Custom Cube style SFF case with 140mm EK-MLC Phoenix support
Discussion in 'PC Build Logs' started by Tazor, May 16, 2019.
  1. OP
    Tazor
    Tazor Member
    May 23, 2010
    2,307
    Canterbury, 3126
    At the back - above the PSU
    Tazor
    Tazor Member
    May 23, 2010
    2,307
    Canterbury, 3126
    Okay guys, I've finally completed the build - it wasn't the easiest build and required some adapting along the way - but she's done, she's beautiful and she's quiet while smashing out some solid 4k gaming performance:
    I found out straight away the feet I bought included screws too short to get through the thick panels. Luckily standard fan screws were exactly the right size!
    I pre-inserted the cables to try and avoid any awkward moments later in the build where my hand is cramped into a tiny hole trying to get the damn thing to fit in... That's not what she said
    Next thing I found was the power button didn't fit through the hole in the back of the case - but luckily it just happened to thread straight in, so it's super flush and clean:
    GPU and top fan in (Was harder than it looked):
    Test fitting the AIO - note the gap between the radiator fill-port and the GPU backplate (or lack-there-of):
    Block fitted:
    PSU in and powered on:
    I did forget 1 or 2 things that are going to be a pain to remedy - namely the bottom fan filter or a bottom fan full stop - I may rebuild in a little bit and add that in, I think I may also swap out the top fan for a slim fan to just improve space efficiency (thinking of using the SilverStone A-RGB fans) and then I'll swap out the front fans on the radiator.
    But would love to hear feedback from everyone!
    Edit: Just placed an order for new fans - got 2 Silverstone 15mm slim ARGB fans and a couple of the ARGB Air Penetration fans - due to the layout I think the air channeling fans will help get the air out of the radiator more efficiently as there's a lot of obstructions which I think the AP's will be ideal for dealing with.
    Should add a nice little bit of optional bling to an otherwise very minimalist build.
    Evilhomer, juzz86 and argent like this.
  3. juzz86
    juzz86 Member
    Nov 15, 2013
    1,126
    Forth, NW TAS
    That's awesome mate, a lovely finish. Tolerances bang-on :thumbup:
    The cables are really sexy - like snakeskin. That 12mm gain on a single 38mm fan we were discussing really is likely to make a big difference there - a bit more room to take a bit of strain off your cable connections.
    Colour me bloody impressed mate - I love it :thumbup:
    Tazor likes this.
  4. argent
    argent Member
    Mar 20, 2003
    2,281
    fullarton.adl.sa.au:5063
    Tazor I noticed that you have mesh as the dust filter! Mind letting me know what spec it is? I've been researching mesh for a bit but I can't seem to find similar ones already used in my Shift. The aperture is about 0.8mm but the strands are very thin in comparison to a lot of stuff I've been looking at...
