Cooler Master and OCAU Contest!
Discussion in 'Overclocking & Hardware' started by Agg, Apr 2, 2013.
  1. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    32,549
    A Reported Post Near You
    Cooler Master have kindly offered a pile of prizes to hand out to OCAU members! There will be five prizes in total, being one each of the following:
    Scout II – Gaming Lan case with handle
    CM Storm Scout 2 N2 follows a more round futuristic theme and features improved steel reinforced carrying handles, bolted to the core structure. It supports up to 9 fans, including two pre-installed 120mm fans and two optional 120mm fans on the acrylic side panel window. The top console has been upgraded to USB 3.0 for high power charging and lightning fast file transfers, and can be hidden and protected from dusty battlefields, friendly fire and melee attacks behind a slide cover. The 1st HDD cage can now be removed, to support monster VGAs like the NVIDIA GTX 690 and AMD HD 7990, turning it into a powerful Battlestation.
    QuickfireTK – Full LED 92 keys mechanical keyboard.
    You're a gamer. You know that a mechanical keyboard means the difference between winning and losing. The original QuickFire Rapid gaming keyboard was embraced by gamers worldwide because it made the difference. Now the QuickFire TK takes the QuickFire Rapid and put it on steroids! Choose between 3 different Cherry MX switches. Each keycap is UV coated to make it durable. There's full LED backlighting with 3 modes and 5 brightness levels. NKRO over USB means every single keystroke will be registered. An embedded steel plate give you maximum stability and durability. 7 easy-access multimedia shortcut keys save time. A complete numpad lets you get work done while not gaming. The slim and lightweight size gives you plenty of room for your mouse. Great for LAN parties.
    Sirus - 5.1 True surround sound gaming headset
    Built for gaming enthusiasts and audiophiles alike, the CM Storm Sirus 5.1 Surround Sound Headset creates an immersive gaming experience with hi-fidelity sounds capes and intensified bass. Sirus produces precise and immaculate sound through its 8 discrete speaker channel pairs of front, rear, center, and sub; delivering accurate real-time 360 degree audio that is fully adjustable through its tactical mixing console. In addition, Sirus is coupled with a uni-directional microphone that minimizes background noise pickup enables crystal clear conversations with teammates and enemy combatants.
    Power RX – Dust/water proof mouse pad
    The CM Storm Power RX is a high-end hybrid mouse pad designed for hardcore gamers seeking ultimate precision. A low friction textured weave submerged into a thin layer of a special rubber compound that sits on a soft anti-slip silicon base that perfectly grips onto any surface. The Power RX gives you the best of both worlds: surgical precision, uniform tracking, and smooth gliding of hard mouse pads as well as a soft ergonomic surface that prevents wrist strain. The separate layers are fusion bonded for extreme durability. The rounded clamped down edge lining prevents mouse cords from rubbing against the Power RX and giving you drag.
    Recon – Ambidextrous gaming mouse
    The Recon Gaming Mice is designed specifically for gamers that demand the utmost in durability, functionality and accuracy. The ambidextrous form factor and rubberized coating making it a versatile for all types of grip gestures. Recon equipped with a pair of Omron Micro switches and Avago 3090 high precision optical sensor, allowing users to switch choice of 800, 1600, 3200, 4000 dpi on-the-fly as well as integrating 5 profiles and 36 macros to personalize the mouse at your own preference.
    HOW TO ENTER:
    Simply reply to this thread, answering the following questions from Cooler Master:
    1. How many DPI is our gaming mouse Recon?
    2. How many sound channel is our gaming headest Sirus?
    3. What color of mechanical switch do we offer for our mechanical keyboards.?
    4. How many colors do we have for our Scout II gaming case?
    5. Why should you be chosen as a winner? :)
    Entries close in two weeks time at 11:59pm Tuesday 16th April, Sydney time. One entry per person. I will choose winners according to my own mysterious criteria and announce them soon after closing, then you send me your details, I send them to CM and they post out your prize. Good luck!
  2. .spectre.
