Corsair HX520W modular PSU shows ultra reliability
Discussion in 'Overclocking & Hardware' started by windwithme, Nov 9, 2007.
  1. windwithme
    windwithme Member
    May 11, 2007
    894
    Corsair has been making PSU since the second half of 2006…
    They unveiled two appetizers to market, 520W and 620W PSU.
    The performance and product specification is really great.
    I knew some users take them to compare with Seasonic’s M12 series.
    No matter the spec and appearance, both of them have something in common.
    Hence, I analyze them by a comparison.
    Price is always significant to consume, so:
    Seasonic M12 about US$148
    Corsair HX520W about US$121
    If you are the users who care about quality,
    guarantee period and reasonable price, Corsair HX520W might be a better choice.
    The Corsair HX520W Modular Power Supply
    We take a look at the package first, it’s a bit bigger than some “same-level” product.
    The accessories from inside
    Multi-language users menu and power cords (not in the picture)
    Cables for power supplying
    Corsair HX520W itself
    The major heat dissipating system is the 12cm temperature-control fan.
    The RPM is low when light loading. If in a heavy loading situation, the noise is still acceptable.
    There is a cellular heat dissipating “holes” for a better heat-dissipation.
    It is a “auto-switch”, no need to put a 110/220v switch there.
    12V x 3, up to 54A, 480W
    That can support most of mid-range to entry-level high-end VGA,
    which under SLI/ Crossfire mode without problems
    A modularized sockets: 24/ 8/ 4pins
    CPU:INTEL Core 2 Extreme QX6800
    MB: DFI LANParty P35-T2R
    DRAM:CORSAIR Dominator TWIN2X2048-8888C4DF
    VGA:ELSA FALCOX HD260XT 256B3 HDT RH
    HD:Seagate 7200.10 320G
    POWER:Corsair HX520W Modular Power Supply
    Cooler:Thermaltake V1
    The settings under OS:
    CPU: 333X10=>3333Mhz
    DRAM: DDRII 1000 CL4 4-4-9
    VGA: 2X ELSA HD260XT
    The voltage of DFI P35 is a little low, that’s because the power consumption is keep on.
    OCCT is an useful testing software
    In the test, it can make all the cores in a full-loading status
    The variation of the CPU’s voltage is more related to motherboard’s design.
    The performance is good if the voltage can reach 1.3 to 1.34V while all cores is full loaded.
    3.3V: about 3.22 to 3.25V, the voltage “drop” about 1% only
    5V: about 4.76 to 4.81V, also, the voltage “drop” about 1% only
    12V: it sticks in 11.9V
    OCCT is mainly for testing the voltage (3.3/5/12V) variations of CPU and RAM while under OS full-loaded.
    For some minimal error of mobos or high-end VGA cards, it is not for it.
    The PSU works fine with quad-core CPU and 2600XT CrossFire in a OC situation.
    In the test,
    The RPM of the fan is not high and the working temperature is acceptable too(around 40C) includes all the merits I introduced,
    this PSU shows a high C/P ratio.
    The coming up review of mine is the most popular Elsa 8800GT 512MB VGA card.
    Then, I’ll use Corsair HX520W PSU again!!
  2. snivlac
    snivlac Member
    Aug 2, 2007
    302
    Yep, my hx620w has been great to me, very quiet even under load, they were made by seasonic btw.
  3. WooKiE_MaN
    WooKiE_MaN Member
    May 3, 2006
    3,015
    Craigieburn
    hx620w +1
    dam awsome PSU's so quiet and so powerfull..:D
    10/10 for hx620w
  4. Bosk
    Bosk Member
    Jul 22, 2003
    2,167
    Ballarat, Victoria
    HX620W is the best PSU I've ever owned, and I've probably owned at least 15 of them over the years.
    For the money it cannot be beaten. Quiet, and cables are funky too.
  5. Scotty1991
    Scotty1991 (Banned or Deleted)
    Apr 27, 2007
    1,527
    Got my 620 on its way :D
  6. WooKiE_MaN
    WooKiE_MaN Member
    May 3, 2006
    3,015
    Craigieburn
    when u get it, you will be so wrapped i gaurentee ya
    i didnt expect it to be packed so dam well, u even get cable ties wif it..., and a little bag wif all the molex connectors + extra ones..:D wtf?
    best PSU, hopefully they make high wattage ones later and ill get one for my server...:D
    ill have them all in my systems one day, they rock.
    corsair PSU's 10/10 + 100% satisfaction..:D
  7. Scotty1991
    Apr 27, 2007
    1,527
    That thermaltake 750 isnt for my pc anyways :D, just for benching
  8. ADV
    ADV Member
    Aug 19, 2001
    1,151
    P✪RT MACQUARIE
    *puff of smoke*
    tada!
    corsair 750w
  9. antari
    antari Member
    Aug 27, 2006
    1,406
    Bendigo
    I hate my Corsair HX620W!!!!
    Nah just kidding, it's tops, absolutely brilliant, but I do have one major, major problem with it: the little sticker on the back has come off :tongue:
  10. WooKiE_MaN
    WooKiE_MaN Member
    May 3, 2006
    3,015
    Craigieburn
    y
    maybe it got blown away wif the power this psu supplies...:D
    hahaha yeh....it was funny for a 2 seconds :p
  11. snivlac
    snivlac Member
    Aug 2, 2007
    302
    Yep, mine came off as well, put a bit of glue and problem solved.
    Also, although the cables look sleek I dont like em because they are too stiff :tongue:
    But performance wise you cant beat it :thumbup:
  12. pongie
    pongie Member
    Dec 1, 2004
    1,050
    Sydney 2166
    Question would be, does the new VX and TX series live up to the standards set by the HX series.
    I think I've read somewhere the VX550 is no longer a seasonic, but the VX450 is. Not sure about the TX series
  13. OldnBold
    OldnBold Member
    Oct 5, 2004
    4,261
    Sunshine Coast
    I think you will find all the VX series Corsairs are assembled by CWT (Channel Well Technology).
    A good point to make here is that even though the HX series are assembled by Seasonic, they use Corsair specifications. They are not Seasonic PSUs.
  14. Sub.Zer0
    Sub.Zer0 (Banned or Deleted)
    Aug 7, 2007
    3,521
    Yup another mad HX620 fan here! Love it!
    Re the 750W one, it's not modular. :( Looks to be a good one tho.
  15. NormM
    NormM Member
    Jul 2, 2001
    1,874
    Beverly Hills
    Lol, that's the only problem I found with my HX520W :sick:
    I've seen a couple of reviews of the HX520/620 where the sticker is coming off as well.
    Maybe Corsair should have spent 5c more and got stickers with better glue :)
    Very happy with the PSU though...
  16. synmnky
    synmnky Member
    Sep 23, 2005
    344
  17. Sub.Zer0
    Aug 7, 2007
    3,521
    And modular too. Nice one! :thumbup:
  18. TRG.dOinK
    TRG.dOinK Member
    Jun 27, 2002
    4,711
    Melb East
    Im using a corsair 450watt, im happy :)
  19. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,818
    ADL/SA The Monopoly State
    nothing compared to Tagans packaging, you get a suitcase and all for ya PSU :)
    wouldnt be too hard to expect a 700w+ one soon as the Seasonic M 12 comes in 700w :) seasonic obciosly have the core, corsair just have to re package it :)
  20. Zan5hin
    Zan5hin Member
    Jun 24, 2002
    44
    This PSU is great, I got a POS Hyper Type-R which was noisy and unstable and when I heard about this cheaper "seasonic" I snaffled it and have never looked back!
    +10
