Cosmos Ultra Tower clear side panel (first attempt)
Discussion in 'Modding' started by STUdog, Feb 28, 2013.
  1. STUdog
    STUdog Member
    Dec 18, 2007
    1,294
    Hi Guys
    So as some of you may know I have a Cosmos II Ultra Tower, but I was unhappy that the fact there is no window in the side panel to show off my fancy bits :p
    So, after inquiring about some custom pre-made side panels which cost nearly the same as the case itself, I decided to do my own.
    I've only put up final pics but I do have some other random shots throughout the mod. Time to complete this mod took 1 day.
    I even did a slight bend to follow the case edge. I'm just not sure whether to put fan holes or slits in it for the fans. But I'm scared ill break it or stuff it up, lol
    Cost of this mod was roughly $50 for the bit of plexi and $15 for a plastic blade for my circular saw. I only used 5mm plexi which seems to be fine and is super strong.
  2. VirtualNinja
    VirtualNinja Member
    Apr 27, 2003
    1,251
    North Parramatta
    That looks brilliant.:thumbup: Unless there is a noticeable increase in temps forget the vents.
  3. Enjoi
    Enjoi Member
    Sep 7, 2010
    714
    Melbourne, VIC
    beautiful work Stu :)
  4. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,427
    Cheltenham VIC
    Looks good - I just don't get the drain valve at the bottom of the GFX card - it looks a bit out of place - also the use of different tubing?
    Komm
  5. crocodaVe
    crocodaVe Member
    Dec 9, 2011
    534
    ACT, 2600
    STU does it again !! Your system inspired the perpex mini I did - that top pipe !
    pneumatic remote vent ?
    GW man.:thumbup:
    STUdog
    STUdog Member
    Dec 18, 2007
    1,294
    Yea drain port is more for convenience and don't waste a port somewhere else,
    There is 1 type of flexi tubing and the other is hard acrylic tube
    STUdog
    STUdog Member
    Dec 18, 2007
    1,294
    Decided to do a video :)
  8. Davo1111
    Davo1111 Member
    Mar 5, 2009
    3,017
    out of curiosity, how did you bend the plexi so accurately? Do you have a plastic heater thingo?
  9. Dr1fty
    Dr1fty Member
    Dec 29, 2006
    1,718
    With some clamps and timber you can minimize the bend distance. He would have had to measure the radius of the case bend and try to match it with the gap between the boards etc.
    Unless he has some magic trick, probably something like above.
  10. silverbullet
    silverbullet Member
    Apr 2, 2005
    2,002
    Marcoola, Sunshine Coast
    Proper way is to leave the protective wrap on then throw it on the strip heater then quickly over to the panbrake to perform the bend. More than likely though by a couple of telltale signs is he used a heat gun and just bent it over in a b&w portable vise benchtop or similar. Looks great though! :thumbup:
  11. BlueRaven
    BlueRaven Brute force & optimism
    Jul 29, 2010
    5,635
    2076
    Very nice work, looks like the bend is pretty spot-on.
    Super smooth rig, impressive. :thumbup:
  12. converge
    converge Member
    Aug 29, 2009
    2,316
    Looks awesome stu, great mod.
    Really do like this case but not having a window side panel has always put me off.
  13. ABEIQ
    ABEIQ Member
    Jun 22, 2013
    60
    Looks Great! A case window was what i felt was lacking in this case, and a full clear panel looks stunning!
  14. WishBone17
    WishBone17 Member
    Nov 21, 2002
    4,560
    Dundas (Sydney)
    quite a beautiful build you got there mate, really digging the clear side panel and how you've hidden almost most of the stuff away with the white stuff.
    nice work
