Custom valve cap thumbscrews
Discussion in 'Modding' started by Goose360, Sep 30, 2009.
  1. Goose360
    Goose360 Member
    May 31, 2009
    9
    Hi everyone,
    I saw this article about custom thumb screws on MetkuMods and thought I'd give it a try
    http://metku.net/index.html?path=mods/screws/index_eng
    First I bought some cheap shiny valve caps, along with some Araldite (epoxy)
    The screws are just from my parts box
    The caps (only $6 per set from the markets)
    Mixing the epoxy
    I used some of the packing foam from my case to hold them upright to dry
    Leaving them to dry
    The final result!
    I apologise for the blurry ones. I haven't quite mastered macro photography, and my camera isn't that great
    This was a really cheap, quick and simple project, but (I think) it looks really good.
    Plus there are heaps of different things you could use instead for your own unique look
    Comments or suggestions welcome :D
    -Goose360
  2. BloodDonor
    BloodDonor Member
    Sep 3, 2001
    1,592
    Invercargill NZ
    nice work... let us know how they hold up :)
  3. Smashedcrab
    Smashedcrab Member
    Jan 22, 2009
    176
    Great job they look good.:thumbup:
  4. Spork!
    Spork! Member
    Jun 5, 2009
    2,294
    Tasmania
    cheap, quick, simple and effective.
    4 of my favourite things. :D
    Goose360
    Goose360 Member
    May 31, 2009
    9
    Thanks BloodDonor, SmashedCrab and Spork! much appreciated
  6. ozgeek
    ozgeek Member
    Oct 4, 2009
    4
    Mt Morgan, QLD
    Are those valve caps for car/bike tyres?
    That looks cool. I might give it a go. Where can I get those caps from?
    Goose360
    Goose360 Member
    May 31, 2009
    9
    Thanks Ozgeek,
    yeah these caps are for car tyres, but anything similar will work.
    I got mine in the local markets from a car modding place, but I'm sure you can find them in any car shop (super cheap etc) or bike shop.
    The caps seem to have the right sized opening to fit the top of those standard case screws (like I used) which makes it quite easy.
    You should definitely try it. For the small amount of time and effort, it looks great.:thumbup:
  8. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,050
    Perth , East Vic Park
    how strong is the bond?
    if you twist hard on the cap is it likely to come off?
  9. Renza
    Renza Member
    Dec 1, 2004
    4,660
    yeh probably should have used JB weld for a stronger bond. they are also a little long for my liking.
    otherwise, great mod!
    Goose360
    Goose360 Member
    May 31, 2009
    9
    Thanks Butcher9_9 and Renza,
    I tried to break the bond by tightening it in as much as possible (so did my dad) and neither of us could break it. So its pretty strong
    To test it further, we placed pressure perpendicular to the join. This did eventually break the bond, but it took a while and a the amount of force necessary means you would actually have to be trying for the bond to break.
    they seem strong enough for what they are. Maybe next time I'll try JB Weld and see how that turns out.
    I agree, they are a little long, but I like the design and there wasn't a huge range of styles to choose from where I bought them
  11. ozgeek
    ozgeek Member
    Oct 4, 2009
    4
    Mt Morgan, QLD
    I've found some (3) spare metal valve caps around the house. Turned 2 into case screws (already had 2 "real" case screws). They look great. Thanks for a nice idea.
  12. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    136,470
    Omicron Persei 8
    Nice, very nice simplistic mod. 10 points from me, and they look good too : )
  13. ttv8
    ttv8 Member
    Jan 16, 2007
    447
    BNE
    nice, i have lost a couple of thumbscrews, great idea
    Goose360
    Goose360 Member
    May 31, 2009
    9
    Thanks MR CHILLED and ttv8. very much appreciated
    @ozgeek - post pics! :D
  15. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,450
    Good job looks great and very effective.
    Goose360
    Goose360 Member
    May 31, 2009
    9
    Thanks Ford ftw! nice name btw :thumbup:
  17. TMM
    TMM Member
    Mar 29, 2005
    7,488
    scuffing the heads of the screws and the ends of the valve caps with some coarse sandpaper will help get a stronger bond too :thumbup:
  18. ysu
    ysu Member
    Sep 27, 2005
    1,097
    Central Coast
    very cool!
    thanks for sharing
  19. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    Cool. Good job.
    If you did find that you did have a problem with the glue bond coming apart, using JB Weld instead of araldite would fix that.
  20. Kyler
    Kyler Member
    Jun 22, 2009
    106
    Scarborough, WA
    yes these are exactly the same
