Can anyone offer and solutions or tips on where to start troubleshooting? I've had no luck so far and Google doesn't seem to hit the exact problem I'm trying to solve.
    Cheers
  2. Tarkhein
    Tarkhein Member
    May 29, 2010
    276
    Have you reset the network settings on the iphone?
    Rezzix
    Rezzix Member
    Jun 18, 2014
    228
    G'day mate, thanks for the response.
    As in forgotten then rejoined the network, or is there another way to reset the network settings?
  4. power
    68,471
    Settings > General > Reset > Reset Network Settings.
    Rezzix
    Rezzix Member
    Jun 18, 2014
    228
    Thanks guys, I've reset the network settings but no luck, it did the same thing again approx 2 mins after the reset.
    Chrome comes up with a "This web page is not available" error, and tapas all failed to load this page.
  6. power
    68,471
    router might be on it's way out, be a good idea to factory reset it and set it back up - see if it works after that, wireless tends to go first on most consumer routers.
  7. drrevenge
    drrevenge Member
    Jun 14, 2004
    316
    I'd recommend updating the firmware on it (if not already to the latest levels) then doing a factory reset and re-setting it up.
    I'd also recommend to see if you can do a ping test from your iphone to say a computer set on the same network.
    (Something like this: http://www.ehow.com/how_5045546_ping-network-iphone.html )
    If, these things don't work, try your phones at some form of public wifi (Maccas, westfield, etc) and make sure it's nothing going on with your phone.
    If you're still having issues after all that, then yes, it may be time to look at a new/warranty replacement, modem/router.
  8. General_Cartman
    General_Cartman Member
    Apr 28, 2005
    2,749
    The Confedaracah!
    Could be DNS.... Can you connect to sites using their IP address instead of domain name?
