[WORKLOG] Custom acrylic case - hardline water cooled
Discussion in 'Extreme and Water Cooling' started by hawpinghaxbag, Apr 28, 2017.
  1. kEv_
    kEv_ Member
    May 5, 2012
    496
    awesome man, nicely done so far!!
    :thumbup:
    hawpinghaxbag
    hawpinghaxbag Member
    Jun 6, 2005
    4,097
    Your mum's place
    Putting this on ice till late July when i return from holiday in Whoreland
    General water pipe layout, not so keen on acrylic, petg pipe now, will prolly go chrome/silver shining or true brass/gold plated brass 12/10mm with a balanced mix of gentle bends and using fittings for tight bends.
    I generally dont like the look of most 90 degree or greater metal pipe bends in WC projects and personally not a fan of the copper look.
    Anyway, something to research while im away
    BP True brass fittings, they dont seem to make matching pipe though
    This colour would really stand out in the tint and chrome theme the case has
    Silver/chrome and fittings look
    Then there is the cable solution, im thinking black chrome various sized pipe from a hobby supply shop or something to make them blend into the background layer
  3. Tazor
    Tazor Member
    May 23, 2010
    1,526
    Canterbury, 3126
    Looks crazy amazing so far, subbed.
    hawpinghaxbag
    Jun 6, 2005
    4,097
    Your mum's place
    Im busy with business and the whole avoiding bankruptcy thing so project is on hold for time being
    Also want to see if any nice z370 itx boards come out
  5. Tazor
    Tazor Member
    May 23, 2010
    1,526
    Canterbury, 3126
    Asus has confirm Strix X370i Gaming for October. Holding out for it myself.
    hawpinghaxbag
    Jun 6, 2005
    4,097
    Your mum's place
    Z, not X. No AMD trolls in my thread lol :):p
    edit: just read ROG Impact series is EOL so i have the last one made, the VIII Z170, so i can slap a 7700K in that and be happy for a few years, i have CL14 3200 ram in it too and BP makes a nice semi-full cover block for it. The big downside of this board and probably what accelerated it's demise is there is no m.2 SSD support
  7. Agg
    Agg Administrator
    Jun 16, 2001
    29,877
    A Reported Post Near You
    Any updates? :)
    hawpinghaxbag
    Jun 6, 2005
    4,097
    Your mum's place
    Havnt done much, January will be the month for finishing this, got a few bits and pieces and the mobo block though
    12 vs 14 vs 16mm pipe. 14 is the sweet spot for me personally but still making a decision, going 12 means saving money on adapters. All sizes have 0.7mm thick walls so to bend 12mm you just use a 1/2" copper pipe bending spring which fits in perfectly. To bend 14mm you use a 1/2" 12.7mm diameter spring which is a tight fit but works
    Experiment bending the pipe, not as bad as the internet community makes bending electroplated hard brass tube out to be but still get slight imperfections in the plating. I'll make slight bends and using fittings for 90 degree turns
