connecting a guitar to an XLR mic input
Discussion in 'Musicians' started by nudge, Jul 4, 2009.
  1. nudge
    nudge Member
    Sep 5, 2001
    860
    Amsterdam NL
    Hi guys,
    Quick question, I have a audio interface which has two inputs, a 1/4 inch instrument input and an XLR mic input. Is it possible to connect a second instrument (for example, a bass), into the XLR mic input? The actual device is a Line6 PODX3, which can process the two inputs simultaneously (usually instrument+vocal, but i would like to process instrument+instrument). Just wondering if the electrical interface of an Microphone XLR input is adequate for instrument in?
    Cheers!
    nudge
    nudge Member
    Sep 5, 2001
    860
    Amsterdam NL
    Ok.. just did a bit of research and answered my own question.
    What I need is a passive DI unit, which connects high impedance, line level, unbalanced output signal (instrument) to a low impedance mic level balanced input. Off to the shop I go :)
  3. Pugs
    Pugs Member
    Jan 20, 2008
    9,465
    Highbury, SA
    actives are better ether battery or via phantom power...
  4. ojk007
    ojk007 Member
    Oct 28, 2006
    1,273
    yep you want a DI.
    FWIW a berihnger active DI an be had for $90 these days, and they tend to get the job done pretty well. IMHO they're nice and transparent and worth the money if you want a DI, but by all means buy a better one if you have the money to spend.
  5. Comma
    Comma Member
    Mar 19, 2007
    3,682
    Almost all the local venues I play at use the Behringer DIs. Very solid.
  6. Willybomb
    Willybomb Member
    Aug 2, 2001
    6,346
    Ballarat
    I've got two Berry DIs, the Ultra-G and the Ultra-DI, both are pretty much bulletproof. The G in particular has seen a lot of gig and recording work.
    nudge
    nudge Member
    Sep 5, 2001
    860
    Amsterdam NL
    Thanks guys! just picked up a Behringer Ultra-DI DI20 for about 30eur, works a treat :) Cheers guys!
  8. ojk007
    ojk007 Member
    Oct 28, 2006
    1,273
    Good to hear. We have em at uni (SAE), alongside really expensive and top grade gear the cheap berry DI's hold up. As much as i give berry crap they make a decent DI.
  9. SquarkyD
    SquarkyD Member
    Dec 24, 2001
    3,509
    Get a nice bass with a hot output and you will instantly see where those extra dollars go. Also the bigger the PA the more you will notice a difference, hence why we ditched our Ultra DI's for a fleet of LA DI2's, tho the Ultra DI's did hold up to a flogging very well for the money. Still for my money the type 85's still sound amazing.
  10. Kurt
    Kurt Member
    802
    I've seen million dollar PA's with a drawer full of DI100s, they're the industry's dirty little secret I reckon ;) In my own system I like to use the GI100 on guitar amps whenever I can in preference to miking, no spill, predictable result.
  11. SquarkyD
    SquarkyD Member
    Dec 24, 2001
    3,509
    No doubt!! we had about 80 of them at one point! How do you use the GI100 on a gutiar amp? thru the line out with speaker emulation or something? Its a big call given just how much colour a speaker will give the sound of the amp.
  12. ojk007
    ojk007 Member
    Oct 28, 2006
    1,273
    yeah too right.
    They're like the sm58. They work. Nothing fancy, but they work. And they're cheap.
  13. Willybomb
    Willybomb Member
    Aug 2, 2001
    6,346
    Ballarat
    You connect the DI to the head's speaker out and use the GI100's 4x12 cab emulation button. The DI's xlr output will go to the PA, and the direct out from the DI continues to the cab.
  14. Kurt
    Kurt Member
    802
    Pads man ;) Either I'm cloth eared or bass for metal is too broodle, but I've used horribly expensive BSS and LA Audio DI's and couldn't tell what the fuss (or price) is about... Seriously, at 110db+ can anyone tell the difference between them?
    I usually run them in the fx loop or line out, or yeah, chained off the speaker output (40db pad ftw) The venue I work in is fairly small, the PA is usually only adding beef (quite a lot thereof) to the on stage sound rather than completely carrying it. Having said that I think the emulation is really good. Nice clean emulated signal beats "old speaker/hats/bass/kick" that the mic picks up most times ;)
  15. SquarkyD
    SquarkyD Member
    Dec 24, 2001
    3,509
    Well at 110db+ i wont be in the room to tell you :p Pads are just more things to put in the way of the signal, sure i use them all the time but i'd prefer to avoid them at the stage end. You will notice subtle things like a bottom end roll off on a 5-string bass, big dynamic handling etc, only if what you are hearing it thru is up to the task. Obviously i'm talking about in a studio or pro level touring PA's, nice DI's do have a place, but the cheapo's usually work just fine in small setups.
  16. Kurt
    Kurt Member
    802
    You've been to rock concerts right? 110 is pretty average... My little 5.5kw system can do it without breaking a sweat. The loudest gig I've done was measured at 114db at the desk and is by no means as loud as many big gigs I've been to.
  17. Comma
    Comma Member
    Mar 19, 2007
    3,682
    110 is fine. Since I have -30 from my earplugs :D
  18. SquarkyD
    SquarkyD Member
    Dec 24, 2001
    3,509
    Yeah, i've been system tech'ing 50+kw PA's in entertainment centres for a while now. 110db(a) at the desk is very loud, peaking at 105db is where i prefer to mix. If you were in 114db and didnt think it was loud, then your meter is probably running c weight, broken, inaccurate, or a mixture of all of the above. Some of the loudest shows i've endured were around 117-120db and punters were leaving because of the volume, i had plugs and muffs on, not ruining my hearing cause of some cowboy!
  19. olie
    olie Member
    May 22, 2002
    900
    Australia
    As above, minus system teching. 110db @ A is damn loud, but it also depends how far the system your desk is (Line Arrays aside that is.)
    @ C rating 120+ is often seen.
  20. Kurt
    Kurt Member
    802
    Dunno, wasn't my meter.... I know it was definitely the loudest mix I've done on my system. It was loud but not uncomfortably so I would guess 114A would be about right.
    If you're working at 105 you're still damaging your hearing with not a cowboy in sight....