    .spectre. Member
    Apr 14, 2008
    62
    1. 800, 1600, 3200, 4000 dpi on-the-fly
    2. 8 channels
    3. Red / Blue / Brown
    4. 1 (Midnight Black)
    5. I shouldn't (and never am chosen).
  3. maev
    maev Member
    Mar 24, 2008
    1,424
    Mid-North Coast, 2428
    1. 800, 1600, 3200, 4000 dpi on the fly
    2. 8 channel
    3. Red, blue and brown
    4. 1: Midnight black
    5. Honestly, I'd love a new case. I bought the old CM Storm a while back to replace my old case, however the Power button shortly broke (is stuck in, spring broke?) and since then i have wired the reset switch to the power pins and use a bobby pin (or anything else thin and long) to turn the PC on/off. I also really liked the sentinel advanced mouse CM made a few years back (wicked easy macro interface - rapidfire CoD at lans was hilarious).
    Cheers for the comp. Always exciting and fun.
  4. Ultra PeePi
    Ultra PeePi Member
    Feb 14, 2002
    316
    2. 8 channels
    5. For my terrific ability to copy-paste the answers of previous replies.
  5. Rezin
    Rezin Member
    Oct 27, 2002
    9,490
    2. 8 channels
    5. For my terrific ability to copy-paste the answers of previous replies Because I did not copy-paste the answers of previous replies.
  6. Smakked
    Smakked Member
    Nov 28, 2007
    2,071
    Goldcoast
    2. 8 channels
    4. 1 Midnight Black
    5. CTRL + C and CTRL + V
  7. matty_0508
    matty_0508 Member
    Sep 7, 2007
    74
    2. 8 channels
    5. For my terrific ability to copy-paste the answers of previous replies. Because I did not copy-paste the answers of previous replies.
    Cause I never win anything no matter how original and different I try to be...
  8. Seravy
    Seravy Member
    Feb 10, 2010
    16
    2. 8 channels
    3. Brown, Red and Blue
    4. 1 - Midnight Black
    5. Your gear will be showcased at LAN's :)
  9. antenna
    antenna Member
    Feb 26, 2007
    530
    SA
    5. Because mspaint
  10. jimbow
    jimbow Member
    Jan 29, 2002
    672
    Perth 6163
    2. 8 channels
    5. Because my current mouse (Logitech MX1000) randomly decides to activate the middle button, and wildly stabbing in to the air does not go well with picking off targets with a sniper.
  11. |einad
    |einad Member
    Sep 13, 2001
    396
    2. 8 channels
    5. Because I could not get to sleep tonight so ended up on OCAU :weirdo:
  12. CREDO
    CREDO Member
    Feb 2, 2004
    750
    Perth, 6027
    2. 8 channels
    5. Because my good old Cm stacker doesn't fit under my new desk. and my mouse lead is too short.
  13. RoSWeLL
    RoSWeLL Member
    Oct 23, 2002
    1,664
    Hobart
    8 channels :eek:
    Brown, Red and Blue MX switches
    Just one in Midnight Black
    I'd love a new keyboard to let my cat sit on that instead of the one I'm trying to type on now :lol: but seriously I would use the CM instead and she can sit on this one
  14. joiji
    joiji magicu
    Feb 20, 2011
    334
    2. 8 channels
    5. Replace either my current headset which is now more packing tape than the original plastic, or finally get my hands on some delicious cherry keys.
  15. kathshan
    kathshan Member
    Apr 2, 2002
    223
    Medowie NSW 2318
    1. 800,1600,3200,4000 dpi
    2. 8 channel
    3. Cherry MX blue/brown/red
    4. Midnight black only
    5. I wont win because as usual i will just make up the numbers.
  16. krappo
    krappo Member
    Aug 25, 2008
    789
    Little Island
    2. 8 channels
    5. I am forever promoting Cooler Master gear to all my friends.
    great products
    :leet:
    many Thanks
  17. Chamelion
    Chamelion Member
    Dec 31, 2001
    11,114
    Strathpine, Brisbane.
    2. 8 channels
    5. Because I will sell the lot and give every last cent to my mum to help with her extremely expensive cancer treatment.
  18. joshpond
    joshpond Member
    Aug 3, 2011
    604
    Townsville
    2. 8 channels
    3. Red, Blue, Brown
    5. Because i eat ribs.
  19. Error-prone
    Error-prone Member
    Sep 30, 2008
    786
    Queensland
    2. 8 channels
    5. I'm really just hoping "mysterious criteria" means randomly chosen and how much we need it isn't taken into account.
  20. toopy28
    toopy28 Member
    Dec 30, 2002
    845
    Gammanville
    2. 8 channels
    5. Tralalalalala, trolololololool
