Connecting an Xbox360 to a monitor with DVI-d only
Discussion in 'Microsoft Consoles' started by samsino, Dec 18, 2007.
  1. samsino
    samsino Member
    Nov 11, 2007
    277
    Wollongong, NSW
    Hi, I was wondering how i would go about connecting an Xbox 360 to a Dell 24" monitor, the problem is the only input for the monitor is DVI-d.
    I've been reading around and apparently it can be done with an adapter. Someone said that this was $250 :Paranoid:
    I had an adapter lying around somewhere, and after of hours of searching finally found one, but it hardly looks like it's worth $250. So im wondering if it will still work. It looks like this:
  2. Deeman
    Deeman Vagrant.
    8,727
    That looks like the opposite of what you need. You want to go from a VGA cable to a DVI monitor, that goes from a DVI cable to a VGA monitor...
  3. TheKiller
    TheKiller Member
    Jul 1, 2004
    3
    If you have a HDMI 360, you could run the hdmi and end it with a hdmi > dvi connector.
  4. brendanseabrook
    brendanseabrook Member
    Oct 27, 2006
    63
    But then you loose sound
  5. Shaunbacca
    Shaunbacca Member
    Dec 5, 2007
    426
    That's why the official MS HDMI cable comes with an extra cable to use for traditional RCA or Optical hookups :)
    See Play-Asia for details
    samsino
    samsino Member
    Nov 11, 2007
    277
    Wollongong, NSW
    Thanks for the replies.
    I was just looking at the specs of the monitor, it has an analogue connection to.
    is analogue VGA? also, can i just connect speakers directly into my xbox360?
  7. almghty
    almghty Member
    1,172
    Thats what I was going to say?????
    The Dell 24" has analog, digital, component, composite ..take your pick.
    You were never going to get sound into this monitor. I'm told 360 has VGA analog so it should be doable.
    samsino
    samsino Member
    Nov 11, 2007
    277
    Wollongong, NSW
    but could i get sound into the xbox 360?
  9. SchRAMBO
    SchRAMBO Member
    Mar 27, 2002
    2,066
    The Xbox 360 Elite only supports HDMI 1.0 which only supports the video signal. HDMI 1.1 support is needed for both video and audio.
    umm unless your talking about a speaker headset for games then no.
