CPU upgrade help? Ryzen or Intel
Discussion in 'Intel x86 CPUs and chipsets' started by jvalente, Mar 3, 2020.
  1. jvalente
    jvalente Member
    Mar 29, 2010
    560
    Hi All,
    A few years ago I had an i7-5820K, and the motherboard died. So for a fix build bought cheap at i5-9400F with ASRock B365M.
    I was looking for the cheapest build I could get.
    But now I'm streaming and gaming and I find the i5-9400F is maxed out.
    BTW I'm on a GTX1080.
    Now decision time:
    1) Ryzen 3700X with new motherboard - Around $600 - $700 I'm estimating -use wraith cooler (won't overclock)
    2) i7-9700 (since I can't overclock on ASRock B365M) - $549. can I use the stock cooler on the i5-9400F? If no then another $50 for a cooler - Cryorig M9 Dual plus - $600
    3) Wait for new RYZEN and/or intel Later this year.
  2. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    2,351
    Melbourne 3073
    Easy ryzen 3700.
    Dilbery likes this.
    jvalente
    jvalente Member
    Mar 29, 2010
    560
    You mean 3700X?
  4. Dilbery
    Dilbery Member
    Nov 19, 2005
    1,466
    Sydney, NSW
    1 and 3)
    You can have the best of both worlds, buy a 3700x now and if you feel so inclined a bios update will give you support for the 4th gen CPUs..
  5. shane41
    shane41 Member
    Nov 10, 2008
    7,403
    dice que no sabe
    Anything less than 9900K is gimped Wintel shit. Cores turned off, HT turned off because it did not pass.
    Fuck that full stop. I have bought my fair share of hot pieces of shit Silicon lottery that you could light a cigarette on.
    Support with your $ Dollars $ AMD. :D
    jvalente
    jvalente Member
    Mar 29, 2010
    560
    What board would you recommend?
  7. vladtepes
    vladtepes Member
    Sep 30, 2015
    3,148
    Brisbane, Qld
    jvalente likes this.
    jvalente
    jvalente Member
    Mar 29, 2010
    560
    I don’t care about form factor. My case is big so I can go ATX.
    how was the experience of going to team red?
  9. zeeps
    zeeps Member
    Apr 11, 2006
    837
    If you are streaming + gaming then perhaps a dedicated streaming pc would be apt;
  10. Dilbery
    Dilbery Member
    Nov 19, 2005
    1,466
    Sydney, NSW
    jvalente
    jvalente Member
    Mar 29, 2010
    560
    adamsleath likes this.
  12. M1ck1
    M1ck1 Member
    May 2, 2018
    578
    Toowoomba Qld
    The high end MSI 450 boards are good and the Tomahawk got good reviews, as far as X570 the Asus Tuf wifi is a good board good vrm and enough features no intel lan if you care and at a reasonable price
  13. flu!d
    20,829
    As an incredibly long term Intel user, I have to say that if I was inclined to upgrade my current machine right now I would go for one of AMD's solutions as bang for buck they just have a value that Intel can't seem to match ATM.
    Having said that, I don't upgrade very often and currently have no itch to do so...
    hairy likes this.
  14. dasa2
    dasa2 Member
    Feb 5, 2003
    1,032
    Northern VIC
    If you want to upgrade to AMD 4000 you could get AMD 1600 AF $149 for now which will double your threads over the current CPU then just stick a new CPU in when the time comes.
  15. OJR
    OJR Member
    Jan 19, 2013
    6,117
    Going from 8 to 12 is not exactly double.
  16. dasa2
    dasa2 Member
    Feb 5, 2003
    1,032
    Northern VIC
    i5-9400F is a six core\thread CPU.
    The eight core 9700 was a potential upgrade option.
  17. OJR
    OJR Member
    Jan 19, 2013
    6,117
    Didn’t he say he’s got a 5820K? Or am I missing something?
  18. adamsleath
    adamsleath Member
    Oct 17, 2006
    20,380
    Sunnybank Q 4109
    +1 tomahawk (based on reviews of its good power delivery)
    And 3700x
    That’s what I would do now.
    You can always sell off the 3700x if you want 4th gen later. I doubt you’d really need to anyway
  19. dasa2
    dasa2 Member
    Feb 5, 2003
    1,032
    Northern VIC
    5820K is a six core twelve thread CPU which once overclocked can perform about the same as Ryzen 3600 but OP said the MB died and it was replaced with i5 9400.
    If you want two M.2 ports the MSI B450M Mortar MAX $159 has the same VRM as the Tomahawk and saves you a little cash.
    Dilbery likes this.
  20. Bert
    Bert Member
    Feb 21, 2002
    1,467
    Brisvegas
    Ryzen
