Cooking Terms, Tips and Measurements
Discussion in 'Geek Food' started by HoldenAngel, May 21, 2002.
  1. HoldenAngel
    HoldenAngel Member
    Jul 1, 2001
    256
    Toowoomba
    Cooking Terms
    I thought that with all of these recipes, there might be some terminology that you might not know about or want to know the meaning of. So I have compiled a quick list of cooking terms for you. Some of them are totally obvious but others might help.
    Al Dente: (AL-DEN-TAY) Refers to how pasta is cooked, it is slightly chewy or being tough to the bite.
    Au gratin: (OH-GRAH-TAHN) Foods covered with a sauce, sprinkled with cheese or bread crumbs, or both, and baked to a golden brown
    Au jus: (OH-JOO-I) Food served with its natural juice
    Bake: To cook by dry heat, usually in an oven.
    Baste: (BASED) To ladle drippings (the stuff that comes out of the meat when you cook it!) over a piece of meat being cooked as a roast to make it juicy and to prevent dryness
    Beat: To lift a mixture with a spoon or an electric mixer to inject air and make the mixture smooth and creamy
    Blanch: To scald, make white, to partially cook an item, or to dip vegetables in boiling water in preparation for freezing, canning, or drying
    Braise: To cook meat by searing in fat, then simmering in a covered dish in a small amount of liquid or to brown meat or vegetables in hot fat, then to cook slowly in a small amount of liquid
    Broil: To cook by exposing the food directly to the heat
    Caramelise: Sugar - to heat sugar until it melts and turns a pale brown colour. Onions/garlic: to cook onions in a small amount of oil or butter until they change to a brown colour (the sugars in the onions/garlic actualy turn to caramel). Done over an easy heat and stirred occassionally.
    Chop: To cut into small pieces using a knife or other sharp utensil
    Cream (as in butter and sugar): a baking technique involving combining butter or margarine and sugar together together to a fluffy consistency. Done by thoroughly beating butter in a bowl, then gradually adding sugar until mixture is fluffy and creamy.
    De-glaze: to pour a small amount of liquid into a hot pan in which something has been fried, to clean the pan bottom, especially as for gravy.
    Egg wash: brushing the top of a baked item, such as bread, lightly with a beaten egg.
    Flambe: (FLARM-BE) Served aflame
    Fold: (Nothing to do with computers this time!!)To mix, using a motion beginning vertically down through the mixture, continuing across the bottom of the bowl and ending with an upward and over movement
    Knead: (NEED) To place dough on a flat surface and work it, pressing down with your hands, then folding over and over again
    Pinch/dash: small, inexact amounts that basically add up to "to taste."
    Poach: To cook in water that bubbles only slightly
    Reduce: To concentrate a liquid by simmering for a long time
    Rise: in bread-making, to leave the dough in a warm place and allow to double in volume.
    Rest: in bread-making, to let the dough sit a few minutes before kneading more.
    Roux (Roo) - The basis of many sauces, and a good thickening agent for soup. Made but melting 1tbls of butter and adding 1 cup of flour and 1 cup of milk. For a thinner consistency, add more milk, for a thicker consistency, add more flour.
    Saute: (SAW-TAY) To quickly heat meat or vegetables in fat in an open pan
    Scald (as in milk): to heat milk just to the point that steam is rising from it, but not to boiling.
    Sear: to quickly brown the outside of meat at a high temperature.
    Simmer: To cook liquid just below the boiling point
    Whip: To beat rapidly to increase volume and incorporate air
    If you have any more, share the knowledge :D
    Edit: Thanks for the suggestion mark|. The words in Italics are how you pronunciate them. I will also update this post whenever a new term comes along.
  2. mark|
    mark| Member
    1,701
    you might want to add after each word how they're pronounced (pro-nun-see-aye-shon). Can't think of the term i'm after though
    Saute could be seen as 'sawt' or 'sss owa tee' or 'saw tee' or 'saw tay'
  3. PostModern
    PostModern Angry Brewer
    5,080
    Inner West Sydney
    Great thread. Thanks HoldenAngel. This will save having to explain each process/term within recipes.
