Cooling a Ryzen 5 5600X
Discussion in 'AMD x86 CPUs and chipsets' started by s8n, Aug 27, 2021.
  1. s8n
    s8n Member
    2,728
    Hi All
    Received a boxed CPU with OEM cooler but also ordered a bequiet! Dark Rock Pro TR4. Do I really need the Dark Rock? Will be going into a gaming PC, not sure i can be bothered to overclock it as it will provide what I need as it is. Will do some mining on it though, but i doubt this makes a difference
    If so,ill just return the Dark Rock
    Thanks!
  2. i_trin
    i_trin Member
    Jun 27, 2005
    286
    No need. Stock cooler fine
    s8n
    s8n Member
    2,728
    If i want to push the CPU a little, will the stock cooler do it? (4.4 to 4.5)
  4. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,343
    DARK ROCK PRO TR4 is for Threadripper socket sTRX4, not AM4.
    s8n
    s8n Member
    2,728
    Glad I know that now! thanks, i havent opened so ill return
  6. jjjc_93
    jjjc_93 Member
    Jul 3, 2009
    3,437
    The wraith stealth bundled with the 5600x is pretty crap, and loud. It's not like the heavier copper cooler that got bundled with the 3700x+. AMD's PBO will push the CPU for you so the cooler you can keep it the better it will perform (within reason) - Any good 120mm tower or 240mm aio is plenty and I would recommend the upgrade.
    miguel_sanchez likes this.
  7. i_trin
    i_trin Member
    Jun 27, 2005
    286
    I suppose the stock cooler isn’t great for overclocking. But there is no need to overclock the cpu in the first place.
  8. OCMunkee
    OCMunkee Member
    Jun 28, 2004
    1,736
    Melbourne, VIC
    I found the stock cooler a bit lacking if pushing power even slightly higher than stock. It'll manage, but the fan gets loud and load temperatures were higher than I was comfortable. I was using a Noctua L9A-AM4 and it did a bit better and quieter, but as a small form-factor cooler it wasn't great for OC. Using a second-hand 120mm AIO now which keeps it cool & quiet easily
