Connecting Haswell Retina MBP 15" to 3007WFP and 3008wfp
Discussion in 'Apple Desktop Hardware/Software' started by mr sti, Nov 14, 2013.
  1. mr sti
    mr sti Member
    Apr 6, 2004
    8,248
    I have a 15" retina haswell MBP and I would like to connect it to my dual monitor set up and not use the inbuilt LCD.
    What's the best way to do this? I saw that there is a display port to dual link DVI cable, but that would only be useful for one monitor and its expensive!
    Any other methods?
  2. Renza
    Renza Member
    Dec 1, 2004
    4,920
    only way is to get a mini-dp to dual link DVI cable as your monitors don't support displayport.
    The apple ones are expensive, but there are alternatives out there, but aren't much cheaper.
    mr sti
    mr sti Member
    Apr 6, 2004
    8,248
    Thanks Renza. Might have to do some cost analysis to see if it's worth buying the adaptors or selling the monitors and upgrading.
  4. Renza
    Renza Member
    Dec 1, 2004
    4,920
    haha the latest 30" dells will cost way more!
    mr sti
    mr sti Member
    Apr 6, 2004
    8,248
    That's true, but they are for work, so it's only a small amount extra to upgrade, providing dell does another 30% off sale ;) .
  6. Renza
    Renza Member
    Dec 1, 2004
    4,920
    Since the new rMBP has Thunderbolt 2 that supports DP1.2, you may be able to daisychain two U3014's together using the DP out port on one of them, meaning you'd only need to connect one cable for both monitors!
  7. Azrael
    Azrael Member
    9,059
    Cant you do DP>HDMI on monitor 1 and then native HDMI to the second? Thats what i was led to believe by a "Genius" the other day (of course he conveniently couldnt demonstrate it)
  8. [KEi]SoVeReIgN
    [KEi]SoVeReIgN Member
    Feb 20, 2002
    8,618
    He/She was right that's possible, but you're limited to 1920x1200 through HDMI. Need to use something else for OP's higher res monitors.
  9. ~Coxy
    ~Coxy Member
    Apr 1, 2002
    1,588
    Cannington, WA
    Am I missing something when you say that TB -> DL-DVI would only work for one monitor?
    The MBPR has 2x TB ports so if you buy 2x adaptors then you can drive 2x 30" monitors.
    Of course you still have to weigh up whether buying the adaptors is cost effective compared to selling the old screens and buying new ones with DP inputs.
  10. plasticbastard
    plasticbastard Member
    Jul 30, 2003
    4,004
    Sector ZZ9 Plural Z Alpha
    From apple.com.au/macbookpro specs page:
    Both Thunderbolt/DP outputs will drive a display resolution up to 2560 by 1600 pixels.
  11. [KEi]SoVeReIgN
    Feb 20, 2002
    8,618
    Cool I stand corrected - This must have been updated in the latest models, I could have sworn the previous gen couldn't do it.
  12. a_buzza
    a_buzza Member
    Jul 11, 2006
    380
    mr sti
    mr sti Member
    Apr 6, 2004
    8,248
  14. mrjayviper
    mrjayviper Member
    Jul 18, 2012
    460
    how about a matrox dualhead thingy. Using that for my MBPr.
