Cooler Master 840 ATCS Case Mod ..::D-9::..
Discussion in 'Modding' started by mnpctech, Oct 30, 2009.
  1. OP
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    is the Metric ruler anodized aluminum.. I love those :leet:
    lol, my shop is right in the heart of Minneapolis, I would have had a lot of explaining to do to the Police
    Thank you!
  2. ghostlyhunter11
    ghostlyhunter11 (Banned or Deleted)
    Aug 7, 2009
    61
    Looking forward to seeing more of this build.
    Excellent work. :thumbup:
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Good to see you all again!
    skipping ahead on this project since last update
    Once everything is assembled, all of the details like weathering, graphics, and effects can be airbrushed on the exterior like the concept drawing.
    Left side panel, the hole will have burned effect airbrushed on later
    Right side panel
    Cooler Master sent over 3x 230mm red led fans, 1x for front intake, 2x top exhaust
    The 840 normally comes with Black frame 230mm fans, no leds.
  4. jasonlka
    jasonlka Member
    Feb 14, 2008
    35
    Very nice paint job...
    white+orange....very nice.
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Thanks! It's been fun. I've had this .5" x 25" flexible conduit lying around, I've always wanted to use it for routing cables. It fits the industrial theme. I've also got .25" i.d. flexible conduit.
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Here is the Prawn canister from the movie.
    My canister will be lit with a 4" UV cold cathode, mounted on the inside wall of the back cover.
    Once it's painted and the window is darkened a bit, it should look eerie.
    canister back cover
    for canister window, I'm going to bend a piece of clear 1/8" thick case acrylic with a heat gun, but more on that later!
    http://www.mnpctech.com/acrylic_colored_sheets_casemod_windows1.html
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    I made the canister's window today. Using a heat gun to bend the Lexan.
    Forming the arc in window by pressing heated piece on the Aluminum rod. It's HOT!
  8. Concept CBF
    Concept CBF Member
    Nov 16, 2008
    2,220
    Behind you
    Sweet stuff man.
  9. humanrace
    humanrace Member
    Dec 12, 2009
    1,654
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Thank you! I will wire the cold cathode today and post pics
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    4" UV cold cathode.
    UV looks Blue in the photos
    The window will be painted to look murky, like the original canister
    The canister will be painted tommorow
  12. SilverSilence
    SilverSilence Member
    Oct 3, 2009
    1,960
    awesome work man :thumbup:
  13. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    Awesome job looks insane and very professional.:thumbup:
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Thank you! Orange Bezel with White intake plate installed. I cannot wait to grunge it up!
  15. brayway
    brayway Member
    Nov 29, 2008
    7,030
    New Zealand
    Looks awesome!
  16. Lil Flipp
    Lil Flipp Member
    Apr 28, 2009
    1,082
    awesome? Damn crazyyyyyyyy :thumbup::thumbup::thumbup:
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    Thanks guys, we should be painting the canister today. I will post the pics as soon as we're done
  18. F3L1X
    F3L1X Member
    Dec 23, 2008
    883
    brisbane, Queensland
    should've watercooled it and used the canister you made as the resevoir and used black coolant. Because in the moviet he canister has black liquid in it and it would've looked cool to have it as a resevoir with the black coolant
  19. Concept CBF
    Concept CBF Member
    Nov 16, 2008
    2,220
    Behind you
    This man is right.
    mnpctech
    mnpctech Member
    Mar 16, 2003
    877
    Minnesota
    I suggested it already to Cooler Master, They didn't want a water cooled PC :confused: btw: The canister isn't finished, it will look like the original once I'm done
    I chose the 1/4" socket head screws, these are fastened into the side panels