    Another one:
  4. pax
    pax Member
    1,344
    God's Country
    yeah I got a bit of that myself... :p
    Nice link Chris
    Pax
  5. Tori Lee
    Tori Lee Member
    Mar 8, 2002
    1,464
    Top End 0830
    Because recipes can come from just about anywhere in the world, I'd like to post a list of customary (Imperial) units of measurement and their conversions...in case you're not familiar with them. :)
    Terms
    tsp = teaspoon
    tbsp = tablespoon
    c = cup
    oz = ounce
    fl oz = fluid ounce (liquid capacity)
    pt = pint
    qt = quart
    gal = gallon
    lb = pound
    Customary Meaurements
    3 tsp = 1 tbsp
    2 tbsp = 1 fl oz
    8 fl oz = 1 c
    2 c = 1 pt
    2 pt = 1 qt
    4 qt = 1 gal
    16 oz = 1 lb
    Metric Conversions
    1/8 tsp = 0.5 ml
    1/4 tsp = 1 ml
    1/2 tsp = 2 ml
    1 tsp = 5 ml
    1 tbsp = 15 ml
    1 fl oz = 30 ml
    1/4 c = 59 ml
    1/3 c = 79 ml
    1/2 c = 118 ml
    1 c = 225 ml
    1 pt = 450 ml
    1 qt = 900 ml (usually rounded up to 1 L)
    1 gal = 3636.8 ml (usually rounded up to 4 L...but personally I'd err on the side of caution here)
    1 oz = 28.3 g
    1 lb = 453.6 g
    Here is an awesome link to direct conversions online (contributed by PostModern in another thread)
  6. Tori Lee
    Tori Lee Member
    Mar 8, 2002
    1,464
    Top End 0830
    Common Cooking Substitutions
    If you're out of a particular ingredient, don't give up just yet. Check out this list of substitutions for various ingredients:
    If you need (You can use)
    1 c sugar (3/4 c honey)
    1 c brown sugar (1 c granulated sugar + 2 tbsp molasses)
    1 c powdered sugar (1 c granulated sugar + 1 tbsp cornstarch, blended)
    1 c shortening (1 c butter or margarine)
    1 tsp dry mustard (1 tbsp prepared mustard)
    1 tbsp prepared mustard (1/2 tsp dry mustard + 2 tsp vinegar)
    1 c cake flour (1 c minus 2 tbsp regular flour)
    1 c buttermilk (2/3 c plain yogurt + 1/3 c milk)
    1 c buttermilk (15 tbsp milk + 1 tbsp vinegar)
    1 tsp baking powder (1/4 tsp baking soda + 1/2 tsp cream of tartar)
    1/2 c wine (sweet) (1/2 c fruit juice)
    1/2 c wine (savory) (1/2 c chicken broth)
    1 c tomato sauce ( 3/4 c tomato paste + 1 c water)
    1 c sour cream (1 c plain yogurt)
    1 c orange juice (3 medium oranges)
    3 tbsp lemon juice (1 lemon)
    If there are any you don't see here, let me know and I'll add 'em in. :D
  7. MorphY
    MorphY Member
    Jan 21, 2002
    192
    Roux (Roo) - The basis of many sauces, and a good thicening agent for soup. Made but melting 1tbls of butter and adding 1 cup of flour and 1 cup of milk. For a thinner consistency, add more milk, for a thicker consistency, add more flour.
  8. Tori Lee
    Tori Lee Member
    Mar 8, 2002
    1,464
    Top End 0830
    Recipe Conversions
    Here's a quick-and-easy way to customize any recipe to yield a certain number of servings or feed a certain number of people:
    Step One: Divide the number of servings you want to make by the number of servings the recipe claims to make. The result will be your conversion factor.
    Step Two: Multiply the amount of every ingredient in that recipe by your conversion factor.
