cooling attachment for external hdd case (just a small project)
Discussion in 'Modding' started by scarletxfi, Sep 10, 2007.
  1. scarletxfi
    scarletxfi Member
    Aug 12, 2007
    157
    I bought a couple of weeks ago this ext. hdd case (abit different you can see by the pictures), and i put a wd 320GB inside (this one in it).
    While backing up info I realized the the case gets pretty hot (especially in this country at summer). So i decided to improvise and make a cooling device...
    first i started off with a plate of painted fiber-glass (the person who painted it for me.. painted it with a .... tongue dispenser, that's why it looks so badly done)
    i got a couple 12 cm fans like these:
    next, i stuck the fans on the fiberglass and soldered a PL insert (for power) and a switch.. so this is what it looked like. I also stuck a bit of black sponge on the side that i stuck the fans (so that when i put the unit on the enclosure it won't bang it in anyway):
    I cleaned it up, and made it tidy, looks like this:
    next, i put some black sponge on top (making it more aesthetic and nice ) looks like this:
    connected, and running looks like this
    unfortunately i can't measure temp before and after, but i can say that if i touched the box it was pretty hot, and now it isn't hot at all.
    next step (when i get back to Australia) will be to solder the connections straight to the button of the enclosure ...
    anyway, beside that.. any thoughts?
  2. faceboy88
    faceboy88 Member
    Aug 8, 2005
    450
    Western Syd
    Wherever you put those images, doesn't like hotlinking. Imageshack them or something
    scarletxfi
    scarletxfi Member
    Aug 12, 2007
    157
    do the pics work proply now? (sorry about the resolution)
  4. predator666
    predator666 Member
    Jul 10, 2003
    195
    Brisbane, QLD
    yup..pics work.. That's pwetty :p although mind you the coolermaster kind of has the drive floating inside the case to allow ventilation, so is a bit better design IMO.
    scarletxfi
    scarletxfi Member
    Aug 12, 2007
    157
    Where i am now ...
    computer parts are a fortune.. so i have to improvise :)
  6. SyntheticNight
    SyntheticNight Member
    Sep 5, 2007
    665
    i have the black coolermaster externals for my two 400gb sata's - those things heat like a bitch! the only good way to have them is on their side - unless you have the room to separate them so you arent stacking like i do...
    i think you have a good idea...despite the not-so-prettiness. :cool:
    scarletxfi
    scarletxfi Member
    Aug 12, 2007
    157
    lol... thanks
    unfortunately those are the only materials i can get.
    I've got better and nicer idea which I'm making...
    and it does the job. People come over to my place and go "cool... what's that?!" so... all in all I'm happy with it.
  8. Pork_Roll
    Pork_Roll Member
    Feb 27, 2003
    733
    Boganville, Sydney
    where did you get the fans, im looking for those, they look low profile.
    Also, i cant tell from the photos how you managed to power the thing
  9. ZeroRaven
    ZeroRaven Member
    Sep 4, 2001
    258
    pork roll:
    looks like 120mm fans to me, thats why they appear low profile in the pictures.
    also looks like a multi adapter end hooked up onto the fan's wires, so maybe a hobby transformer of some sort.
    scarletxfi
    scarletxfi Member
    Aug 12, 2007
    157
    @ Pork_Roll , I can't really help you with the fans since I'm currently living oversees.
    what ZeroRaven said is correct. The fans are powered by a hobby transformer (12V 250 mAh)
    I assume you can get 12cm fans at any computer store. like Austin
    the fans are 120 mm
  11. TheLobb
    TheLobb (Banned or Deleted)
    Aug 21, 2007
    1,050
    2090/2063
    nice, my maxtor external hdd gets hot....i just keep it under a heap of 5 cent peices
    heatsink FTW
  12. Scotty1991
    Scotty1991 (Banned or Deleted)
    Apr 27, 2007
    1,527
    pics or bs :D
