cs sound through onboard sound only
Discussion in 'Windows Operating Systems' started by MoNk{LAH}, Aug 12, 2002.
  1. MoNk{LAH}
    MoNk{LAH} Member
    19,976
    i'm using a maxi fortissimo atm on my PC. I'm going to be using my onboard sound on my a7v266e soon, so i can use both speakers and headphones at the same time.
    maxi sound card: 4.1 speakers (for divx/mp3s)
    onboard sound: headphones(games like cs)
    now, i can get winamp to use the maxi sound card for its output of the mp3s
    if i set the default soundcard, the divx and mp3s both run through the speakers.
    in games like cs, the output is also through the speakers if i do this
    however, i want cs to output sound through the onboard sound (headphones)ONLY
    can any one tell me how to? or would it be easier if i get a newer soundcard like a sb live de5.1 which allows both the headphones and the speakers?
  2. roodog
    roodog Member
    Jul 31, 2001
    4
    You cannot have two sound cards installed.
    Your onboard sound is disabled so if buying a new s/card is easier than unplugging the other speakers and plugging in your headphones, go for it.
  3. AusKWiKsAnD
    AusKWiKsAnD Member
    May 28, 2002
    1,700
    Perth, WA
    You cant have two sound cards installed?? Since when?
    I'm using onboard and SB Live DE5.1 right now...
    I use microphone on the on board because I can't get the mic boost nearly as high from the SBLive... all output and other input is done from the soundblaster
  4. Crash Dummy
    Crash Dummy Member
    1,756
    Newcastle, NSW
    i'm doing the same. Onboard audio on my Epox 8K3A+ doing the audio dutys and my SBLive 5.1 outputting a signal to my BA7500g's. This allows me to run a stereo off the Analog output of the onboard audio and my BA7500g sub as a dedicated subwoofer.
  5. roodog
    roodog Member
    Jul 31, 2001
    4
    SorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorrySorry
    I meant he can't under Win XP. Win 9x and ME not really a problem but 2000, XP, and NT generally give massive problems.
    MoNk{LAH}
    MoNk{LAH} Member
    19,976
    um i'm using XP and have both onboard and my maxi fortissimo working.....so it can work :)
  7. AusKWiKsAnD
    AusKWiKsAnD Member
    May 28, 2002
    1,700
    Perth, WA
    hehehehehe me too...
    I'm running onboard on me Epox 8K3A+, and SBLive 5.1DE and Win XP.. Never had a problem.
    kWiKsAnD
  8. Fred Nurk
    Fred Nurk Member
    Apr 5, 2002
    2,243
    Cairns QLD
    its actually the other way around, it works in multitasking OSsbut not in 9X
