CORSAIR Force SSD 40GB RAID 0 Hi-Speed test in dual PC platform
Discussion in 'Storage & Backup' started by windwithme, Sep 28, 2010.
  1. windwithme
    windwithme Member
    May 11, 2007
    863
    SSD full name is Solid-State Drive.
    It’s new booming hardware within 2 years. It really enhances the PC/NB transfer performance.
    The main reason is SSD using NAND Flash instead of diskette design.
    SSD normal capacity are 32/40/64/80/128GB. Recently, SSD market price is dropping a little bit.
    The main reasons for users to buy are transfer performance; seek speed, anti-shock ability and MTBF.
    Especially for NoteBook users, SSD is also lower power consumption and lighter.
    However, SSD price and capacity are still the key factors to impact the selling ramping speed.
    Related to SSD products, USA brand, CORSAIR, also put lots of efforts. They have 6 SSD product lines.
    Per performance, it divides into
    Force/Nova/Reactor/Performance/Extreme/Legacy series.
    This review is CSSD-F40GB2, belongs to Force series. It has 3 years warranty.
    CORSAIR F40 SSD position is similar to Intel X25-V 40GB. This review will focus on RAID0 in PC.
    First to check the packing, CORSAIR FORCE SERIES F40
    Product size is 2.5”, code is F40, and the highest performance is 280/270 MB/s.
    Random 4K writing performance is 50000 IOPS. 4K writing performance is the weakness of most SSD.
    Black metal shell and brushed finish surface look great.
    Official weight is 80g which is lighter than 2.5” HDD.
    The website showed the controller IC is SandForce SF-1222TA3-SBH.
    MLC NAND FLASH is Intel 29F32G08AAMDB, total 10 pieces 4 GB chip.
    The sticker above is warranty notice. The warranty will be invalid if it’s broken.
    SATA supports SATAII which is for PC or NB.
    This review uses desktop with different SB chipset to test RAID0 performance.
    I believe this combination is very popular now and using SSD for booting drive.
    And use big capacity 3.5” 7200rpm HDD for data drive.
    Desktop uses Intel platform, GIGABYTE X58A-UD5.
    SB is ICH10R, the most high end Intel chipset currently. I use it to test performance.
    Built-in USB 3.0 and SATA3, 2 latest MB technologies.
    Test Configuration
    CPU: Intel Core i7-930
    MB: GIGABYTE X58A-UD5
    DRAM: CORSAIR DOMINATOR-GTX3 DDR3-2400
    VGA: ATI Radeon HD 5830 CrossFire
    HD: CORSAIR CSSD-F40GB2 Raid0
    POWER: ANTEC HCG 620W
    Cooler: Mega Shadow Deluxe Edition
    OS: Windows7 Ultimate 64bit
    windwithme
    windwithme Member
    May 11, 2007
    863
    HD Tune Pro 4.60 Benchmark
    Read - Average 520.0 MB/s Access Time 0.085ms
    Write - Average 488.6 MB/s Access Time 0.017ms
    Random Access
    Extra tests
    Sequential middle
    Read - 522.673 MB/s
    Write - 528.175 MB/s
    Random seek 4KB 62779 IOPS
    File Benchmark
    ATTO DISK Benchmark 8k above transfer rate is 563.1 Mb/s at reading and 531.5 MB/s at writing.
    CORSAIR F40 in HD Tune Pro test also has very high performance.
    Both read/write are all over 500 MB/s which are very impressive transfer rate.
    The seek time is below 0.1ms and even achieve 0.017ms. This is also very outstanding.
    ATTO DISK Benchmark can also achieve over 560/530 MB/s, read/write performance. It really shortens the PC access time.
    EVEREST Read Test Suite - Linear Read(Middle) 527.0 MB/s.
    FDEBENCH gets the reading at 247.6 Mb/s and writing at 136.5 MB/s.
    CrystalDiskMark gets the reading at 308.0 Mb/s and writing at 89.52 MB/s.
    EVEREST Linear Read Average 526.2 MB/s
    AS SSD Benchmark
    Seq Read - 296.41 MB/s Write - 92.24 MB/s
    4K-64Thrd Read - 198.54 MB/s Write - 86.68 MB/s
    EVEREST Random Read 515.5 MB/s
    AS SSD Benchmark
    4K-64Thrd Read - 51293 iops Write - 20921 iops
    CrystalMark Sequential Read 521.37 MB/s Sequential Write 495.65 MB/s
    SiSoftware Sandra 481.72 MB/s
    EVERSET many items are over 500 MB/s.
    The others like CrystalMark、SiSoftware Sandra are also similar.
    The most surprise is some items of AS SSD Benchmark and FDEBENCH didn’t reach the highest performance.
    After repeating test and check the internet, I found it is caused by controller chip.
    SandForce SF-1222 in other SSD products is also having this issue.
