CPU performances Macbook Pro 2016 vs current
Discussion in 'Apple Desktop Hardware/Software' started by drunkntigr, Nov 7, 2018.
  1. drunkntigr
    drunkntigr Member
    Nov 18, 2004
    1,457
    MELB
    Need to get a mac laptop so can run off 4k screen whilst being portable. Need a bigger screen so going 15"
    Spending $2400 on a new 2016 macbook 15" with the 6700HQ cpu - or should I just buy a new 13" version 2018 for $2200? The quadcore i5 apparently performs better, but the onboard iris 655 won't be as good as the radeon 450 - albeit marginal.
    How slow really is the 6700HQ? Only really use chrome, photoshop and youtube/netflix.
    I've been running a 6600k on my desktop and it seems fines - yes I know it will probably beat both the newer i5 on the 2018 macbook touchbar and the 6700hq
  2. mAJORD
    mAJORD Member
    Jun 4, 2002
    9,341
    Griffin , Brisbane
    6700hq is the same skylake core as the new models, (i7 quad cores) it's a bit less efficient , but is TDP @35w vs iirc 15 on new models.
    you're looking at a dual core (i5) 13" - the 6700hq would be much faster in this instance
  3. [KEi]SoVeReIgN
    [KEi]SoVeReIgN Member
    Feb 20, 2002
    8,146
    Buy an eGPU and attach your screen.
    Portable web browser when you’re mobile and grunt at your desk.
    I just picked up a Razer Core X and RX580, both fully supported by MacOS
    drunkntigr
    drunkntigr Member
    Nov 18, 2004
    1,457
    MELB
    Don't use it for gaming at all. Really just after a bigger 15" screen for a laptop and mac os. I find I'm more productive on mac than windows as get so distracted by the clutter. Mac OS seems to limit multitasking which often causes distraction
  5. [KEi]SoVeReIgN
    Feb 20, 2002
    8,146
    Reality is for 90% of what you do you don't really need the GPU grunt, although some functions in Photoshop will be sped up with the Radeon.
    drunkntigr
    drunkntigr Member
    Nov 18, 2004
    1,457
    MELB
    Don't game at all now. Just wanted the 15" screen as more comfortable than 13 and 12 inch. After changing to 32" 4k, I find the 14" on my T470 is just a bit too small.
