Coolant
Discussion in 'Extreme and Water Cooling' started by occxlr8ed, Jan 21, 2021.
  1. roony
    roony Member
    Jul 1, 2008
    106
    Been using distilled for the last 5 years, no issues. New build, reused WC parts for a temp loop. Tried EK mystic fog (concentrate) and it turned clear in about 3 weeks.
    occxlr8ed
    occxlr8ed Member
    Jan 2, 2007
    2,512
    Ended up with Corsair XL8 clear (stock issues), running great
  3. mixsetup
    mixsetup Member
    Dec 22, 2003
    2,990
    Cairns,QLD
    I just bought some EK Clear premix. Bought some others as well incase I decide to use them. I have used Mayhems Blitz kit to clean my loop then run distilled water after to clean out after I used Blood red, worked great.
  4. The Beast
    The Beast Member
    4,507
    I've used all sorts, here are my thoughts:
    Tap water: fine for short term use and testing. I still flush with distilled after testing just to get most of the minerals out.
    Distilled water: great for long term use, honestly I ran this stuff from Super Cheap Auto for two years and never had a problem.
    Pastels: Avoid. I ran a Mayhems blue pastel and some of my gear still has traces of it.
    EK Cryofuel (transperant!) pre-mix: Very good. I've run the Navy Blue for sometime now and not only doesn't it stain or clog components, but it stays so clear I've drained it rebuilt and re-used it.
  5. woja
    woja Member
    Feb 18, 2004
    559
    Sorry to jump on to this thread but approximately how much coolant you reckon I'd need with a eisfach dual bay res pump, a Xt45 triple 180mm rad and cpu and gpu block? And do most people go for concentrates or premix?
  6. roony
    roony Member
    Jul 1, 2008
    106
    I think the safer bet is to go with premix. Say the coolant goes bad, you can at least rule out the water you used for concentrate.
    woja likes this.
  7. mixsetup
    mixsetup Member
    Dec 22, 2003
    2,990
    Cairns,QLD
    I used EK Blood red cryofuel no problems with the PETG tubing for 2 years. Just building my new system and I have EK Blood red, Mystic Fog and clear. Was just going to see what looks best hope I don't get any residue in mine.
    woja likes this.
  8. mrjayviper
    mrjayviper Member
    Jul 18, 2012
    460
    I'm looking to use distilled water. Anything I need add?
    • Algecide? (Which one)
    • Silver coil? (Where do I put this? Inside reservoir?)
    Thanks
    Edit: I believe there's no aluminium in the loop. Just a mix of brass, copper and nickel plated copper.
  9. ging
    ging Member
    May 9, 2006
    154
    As stated above, I'd avoid any pastel coolant.
    Don't use a silver coil if you're running nickel plated components, they don't play well with each other.
    Instead, a biocide / growth inhibitor such as Mayhems Biocide Extreme or EK Cryofuel clear concentrate should be added to the distilled water to prevent any growth in the loop.
    I've been running EK Cryofuel Clear Concentrate mixed with Nulon Demineralised water for over 18 months with no issues (copper and nickel blocks, brass fittings, ZMT tubing), though jekel reported issues a few posts above, so maybe give Mayhems a try instead.
    Thorough clean of all components before filling is highly recommended to reduce chances of issues down the track.
    That includes new components (ZMT tubing can be pretty dirty from the factory, as are radiators which are usually filled with flux).
    An hour or two of prep can save you the hassle of breaking down the loop and cleaning out gunk stuck in the blocks.
    Good luck!
    mrjayviper likes this.
  10. Mordenkainen
    Mordenkainen Member
    Feb 16, 2004
    72
    Ulverstone Tasmania
    If there is nothing in the water or in the materials of the pipes/pump/res for algae to feed on then you won't get any growing in your system. It takes more than just light and water for it to grow.
  11. shane41
    shane41 Member
    Nov 10, 2008
    7,128
    dice que no sabe
  12. ashenIC
    ashenIC Member
    Sep 21, 2019
    82
    Demineralised water (by itself or) and engine coolant. Cycle your fluids periodically.
  13. juzz86
    juzz86 Member
    Nov 15, 2013
    1,924
    Forth, NW TAS
    Add this additive to store-bought Demineralised Water, and you'll get at least 12-months maintenance-free from my experience. Note it doesn't provide corrosion inhibition, so if you're mixing metals you may see some corrosion at fluid changeout. In my experience it took the plate off the inside of a CPU block, but it was a poor job initially anyway. Shane's table above is a good reference - the closer the values to each other the better.
    For corrosion inhibition as well, run with the automotive coolant at recommended dilution. Can last for ages, plus bonus colours. If you're after clear, you've generally got to go the PC-brand pre-mix stuff, most auto stuff is coloured.