    CrystalDiskMark 50/100/500/1000MB comparing test
    According to the different file size, you can see the improvement of CrystalDiskMar Seq performance.
    F40 high light point is having better transfer rate in smaller file. This is normal for high performance 4K file type SSD.
    IOMETER 2008
    4KB test - 100% Write 100%/Random 4KB
    Total I/Os per Second 68653.32
    4KB file IOPS writing performance is COSRAIR F40 strength.
    The test is not achieve double performance as Raid0. It’s also possible the limitation of SB.
    However, the benchmark is still over 68600. I will test with RAID card to compare this in the future.
  3. Hive
    Hive Member
    Jul 8, 2010
    5,088
    ( ͡° ͜ʖ ͡°)
    Allmost 100K IOPS writing 4KB.... that is fucking insane
    windwithme
    windwithme Member
    May 11, 2007
    863
    Another desktop PC test is in AMD platform.
    Using GIGABYTE 890FXA-UD5, the SB is SB850, the most hi-end AMD Chipset so far. It also supports SATA3.
    Supports ATI CrossFireX, On/Off Charge, USB 3.0 with 3X USB Power
    Test Configuration
    CPU: AMD Phenom II X6 1090T Black Edition
    MB: GIGABYTE 890FXA-UD5
    Cooler: Thermaltake V1AX
    ATTO DISK Benchmark 64k above test can achieve reading at 446.3 Mb/s and writing at 445.2 MB/s.
    EVEREST File Benchmark64k above test can achieve over 400 MB/s.
    EVEREST Linear Read Average 422.3 MB/s
    CrystalDiskMark reading at 240.9 Mb/s and writing at 106.6 MB/s.
    AMD Raid0 has no “Write-back cache” item, so the performance is lower.
    I hope AMD can add in this feature in Raid tool to enhance own chipset performance.
    Of course, if we also disable “Write back” in Intel platform, the performance will be similar.
    I also have some friends use SSD as NoteBook system drive and use 2.5” external HDD as data drive.
    For desktop users can have higher performance with SSD as building Raid0 by 2 pieces 40GB SSD. The performance will be much higher than single 80GB.
    However, the previous SSD version has lower performance issue after using for long time.
    The most new versions SSD all support TRIM to solve this issue, but it’s only for single drive now.
    Due to Matrix Storage Manager doesn’t support Raid0 TRIM instruction, the performance dropping issue is still exiting.
    The solution is clear SSD Raid0 mode and all data. Then re-build the Raid0 to recover the original performance.
    For Raid0 not support TRIM issue has none solution now. We only can expect Intel launches new Matrix Storage Manager to support it.
    Just can let Intel chipset with SSD Raid0 users to really enjoy Raid0 performance and worry free for performance dropping issue.
    Intel SSD product has very high level standard. The 4K writing performance is almost the best.
    CORSAIR F40 uses Intel 29F32G08AAMDB and new controller, SandForce SF-1222TA3-SBH.
    Except the high 4K writing performance, it also improves the overall performance of Intel NAND FLASH IC.
    Force series can be the new generation high performance SSD spec. It’s also the key factor to ramp up the SSD market share.
    CORSAIR Force series has 40/60/80/120/160/240GB.
    The users can buy by budget. More SSD capacity provides more flexibility.
    Force 40GB price is around 125US. Comparing to the other brands, the price is not too high.
    There are more and more controllers in the market. It also improves the performance. At least the different chipset has different strength.
    In the future, the price and capacity still impact the SSD coverage. I do want to see it happens soon.
    Recently, I got a DC - Canon IXUS 200IS, official from Taiwan disti.
    If I have time, I will make a preview. The content has outlook and experience sharing.
    Thanks for your time to read this SSD review by windwithme. :)
    This article is also posted in my blog: WIND'S 3C
    Welcome 3C fans to drop by.
  5. Audionut
    Audionut Member
    Mar 7, 2006
    995
    4610
    What stripe size did you use.
    I just got 2 x OCZ vertex II 60GB drives yesterday.
    I did some quick reading before installing, and the recommendation was to use a stripe size of 64.
    Here is what I am currently getting with Q6600 @ 3.2 on ICH10R.
    I'd love to get my 1-4K speeds a little higher.
  6. issa2006
    issa2006 Member
    Feb 4, 2006
    3,147
    AUSTRALIA (ADL)
    for ssd the lagest tripe size that yiu can do is recommende (ssd works dif than hdds) typ 128k
  7. MagyaR
    MagyaR Member
    Jan 15, 2004
    5,626
    Melb
    The F40 go for around $140, would it be overkill for a HTPC? I suppose quick boot up is a must if I want to watch TV, I have a secondary 1tb for the pvr and can have the swap file sitting there as well. Or I can get the OCZ Vertex 2 40gb for $145.