    For example: to make my Extraordinary Mashed Potatoes , which makes 10 servings, you need
    3 lbs (1.36 kg) potatoes
    1/2 lb (226.8 g) butter
    1-3/4 c (402 ml) milk
    To convert the recipe to yield a smaller amount, e.g. 5 servings, divide 5 (# of servings desired) by 10 (# of servings recipe makes), giving you a conversion factor of 0.5. Thus, your new ingredient amounts are as follows:
    Potatoes: 1.33 kg *0.5 = 0.665 kg (or 3 lb * 0.5 = 1.5 lb)
    Butter: 226.8 g * 0.5 = 113.4 g (or 1/2 lb * 0.5 = 1/4 lb)
    Milk: 402 ml * 0.5 = 201 ml (or 7/4 c * 0.5 = 14/16 or 7/8 c)
  9. egarrard
    egarrard Member
    Aug 22, 2001
    129
    Middle Tennessee, USA
    2 qt = 1 gal? I thought it was 4.
  10. Tori Lee
    Tori Lee Member
    Mar 8, 2002
    1,464
    Top End 0830
    Ooops...thanks for catching that, egarrard. :)
    Fixed it.
  11. eYe_kAnDy
    eYe_kAnDy Member
    Sep 14, 2002
    1,244
    Also al dente is when there is a white circle in the middle of your spaghetti
  12. suzie
    suzie Member
    Oct 5, 2002
    64
    Gold Coast
    Also when measuring liquids for recipes if you dont have a metric jug you can just weigh the liquid.
    1 litre of water = 1 kilo
    100mls = 100gms
    etc
  13. Midnight Rider
    Midnight Rider Member
    Dec 24, 2001
    1,248
    Newcastle
    A better description of "aldente" is.... "not too soft, not too hard, but just right."
    Also, Golden Syrup is an even better substitute for suger...because it is suger. Use it spoon for spoon.
  14. Kaell116
    Kaell116 (Banned or Deleted)
    Apr 7, 2002
    1,100
    In My Little Corner
    or whenever it sticks to the roof of ur kitchen (this tip actually works i got in trouble for it in high school :D
  15. cougar14
    cougar14 Member
    Oct 4, 2002
    77
    Eastern Suburbs, Melb
    Can I make a correction?
    The correct ingredients of Roux is as follows :
    1 part fat to 1 part flour.
    The fat can be in the form of Lard, oil, margerine or butter.
    Butter , however, is preferable, as it tastes a whole lot better in the Roux and therefore in the sauce/soup it would thicken.
    Not trying to start something, just hope it helps someone!
  16. MiGiSHu
    MiGiSHu Member
    Mar 1, 2002
    2,159
    Montreal, Canada ePenis Size: Whoppingly Large
    You have down that 3tsp = 1tbls
    Is that Australian or American? Because I think Australian mesurments are 4tsp = 1tbls
  17. sgn
    sgn Member
    Aug 2, 2001
    595
    sydney
    doesn't roux need to have Corn flour not just normal flour?
  18. Tori Lee
    Tori Lee Member
    Mar 8, 2002
    1,464
    Top End 0830
    Nope, it's regular white flour -- at least traditionally. :)
  19. kasi
    kasi Member
    Aug 20, 2001
    1,257
    Central Coast NSW
    There are some US measurements in Tori Lee's "Customary Measurements" and "Metric Conversions". Although they would be fine and helpful for American readers, in Australia be careful when measuring unless you are adjusting the amounts for an American recipe. Some English measurements such as the cup and the tablespoon are also different to Australia. These different Australian measurements (in particular the Australian tablespoon) are rarely mentioned in online converters.
    1 fluid oz (imperial) = 28ml, standard quoted as 30ml though
    1 pint (imperial) = 568ml, standard quoted as 600ml though
    1 quart (imperial) = 1136ml
    1 gal (imperial) = 4546ml usually quoted as 4.55litres
    And yes, Australian tablespoons are different to American or English ones because they are equal to 4 teaspoons not 3.
    4 tsp = 1 tbsp in Australia
    1 tablespoon (Australia) = 4 teaspoons = 20ml
    Also because a pint in Australia contains 20 fl oz, rather than 16 fl oz as in the US, 2 cups does not equal 1 pint. Finally, the English cup is 300ml/10fl oz, whereas the Australian cup is 250ml/8fl oz.
    The following link will explain the differences and may help anyone in Australia with any recipe that may have been handed down from generation to generation, but remains in imperial units, or with a recipe sourced from a US or English cookbook.
    www.ozevillage.com.au/gs/tips/gs.asp?topic=conversion
  20. Skit
    Skit Member
    May 27, 2002
    2,125
    freo.wa.au
