Cooling for a gtx 275 gigabyte
Discussion in 'Newbie Lounge' started by Issac, Mar 18, 2010.
  1. Issac
    Issac Member
    Mar 18, 2010
    72
    Ballarat
    I've got a gigabyte gtx 275 gpu and it seems not matter what i do the temp seems to sit around 60-70 celsius and the automatic fan doesnt work with the nividia system moniter. When looking at the card it has its own heat sink and fan but is there any other options other then water cooling for the gpu? I've already got the maxium amount of fans in the case to increase air flow but can't think of much else to do :confused: any idea's would be great:)
  2. The Wiz
    The Wiz Member
    Jun 17, 2007
    44
    Perth, W.A.
    What version drivers are you using?
    Issac
    Issac Member
    Mar 18, 2010
    72
    Ballarat
  4. The Wiz
    The Wiz Member
    Jun 17, 2007
    44
    Perth, W.A.
    That's the driver that is causing fan issues. I haven't read up on it to much, but you should probably get a hold of the earlier driver and install that.
    Issac
    Issac Member
    Mar 18, 2010
    72
    Ballarat
    hmmm the problem is when i update the driver the card says its overclocked and resets all the moniters for the card to 0 and only displays temp so i stripped the driver to the earlest i found.
