Cooler Master 840 ATCS Case Mod ..::D-9::..
Discussion in 'Modding' started by mnpctech, Oct 30, 2009.
  1. mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Hey gang, I've started the build for Cooler Master's media suite at 2010 CES. The D-9 concept was mine after seeing the movie.
    I should know by first week of November what hardware CM will be sending me.
    Conceptual drawing by E.E.L. Ambiense
    Our Project Sponsors!
    Case Mods & Supplies used in this project by Mnpctech.com
    Machined Aluminum Computer Case Feet Link
    Acoustical Sound Proofing Sheets for your PC
    Mnpctech is now stocking clear and colored sheets of cast acrylic for window mods
    http://www.mnpctech.com/colored_acrylic_sheet_casemod_window.html
    This is the Honeycomb Modders Mesh we used.
    PC Cable management clamps
    http://www.mnpctech.com/CableClamp.html
    The canvas for this PC build is the Cooler Master 840 ATCS
    Adding window to Cooler master 840 ATCS
    Using tape roll to make curved corner
    Make first initial cut with your Dremel and cutting wheel, to allow use of Jigsaw and cut the window more efficiently
    You have created slot, this allows using a Jigsaw w/ 18 TPI cutting blade
    Using a Jigsaw is much quicker than using a Dremel to cut your window
    Use a rounded side file to debur the jagged edges of the new window
    Notice the window location doesn't reveal the drive bays, this was intentional.
    "District 9" design cnc milled in the Cooler Master 840 aluminum intake plate. The recessed center portion will have CM case badge
  2. Micah.
    Micah. Member
    Apr 8, 2009
    232
    North Brisbane
    This one looks Like it is going to turn out like all your other ones Amazing :)
  3. flyingracoon72
    flyingracoon72 Member
    Aug 16, 2008
    209
    Looks like its going to be awesome :D
  4. CHemical.
    CHemical. New Member
    Mar 1, 2009
    660
    In a mushroom patch
    AWESOME!!!
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Thanks for the comments guy! I'm glad you like it!
    Upgrading the 840's stock 120mm exhaust fan to 140mm fan.
    Cooler Master 840 ATCS rear 120mm exhaust
    I'm holding up a 140mm Cooler Master fan over the stock 120mm grill. "Will it fit without anything obstructing it?"
    The location of the 140mm fan resides along the crease on the back plate.
    Making the initial cut with Rotary tool and reinforced cutting wheel before using Jigsaw
    Using Jigsaw with 18 TPI metal cutting blade
    Using rounded side hand file to clean up burrs along the edge of the cut.
    140mm opening is cleaned up, next is drilling mounting holes for 140mm fan
  6. zeropluszero
    zeropluszero Member
    Aug 6, 2008
    6,064
    Post only
    what an awesome idea.
    top movie btw!
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Cool, I liked the movie too! Now that we've got the 140mm hole finished, it's time to drill the 4, mounting holes for the fan.
    My trusty center punch. I use this to mark where the holes will be drilled. Once the fan is positioned correctly, It's spring loaded, you push down firmly until the pointed ends "pops" and create a dimple for the drill bit. I insert this in each of the fan's mounting holes
    The 140mm fan is located 7/8" from the top of the Motherboard tray.
    vibration dampening fan grommets
    Using a 1/4" size drill bit to make the mounting holes, this allows the fan grommets to fit.
    Vibration dampening fan grommets installed.
  8. brayway
    brayway Member
    Nov 29, 2008
    7,017
    New Zealand
    Looks great!! and i want to see that movie lol :thumbup::D
  9. elstado
    elstado Member
    Feb 10, 2009
    1,393
    NSW
    Looking ridiculously professional as always! :thumbup:
  10. CHemical.
    Mar 1, 2009
    660
    In a mushroom patch
    so much deatail for a fan hole! thats awesome!
  11. HM4A1
    HM4A1 Member
    Dec 1, 2008
    71
    Vic, Hoppers Crossing
    Really, really nice design and artwork. Cant wait to see the outcome. Eager to see how you get the dotted rust effect going.
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Thank you everbody!
    I've cut the window from Lexan. It's tougher than plexiglass/acrylic, but 2 or 3 times more expensive. It won't shatter or crack "easily" You can buy Lexan sheets at Home Depot, Lowes and some hardware stores like Ace.
    The window will be fastened with 1/4" socket head screws, for reinforced armour look
    Using center punch to mark each fastener hole.
    Roper Whitney No. 5 Jr Hand Punch kit available here
    Hand punch (estimate $60 new)
    "Look Ma, No deburring needed!"
    The benefit of using Lexan is that you can drill or hand punch it without cracking it.
    Clean hole cut! I love Lexan.
    Ironically our concept drawing calls for bullet holes in the Lexan "bullet proof" window...lol
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Cooler Master's hardware list for their CES show display
    1 x Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
    1 x Intel Extreme Series DX48BT2 X48 Motherboard
    1 x Silent Pro RS-600-AMBA-D3
    1 x CM MITX Cooler 38mm tall (will be replaced with future V series cooler)
    1 x Sapphire ATI Radeon 4870 512MB
    1 x 4GB DDR3 Kingston 1600mhz memory kit
    1 x WD 500GB HDD
    1 x DVD drive
    Silent Pro RS-600 Watt-AMBA-D3 PSU
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817171036
    Are you a fan of the Black Ribbon power cables?
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    The concept called for bullet holes in the window
    Using 3/8" drill bit
    Using wire cutter to make cracks around the hole
    Etching Rotary Tool (or Dremel) Engraving Bits
    Using the dremel to emulate some cracks
  15. Smoken
    Smoken Member
    Aug 27, 2001
    1,386
    Gold Coast
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    hehe, thanks! I'm adding bullet holes to the case too, so I drilled holes in the 840's aluminum panel. I then used a tin snip and needle nose plier to cut and rip the 3/8" hole open
  17. shadowkila
    shadowkila Member
    Aug 27, 2007
    34
    Pakenham, VIC
    woah?
    Wow mate, this looks insanely awesome really love the look of the bullet holes.
    Shadowkila.
  18. broox
    broox Member
    Apr 27, 2006
    3,597
    Ad'laide SA
    that is something that should have been a standard for years! no more sleeving :D
  19. BloodDonor
    BloodDonor Member
    Sep 3, 2001
    1,595
    Invercargill NZ
    nice work, cant wait til its finished
    ps, want me to send you a metric ruler? :p :lol: :D
  20. BigDave
    BigDave Member
    Nov 12, 2007
    3,700
    ADELAIDE/5018
    Awsome work as usual Bill.
    What you didn't use real bullets,:shock: I thought everyone in the united States had a gun :rolleyes: :lol:
